Old 04-11-2011, 01:55 AM   #1
intofx
Drives: 2011 RS/SS Camaro
******** harness question...
I have an older amped bazooka tube laying around the garage and was wondering if the ******** harness will plug and play with it. Bazooka has their specific wiring systems and it looks like they want you to plug into the back of the head unit. Is the connector on the ******** splitter the same as what I would find on the back of the headunit?
TIA,
Matt
2011 RS/SS camaro
1969 RS/SS camaro
2007 Hummer H2
intofx is offline   Reply With Quote
Old 04-11-2011, 11:16 PM   #2
intofx
Anyone?
2011 RS/SS camaro
1969 RS/SS camaro
2007 Hummer H2
Old 04-12-2011, 01:02 PM   #3
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
No it is not the same perse. The harness plugs in between the stock amp and stock wiring harness basically creating a bridge. Out of the bridge you have five (5) connections, I am assuming you are only talking about the X3 connector and not the amp replacement kit.
The five (5) connections you have are:
4x rca outs used to send signal to your after market amplifier in either two or four channel config
1 remote turn on lead that you wire to your after market amplifiers remote signal terminal.
I am not familiar with a bazooka amp but I think you will be fine. If you have any questions email or call Steve directly. He is very knowledgeable and easy to work with.
Cheers
K
Moriartii is offline   Reply With Quote
Old 04-12-2011, 01:08 PM   #4
Steve@Subthump
Drives: 2011 2SS IOM Vert
TIA,
Matt
Are you referring to just the rca jack connections? If so, then yes, our harness has rca jacks, the same that you would find on the back of an aftermarket radio.
Steve@Subthump is offline   Reply With Quote
Old 04-16-2011, 01:45 AM   #5
intofx
I'll snap a pic tomorrow so you can see the input I'm referring to.
Thanks for the help.
Matt
2011 RS/SS camaro
1969 RS/SS camaro
2007 Hummer H2
Old 04-16-2011, 01:13 PM   #6
intofx
So, here the pics. Can I plug this up using the ******** harness? It's just collecting dust and I'd love to use it.
Sub
Plug
Harness - you can see the wires were cut when it was removed...
Thanks!
Matt
2011 RS/SS camaro
1969 RS/SS camaro
2007 Hummer H2
Old 04-16-2011, 05:12 PM   #7
Steve@Subthump
Looks like that connector plugs into the tube right? I see some rca ends at the bottom of pic 2. Those are what would plug into our harness. Then you'll need to find out which wire is the turn on lead and wire the power and ground to the battery.
Old 04-16-2011, 07:04 PM   #8
intofx
Yeah, it plugs into the tube and there are RCA's. When you say wire the power and ground, does your harness account for that or is it another wire I would have to run to the battery?
Thanks,
Matt
2011 RS/SS camaro
1969 RS/SS camaro
2007 Hummer H2
******** Wiring Harness HELP !!!! ToyotaCamaro Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 0 12-22-2010 11:14 PM
******** Boston Amp harness For Sale. JEFF2010SSMANUAL V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 1 06-23-2010 02:14 PM
Fog light harness Mod Question strauchpete Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 03-13-2010 09:31 AM
