Old 04-13-2011, 10:30 PM   #1
Lil' James
Drives: 2018 Camaro 2SS
Axle Back or Cat Back?
Which exhaust system do you recommend?
Lil' James is offline   Reply With Quote
Old 04-14-2011, 02:08 AM   #2
DanteTDH
Drives: A car.
I'm wondering this as well, I've pretty much made up my mind with the Borla S-type series...
Also, I know this is off topic, but what is (and I mean hands down) the best CAI available to date? I was thinking either CAI or Air raid (only reason I say air raid is because I read in the forums somewhere they re-designed or used different/new material on their CAI that made them better?)
DanteTDH is offline   Reply With Quote
Old 04-14-2011, 04:08 AM   #3
oyealiz
oyealiz's Avatar
Drives: c7 3LT, manual, vert
Send a message via AIM to oyealiz Send a message via Yahoo to oyealiz
I have a v6, and this is the thread from my install. Thought you might want to click on the installer's info about what they do on the SS.
Good luck...I listened and listened to different setups before I decided which one to go with. I should do a new recording now that it's been on the car for a year!
http://www.camaro5.com/forums/showthread.php?t=79544
Oops, I see the website is way down in the thread. Here it is...http://www.kinneysmufflershop.com/
oyealiz is offline   Reply With Quote
Old 04-14-2011, 04:11 AM   #4
VictoryRed10
Drives: 2010 Camaro 2SS/RS
axle back is all about sound whereas cat back youll see some gains. my recomendation spend a a little more and get headers
L99
Magnacharger 2300 @6 psi
American Racing 2" LT's long system
Borla ATAK Mufflers
Fastlane CAI
Pfadt Diff mounts
472 RWHP
Future mod: LS3 conversion,JRE Blower Cam, Posi Mod, billet caps, boost a pump and upping the maggie to 9 psi, Forgestar wheels, Michilen Pilot SuperSports, Pfadt stage 3.
VictoryRed10 is offline   Reply With Quote
Old 04-14-2011, 04:15 AM   #5
VictoryRed10
i just ordered my third CAI K&N fastlane and now C.A.I. you would hard pressed to find anything negative about their kit
L99
Borla ATAK Mufflers
Fastlane CAI
Pfadt Diff mounts
472 RWHP
Old 04-14-2011, 05:36 AM   #6
papabearcamaro
papabearcamaro's Avatar
Drives: 2012 Chevrolet Silverado 4x4 Z71
If you can afford it catback is the way to go.
SOLD(Traded for 2012 Silverado Z71 4x4 and 2012 Sonic Hatch.)...2010 Camaro 1SS/RS/LS3,yellow with House of Kolor Tangerine Pearl rally stripes,manual trans.Hurst short throw shifter,4 pack rally gauges,Roto-Fab air intake,Kooks long tube headers with high-flow cats,Borla S-Type catback exhaust,Comp Cam,PRC ported heads,Maggie with 3.6 pulley and 1:1 cog drive,secondary fuel system with 65lb injectors,ADM digital A/F and Boost gauge,Pfadt trailing arms and subframe bushings.614.25rwhp/566.82rwtq on 8# of boost.
2012 Chevrolet Silverado 1500 EX.Cab 4X4 Z71.
papabearcamaro is offline   Reply With Quote
Old 04-14-2011, 06:57 AM   #7
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
If you can afford it..cat back
Axle back is for sound improvement. I couldn't afford the cat back right off the bat when I bought this car. However, I NEEDED! a sound improvement from the weak stock system. Later, you can always get the xpipe...
Cat back won't give you a lot of gains over axle back..the stock H pipe was done rather well. However, I believe the catback will set you up better for additional mods down the road such as CAI and Headers..
As stated if you can afford it..go for it. If you only want sound and don't see yourself doing any other mods..axle back.
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 04-14-2011, 07:16 AM   #8
HP Addicts
Drives: N/A
If your just looking to improve the exhaust note I would go with an axle-back system. If you want the most performance and might upgrade your headers down the road then you may want to go with a cat-back system.
HP Addicts is offline   Reply With Quote
Stainless Works Retro Chambered Cat Back At Apex Motorsports!!! Apex Motorsports V8 Bolt-Ons & Tunes 409 02-12-2013 08:04 PM
NEW GROUP BUY- Solo Performance Axle Back with J pipes & Mach XL (L99) with J Pipes GOINGSOLO2 V8 Bolt-Ons & Tunes 130 12-20-2011 07:15 PM
Palm Beach County(GMPP AXLE BACK) Ohten USA - Southeast 1 01-23-2011 01:36 PM
Does an axle back have the same problems as a cat back? G.E. Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 09-15-2009 03:31 PM
Cat back or axle back? norcalwheelman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 07-22-2009 08:15 AM
