Old 04-13-2011, 07:57 PM   #1
rmoreno145
CHEVY ROCKS
rmoreno145's Avatar
Drives: 1990 454 SS 2016 Garnett Red 1LTRS
Oil Change-Sport Mode Mpg
I have had my 2LTRS for almost two years, I have been using castrol gtx and was wondering if that is a good oil? I havent had any problems but want to know if anyone reccomends switching to synthetic blend or full synthetic and if so do i just start at my next oil change or do i have to put something else in before it to get out the excess oil first.Will i notice a difference when i drive if i switch?Also does driving in sport mode affect your mpg as to driving in D? Thanks
rmoreno145 is offline   Reply With Quote
Old 04-13-2011, 08:17 PM   #2
cdn2usa
cdn2usa's Avatar
Drives: 2010 2SS
Sorry.
I have always used Mobile 1 synthetic, changed every 5 k.
Yes you should change, no you do not need to prep the engine.
You don't need to use Mobile 1, just the best oil you can get. It's worth the small investment in the long run. I plan on keeping mine for a long time and driving it.
Aqua Blue 2SS c/w factory white strips, MT.
Installed options;Tinted Windows, De-badged,
Hurst Shifter,CAI,Vmax throttle body, Kooks LT Headers, High Flow Cats,Borla Touring Axle Back, ADM Scoop, Washwater relocation,Diablo Predator(c/w Ted's Magic), Custom start defeat switch, painted engine cover, shark fin & bow ties, ABL lighting, Rear Camera.
cdn2usa is offline   Reply With Quote
Old 04-13-2011, 08:23 PM   #3
LoneStar
LoneStar's Avatar
Drives: 2011 IOM Camaro
Castrol GTX is just a conventional oil (as compared to synthetic). So, switching to a synthetic will at least be as good as your current oil, and will probably be better depending on your driving habits. Do you race your car? Stuck in stop-and-go traffic often? How often are you changing your oil? From what I understand, synthetic oil resists thermal breakdown more than conventional, so it's supposed to be effective for longer time.
If you switch, there's nothing special to do. Just drain the oil properly (including the oil filter) and fill with synthetic/synthetic blend. I would also recommend NOT using Fram filters. Go with Mobil1 or Wix filter.
I haven't run conventional oil (other than the factory fill), so I'm not sure you'd feel any difference with the change, maybe a placebo difference?!
Driving in sport mode holds the gear longer, into higher rpms, so it could lower your mpg's, but it would mainly be dependent on your right foot...
LoneStar is offline   Reply With Quote
Old 04-13-2011, 08:28 PM   #4
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2017 ZL1 M6
Unless you have an SS, (which you and I have the V6) I personally don't see the need to run synthetic per you change your oil regularly (on schedule) and don't over use it.
If I had the V8, I'd definitely run synthetic...but since I don't I just use regular.
My $0.02
Stock...For Now.
CamaroKid300 is offline   Reply With Quote
Old 04-14-2011, 04:51 PM   #5
mpiper
mpiper's Avatar
Drives: 2011 Black 1LT RS
Yes, you should switch to synthetic. Synthetic oils provide better wear protection, better heat breakdown protection and more consistent sheer point than conventional oils.
Basically an engine is a pressure cooker. Traditional oils get cooked down over time, with the lighter elements boiling and evaporating away, leaving the heavier components. Synthetics are more consistent, so there really isn't much to boil away.
As far as the switch? If you've been religiously regular with your oil changes, just drain old, add new. But if you've skipped or stretched, run a quart of cleaner in there for a day or so (follow directions, one mega cleaner CANNOT be left in and driven , while others are supposed to be driven). Drain that out with the old oil and swap filters. Then fill up with the cheapest oil that meets the engine specs. Turn on and let it run for 15-20 minutes. Drain this out. Now put in a new filter and fill up with the synthetic oil.
The reason I recommend this if you've stretched oil changes is that synthetics do a better job of keeping the dirt and contaminents in suspension. So if any crud has been baked onto your engine, it'll come loose with the new synthetic flowing. So, run a cleaner to get it out so the new synthetic can start without having crud in it from day 1. But, two oild changes in a row can be expensive, even if you do the labor. So ONLY do this if you've pushed the oil change schedule.
There is also a slight benefit in gas mileage with synthetics. NOT if you compare new oil to new oil. The difference is that at 4,000 miles, regular oil is thicker and MPG will decrease. At the same mileage with synthetic, it should be VERY close to new in viscosity, meaning the mileage should be as good as right after an oil change. This will vary depending on what synthetic you use, but all are better than regular.
I use Amsoil, but any DEXOS 1 quality Synthetic will work great in our V6 engine. Some people say you get a smoother idle, quicker throttle response, and similar things. I personally think its the same as any new oil change. Its the better protection that matters most to me. If there is a performance benefit, it's a free bonus.
mpiper is offline   Reply With Quote
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 07:53 PM
2010 Camaro V6 Oil and Oil Filter Change azamazonqueen Camaro DIY & HOW-TO instructions & discussions 116 03-19-2017 02:36 PM
Can we use the catchcan made for the G8? HaZe_X Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-05-2010 11:35 AM
