Old 04-07-2011, 12:45 PM   #1
Hotchkis
Drives: 1st through 5th gen Camaros
New 5th Gen Camaro Hotchkis Race Pack
The New 5th Gen Camaro Hotchkis Race Pack
Designed for maximum performance 5th Gen Camaros headed for autocross and track days, the Hotchkis Sport Suspension Race Pack is a tuned, balanced complete suspension solution for the Gen 5 Camaro. Born on the track and engineered for razor-sharp handling performance, the Race Pack improves steering response and stability, eliminates understeer and subframe movement and allows for precise driver control. Starting up front, the system includes a strong, lightweight Strut Tower Brace designed to clear Magnuson super chargers. To improve vehicle feel and offer a more aggressive stance, 1” lowered coil sport springs with performance rates are utilized. To control body roll, Hotchkis Competition Sway Bars are included; a high-strength tubular 1.25” front bar and three-way adjustable 1.375” rear bar allow you to dial-in the way the car responds to throttle steer and driver input. High quality 3-piece lined end links are included for both front and rear. The Hotchkis Chassis Max undercar brace, ties the rear sub frame to the uni-body, reducing wheel hop and subframe movement. This brace features Hotchkis exclusive aerodynamic extruded aluminum tubing for maximum weight savings and excellent ground clearance. All necessary hardware and complete installation instructions are included.
Kit Includes:
• Lightweight 1.25” tubular front bar. 210% stiffer than stock SS
• Lightweight 1 3/8” adjustable tubular rear bar +500,630,800% stiffer than stock SS
• Greasable polyurethane bushings, mounts.
• End links feature highest quality 3-piece PTFE lined heim joints with high articulation spacers and CNC machined aluminum Sleeves with wrench flats.
• 1” Lowered sport coil springs with high performance rates, F.210lbs/in, R.440 lbs/in
• Chassis Max Strut Brace designed to clear Magnuson supercharger systems.
• Chassis Max underbody brace, manufactured from Hotchkis exclusive, extruded aluminum arrow tubing.
• All Necessary Grade 10.9 hardware
We'd like to offer a special discount code good for 15% off any 5th Gen Camaro parts until April 15.
Call us and mention Camaro5 and Code: RTCAM5 to place your order.
Hotchkis is offline   Reply With Quote
Old 04-08-2011, 11:28 AM   #2
ARMYRockyMtn
ARMYRockyMtn's Avatar
Drives: 2010 Camaro V6 Red Jewel Tintcoat
Can you PM me info for something for the V6 model?
Kit Includes:
ARMYRockyMtn is offline   Reply With Quote
Old 04-09-2011, 01:30 PM   #3
Stay Marine
Still love daily drivin'
Stay Marine's Avatar
Drives: Built '10 IBM 2SS; '15 Black Z/28
does that include 15% on the BBS wheels?
Stay Marine is offline   Reply With Quote
Old 04-15-2011, 01:43 AM   #4
Hotchkis
Sorry, Stay Marine,
The 15% is only on Hotchkis brand products.
Remote Reservoir Seperate Bound and Rebound Adjustable 5th Gen Coilovers JusticePete Suspension / Brakes / Chassis 144 12-07-2011 04:50 PM
GM builds race-ready SSX Camaro and chooses Pfadt Race Engineering suspension PfadtRacing Suspension / Brakes / Chassis 55 07-14-2011 05:20 PM
