04-10-2011, 05:32 PM | #1 |
Need driveline recommendations
I will start out by giving the numbers here. whp is 632 as of right now. I am on a stickier set of all weather tires currently. Slicks are coming soon.
Ok so recently after a hard launch i destroyed the rear end. I temporarly fixed that by finding some parts off the wrecked 2010's. My question concerns what do i need to do for my rear end. I talked with Ted at jannetty and he recommends the 9 inch conversion and curious who has done that. And what clutches do you guys recommend. Is twin disked really needed? I found these monster single disk clutches and wondering if anyone has messed with these yet and any words on them.
Mods:
Dynatech Headers, High flow cats, MSD 8.5 wires, magnaflow bullits, Halltech intake, SCT tuner, maggie tvs 2300, Jannetty Tune, BMR driveshaft safety loop, Pfadt drop springs, Pfadt rear trailing arms, Pfadt rear tie rod, ACT Twin Disc Clutch, DSS Aluminum Driveshaft. Appearance Mods: AAC Concept Sidemarkers, P13W Plasma LED Bulbs, Iforged Classics 20". Next Mods: Cam and Fuel System. |
04-11-2011, 05:57 AM | #2 |
Drives: own more cars than i can list Join Date: Nov 2010
You are approaching the Hp area where the stock diff will not make it anymore. contact some of the guys that have posted installs on this site. they would be the ones to talk to. Ted from Jannetty has installed may of them and has given some good advice.
04-11-2011, 07:13 AM | #3 |
Drives: First 9 inch-12 bolt IRS Camaro Join Date: Jun 2009
At your power levels any single disc wont be up to the challange.If your going to be at the fest i will have my car there with a twin disc that your more than welcome to drive ,it also has the first 9 inch that has been in since april 2010 and has about 20,000 miles on it.The 9 inch kitt will bolt right in with no cutting or welding .If i can answer anymore questions about the clutch or 9 inch give me a call i can help you with either or both 980-521-07722
04-11-2011, 12:04 PM | #4 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
Driveshaft Shop all the way. Great Guy's to deal with. Super service toooooooooo.
04-12-2011, 09:42 PM | #5 |
Drives: 05 GTO Join Date: Jul 2009
I agree, your pushing the limits of the stock rear since there isnt a good posi out yet for these cars.
We make a bullit proof 9" conversion for the 2010+ Camaro that uses a fabricated housing and our 1000+hp axles, driveshaft of your choice (aluminum or carbon fiber) for a great price. We can also build the rear with the 35 spline wavetrac posi that comes with a lifetime warrant. We will have one of our 9" kits on display at Camaro fest if your at the event. Thanks Chris @ Gforce |
04-12-2011, 09:48 PM | #6 |
Drives: 2010 rs ss Join Date: Jan 2010
04-13-2011, 11:34 AM | #7 |
I have just slightly more than yours. I have 9 inch, axles, and one piece shaft fron driveshaft shop. Also have ram twin disc clutch. Works absolutely perfect. Also suggest chassis brace and at least trailing arms. Good luck.
04-13-2011, 02:36 PM | #8 | |
Drives: 2010 Join Date: Jul 2009
Sounds like a SOLID recommendation.I would add Subframe bushings and Diff bushings as well. You won't need the diff bushings if you replace the rear diff with a 9" or LPE's rear diff. I would suggest you shop at Drive Shaft Shop, Gforce 1320, or Lingenfelter, for the parts Flyby recommended. |
Similar Threads | ||||
Driveline TSB's ?? | Caution | 5th Gen Camaro SS LS LT General Discussions | 2 | 04-08-2011 05:39 PM |
OBD-II Reader Recommendations? | Don57 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 4 | 10-03-2010 04:30 AM |
Strengthened Driveline | BoostedX2 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 16 | 08-01-2010 09:53 AM |
Driveline Loss at High HP | FASST 1 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 2 | 07-23-2010 11:15 AM |
San Diego/North County auto audio recommendations | loopback | USA - California | 2 | 03-07-2010 01:22 PM |
