![]() Drives: 2011 Camaro 2SS/RS Join Date: Feb 2011
Subframe Bushing Inserts - BMR, Pedders, Prothane, Energy, etc.???
Anybody out there have personal experience with either the Prothane or Energy Suspension polyurethane cradle to subframe bushings? I really want to eliminate the rear suspension movement on my 2011 SS and believe this is the best first step from what I've read. After the bushings I intend to replace the trailing arms, toe links and rear sway bar. My question is which bushings should I go with? From a pricing standpoint I have seen prices from a low of $120 for the Energy Suspension bushings to a high of $265 for the Pedder's version with the others falling in between for what look to be essentially the same product. Does anyone know what the differences are? On a daily driver with the occassional autoX or track day, does it really matter? I've always been a firm believer in "you get what you pay for" but in this particular situation with a price spread of more than a 100%, I'm just not sure which way to go. Any personal experiences and/or advice would be much appreciated. Thanks
#2 | ||
![]() ![]() ![]() Drives: none Join Date: Oct 2009
We have and sell the energy suspension bushings. we have had them on the car for over a year with no problems.
This link is whet we were doing with them last weekend. http://www.camaro5.com/forums/showthread.php?t=140415 some more things we were doing with them. They seem to be working. They are not harsh or noisy. |
Got pedders xa drag pack which is full bushings and coilovers. Absolutely love them. Would recommend them to all.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
Are you trying to get rid of wheel hop? If so, I would do trailing arms first. When I first took my car to the track I got tons of hop. I then put on som TA and it all went away on the line. I still get an occassional hop from 2nd to 3rd but I'm going to address that with the Hotchkis chassis brace or some craddle inserts.
For inserts I've been looking at BMR but I probably should look at Energy as well.
Build Journal ![]() |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2009 ZR1 Join Date: May 2010
I've got the energy suspension full bushings. I am quite pleased with them.
#6 |
"Camaro Joe"
not only do i sell pedders i use pedders and the products are second to none
#7 | |
Drives: 2010 1SS Join Date: Jan 2010
Additionally we manufacture the other suspension components you are already planning to upgrade. Sometimes it pays to stick with one brand for everything as it has been designed and tested together not only for compatability but for functionality to compliment each other. In the end you can't really go wrong with any of these companies but I just felt it was necesarry to explain what the differences were and why we are not necesarrily the lowest price in the market... |
#8 |
I went with the BMR inserts instead of replacing the entire bushing. Very satisfied with the inserts ability to control the motion of the rear cradle and not transmit additional NVH to the cabin. Easier to install ( cradle still needs to be dropped down a few inches ) and less costly. For my 99% street use and 1% road course / autocross use the inserts were the right modification for me.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
#9 |
Supercharged LSX
Drives: 2011 2SS/RS Black/Carbon Fiber Join Date: Dec 2010
I got Pedders ones and I'm very happy. Worked very well at C5F2. The car never felt better on the track. There is some noise and vibrations, but worth it to me. Driving on the freeway and changing lanes has a positive feel.
#10 | |
![]() Drives: 2010 Camaro SS Join Date: Oct 2010
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete Roto-Fab Intake Stainless Works 1 7/8" Long Tube Headers Corsa Exhaust |
#11 |
Quit being a pu$$y
Bushings are a huge pain, so I did it once and did it right. I got BMR's full line of bushings and suspension components. Like they said, they are all designed to work perfect together and it shows. Plus their customer service is second to none. They have also been around for a long time.
#12 |
Thanks flht99b, Agent WD-40, and SUX2BU for posting your experiences!
#13 |
Drives: 2010 SS with WAY TOO MANY MODS Join Date: Sep 2010
Just a quick question....... if price isn't the deciding factor, why not go solid? I think the science has proven that the solid bushings ALWAYS outperform any urethane counterpart with littel actual increase in NVH. On ALL of our drag, road race, auto x, and street cars, even our own Camaros, we have run the solid mounts from Pfadt with incredible results.
PM me if you have any questions. We set up (installs, laser alignments, and corner scaling) about 4 to 5 Camaros per week with different suspension options depending on the specific customers needs. |
#14 | |
Ed M.
| Tags |
| bushings, subframe connectors chassis, wheel hop |
| 5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 06:52 PM |
| Subframe Bush Upgrades. From Simple DIYer to Full Race Capable | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 16 | 05-03-2010 10:29 PM |
| New to Suspension (look over list please) | Brokenlizrd | Suspension / Brakes / Chassis | 19 | 04-24-2010 12:31 AM |
| Pedders Suspension Benchmark Track Testing and New Jersey Track Day | Info@PeddersUSA.com | USA - NY / NJ / PA | 35 | 10-26-2009 06:20 PM |
