Old 04-19-2011, 10:45 AM   #1
mikester0612
Camaro 5 Muscle
mikester0612's Avatar
Drives: 2010 CGM 2SS/RS L99
USB port not working...
When I plug in my USB cable to my iPod, it wont read the iPod. I tried to wiggle it once and it picked it up, but then when I let go, it lost it. I have been using it for 6 months or so and this happens. Any suggestions?
TSW Donington 22" Matte Black / Corsa Cat-Back Exhaust / Kooks Signature Stepped Headers 1 3/4" - 1 7/8" / High Flow Cats / Custom Tune / CAI Cold Air Intake / BMR 1" Lowering Springs / VMax Ported Throttle Body / Heritage Grill / Havoc Rear Diffuser
mikester0612 is offline   Reply With Quote
Old 04-19-2011, 10:52 AM   #2
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
I'd try a different cable, or different ipod. Try the cable & ipod on your computer and see if it works. If it turns out to be your car's usb port, it should be covered under the warrantee.
Tori
Old 04-19-2011, 10:55 AM   #3
mikester0612
Camaro 5 Muscle
Thanks. I have another cable and iPod here. I will try it now.
Old 04-19-2011, 10:56 AM   #4
66olds442
Born Olds, Living Chevy
66olds442's Avatar
Drives: 2011 2SS/RS: VR A6
Sometimes when I start up my car it won't recognize the USB port or the Aux. port. If it doesn't recognize your aux. port also, it's most likely the car.
66olds442 is offline   Reply With Quote
Old 04-19-2011, 11:29 AM   #5
Transformed
Roxy
Transformed's Avatar
Drives: 2012 Red Camaro 2SS RS
Every once in a while mine does that - I have no idea why. I usually unplug/plug it back in and turn the Ipod off and on. So far, that has always made it work.
Transformed is offline   Reply With Quote
Old 04-19-2011, 12:59 PM   #6
Sasquatch
C5 THAKILYETI
Sasquatch's Avatar
Drives: 2LTRS
the software can be fickle, but once you learn it's behavior (intended and not) you should be fine.
this sounds like a shorted ipod cable, happens quite frequently. your ipod is probably fine unless you pull and put pressure on the cable while plugged in.
Sasquatch is offline   Reply With Quote
Old 04-19-2011, 01:03 PM   #7
Rip
Drives: 2011 SS/RS
Happens all the time with the iPod touch and the iPhone. Unplugging it and plugging it back once or twice should be enough to "fix" it. If not, then it's probably the cable. Even if it is the cable, if you have either of the above products it will probably happen on occasion.
Rip is offline   Reply With Quote
Old 04-19-2011, 02:09 PM   #8
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
Mine has never worked.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
Old 04-20-2011, 04:16 PM   #9
Chevrolet Customer Svc
Drives: GM Vehicles
mikester0612, if these suggestion do not do the trick for you then I would suggest that you let your dealership take a look at as there might possibly be an issue with the vehicle. Hopefully this is not the case and you are able to get this feature running again yourself. I hope all of the suggestions given do a good bit of help towards resolving your issue. If the issue continues feel free to contact me.
Jeff Morris, Chevrolet Customer Service
Old 04-21-2011, 10:43 PM   #10
Jmiller
Jmiller's Avatar
Drives: 2013 Camaro 2SS 1LE
Software update
Hey guys,
I was having trouble playing me 3rd generation Iphone, and ipod touch in the camaro. I took it to the dealer and they told me their was a software update for the USB. After the software update my Iphone and Ipod touch worked flawlessly. This could be the problem.
Jmiller is offline   Reply With Quote
Old 04-21-2011, 10:45 PM   #11
Devon
Highway Man
Devon's Avatar
Drives: '10 2SS/RS
I have just tarted having this problem as well. I have tried two different ipods (one a "classic" and the other is a new mini touch) both with two different connector cords. Plugging them in and unplugging them repeatedly does nothing, nor does shutting the car off and turning it back on. I'll be getting in contact with my dealer shortly about it, but in the mean time was hoping there was something that anybody else here knows that can be done about it or if there is a fix/TSB in the works for this problem??
Devon is offline   Reply With Quote
Old 04-21-2011, 10:46 PM   #12
Devon
Highway Man
Devon's Avatar
Drives: '10 2SS/RS
Originally Posted by Jmiller View Post
Hey guys,
...As I was typing. Nice. Did they give you a bulletin # or anything like that?
Old 04-22-2011, 04:59 PM   #13
Jmiller
Jmiller's Avatar
They might have, but i am not sure. Just make sure you have the latest version update on your ipod, or iphone and take your car to the dealer. Tell them the problem you are having, and they will peform a usb update, which should fix the problem. All of this is under warranty.
Old 04-22-2011, 06:11 PM   #14
Drago77
Treasure Coast Camaro 5
Drago77's Avatar
Drives: 19 2SS vert, Mosaic Blk, A10
I have issues with it recognizing my Droid X as well... sometimes it.does, sometimes it.doesn't. Real pain in the ass... was thinking about buying a USB drive dedicated soley to.music and leaving it in there.
Drago77 is offline   Reply With Quote
Problem with iPod working through USB Port TexasTechZ06 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 10 08-09-2011 01:43 PM
USB Port problem w/ Ipod touch Arsenal11 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 8 06-03-2011 07:42 PM
Had a great idea!....but didnt work :( CamaroC-17 5th Gen Camaro SS LS LT General Discussions 13 01-10-2011 09:27 AM
My USB & Blue tooth is not working Help :( dxy2jbaby Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 12-09-2010 12:12 PM
Does the USB port charge the iPod ICEMAN 316 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 08-31-2010 12:28 AM
