Old 04-09-2011, 01:41 PM   #1
GrinderSS
Drives: IOM 2SS/RS
LPE ZR1 Clutch Kit - Impressive!
After having an ACT twin disk for a while, the slow start shuddering never subsided, so I changed to an LPE ZR1 clutch kit and I've got to tell you it is absolutely fantastic.
The GM clutch is smooth as butter, no more shuddering and jolting on take off or when down shifting.
Lingenfelter deserves a great deal of credit for coming up with the idea to adapt the ZR1 twin disk clutch for use in the new Camaro's.
If you're considering a twin disk clutch, take it from a guy that made the expensive mistake of buying an after market product before switching to the LPE ZR1 clutch kit.
GrinderSS is offline   Reply With Quote
Old 04-09-2011, 02:10 PM   #2
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
Thanks for the info. I have the ram twin disk clutch, must say... i hate it.... think ill go this route when i need a new clutch.
kevin1106 is offline   Reply With Quote
Old 04-09-2011, 02:26 PM   #3
alssiri
alssiri's Avatar
Drives: 2017 ZL1 A10
Thanks for sharing my RPS twin is not that bad but will be considering this in the future .
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir
Glassskinz rear window valance .
2012 ZL1 A6 (SOLD)
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
alssiri is offline   Reply With Quote
Old 04-10-2011, 12:09 AM   #4
Camaro21
Drives: SOLD - 2013 M6 ZL1
I have had my LPE ZR-1 Clutch for a few months now and I absolutely love it too.. It doesn't get any closer to a stock feel !!!
Camaro21 is offline   Reply With Quote
Old 04-10-2011, 12:57 AM   #5
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Did you guys have to change flywheels also...I have the ACT twin as well, and it shudders a little bit... Additionally, what ft/Lbs is it rated for...???
Old 04-10-2011, 08:25 AM   #6
Stingr69
'69 Owned Since '79
Stingr69's Avatar
I requires a different (aftermarket) flywheel and a custom spacer for the slave cylinder.
-Mark.
Old 04-10-2011, 11:11 AM   #7
BUMBLEB
IN GOD WE THRUST
BUMBLEB's Avatar
Drives: 2010 RY 2SS RS M6 TVS2300 2015 Z06
Just ordered MINE
BUMBLEB is offline   Reply With Quote
Old 04-10-2011, 11:27 AM   #8
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
I'll be doing the ZR1 kit after the fest.
Old 04-10-2011, 07:09 PM   #9
GrinderSS
Drives: IOM 2SS/RS
Lingenfelter has the entire kit on their site. It includes their custom aluminum flywheel, slave cylinder adapter, slave cylinder/throwout bearing, and the clutch.
It's expensive, but believe me you do not want to buy a cheaper twin disk like the ACT....crapola!
Old 04-10-2011, 07:21 PM   #10
Silver Ice
Silver Ice's Avatar
Drives: 2010 Camaro 2ss-rs
Good info. Thanks
Pfadt drop springs,
Pfadt sway bars
Pfadt end links
Pfadt rear tie rods
Pfadt rear trailing arms
Pfadt rear lower control arm reinforcement bracket
Kooks Long tube headers and high flow cats
Airaid Cold air intake
Magnaflow catback exhaust
Mti short throw shifter
Jannetty tune
Silver Ice is offline   Reply With Quote
Old 04-10-2011, 08:15 PM   #11
600hp-lpe
Drives: 2010
There are a few of us on the LPE thread that have had this dual disk clutch for a year now.. it still works perfectly!
When I need another clutch, it will be this one again. it has been problem free.
600hp-lpe is offline   Reply With Quote
Old 04-11-2011, 04:39 PM   #12
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
You can do the original LPE ZR1 clutch or the new one recently released that is rated at 960+ ft/lbs. That's the one I'll be getting soon.
FrankT is offline   Reply With Quote
Old 04-11-2011, 04:45 PM   #13
FrankT
FrankT's Avatar
By the way, I currently have the Fidanza twin disc. Holds the power okay, but chatters, shudders and makes all kinds of strange noises when you start off. I wouldn't have another Fidanza if it was given to me.
Old 04-11-2011, 08:53 PM   #14
GrinderSS
Drives: IOM 2SS/RS
Frank, do you know what the torque rating is for the original LPE ZR1 clutch?
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 06:56 PM
Chronicle of the Red Devil - a Lingenfeltered and Pedderized 2010 Camaro 600hp-lpe Member Car Journals 86 09-14-2011 07:17 AM
What exactly burns the clutch on an m6? DarkneSS 5th Gen Camaro SS LS LT General Discussions 49 04-15-2011 11:55 AM
Interesting ZR1 Read TFord General Automotive + Other Cars Discussion 2 09-09-2008 10:32 AM
Chevrolet Corvette ZR1 (2008) andykhol23 General Automotive + Other Cars Discussion 3 05-22-2008 12:24 AM
