Old 04-19-2011, 02:43 PM   #1
ArmoSS
ArmoSS's Avatar
Drives: 2011 Camaro SS
Headers and Tune??
I live in CA and have been hesistant on getting headers due to emissions, etc. But, I figured i don't need a smog check for a while, so screw it!
Question: If I get headers, do I need a tune? I don't want to void my warranty, and have extended warranty on my car as well, so I don't want to screw either up.
Will I gain much if I get headers without a tune? Is there a big difference between short tube and LT headers?
Any assistance here is much appreciated.
ArmoSS is offline   Reply With Quote
Old 04-19-2011, 03:28 PM   #2
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Nothing wrong with long tubes and no tune, you will have a cel and that would need a tune to turn off. As far as warrent goes, the tune will kill it so dont tune it. What you could do is deal with the cel and have your headers... then when its emission's time swap your manifolds and cats back on to take the test. Figuring its only 1 time every 2 years and its not that bad of a job! I am doing long tubes this weekend and not getting a tune untill I get a cam... after the cam warrenty is no go anyway
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 04-19-2011, 03:30 PM   #3
Bad70supreme
I would forget the shortys, you could always get high flow cats but I heard that sometimes throws a cel too!
Old 04-19-2011, 03:42 PM   #4
Bay Area SS
Bay Area SS's Avatar
Drives: 2010 rs/2ss
Long tubes are definetley going to throw a code, and you will need to tune it out. Plus if you dont tune it after the install its more than likely going to run lean and not run correct. My buddy just installed long tubes on his SS. Threw a code and was running poor, until he tuned it. Hope this helps. If I was going to long tubes, which I would like to, its gettin dyno tuned immediately after.
Bay Area SS is offline   Reply With Quote
Old 04-19-2011, 04:37 PM   #5
ArmoSS
ArmoSS's Avatar
Thanks, guys. I've heard both...that there will be a cel and can tune it "out," but also that without a tune the car will not run correctly. That's a bummer, since I definitely wanted to get headers. It seems that without a tune it's just not the same.
Old 04-19-2011, 04:50 PM   #6
Tshepp
Show & Go
Tshepp's Avatar
Drives: '10 Camaro 1SS LS3
I have heard of quite a few people who run headers without a tune for a decent period of time because they only want to tune once...
Tshepp is offline   Reply With Quote
Old 04-19-2011, 04:55 PM   #7
Bad70supreme
I guess I will find out for myself real soon. But my old 4th gens and my brothers 2000 T/A ran fine without a tune and long tubes. He's been running his cur untuned for 3 years now without any problem.
Old 04-19-2011, 05:37 PM   #8
JANNETTYRACING
JANNETTYRACING's Avatar
The Older Computers were a lot more Forgiving.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 04-19-2011, 05:54 PM   #9
ArmoSS
ArmoSS's Avatar
Ted.
Ted, then you would agree that there's no point in getting LT headers without a tune? Stick to only CAI and exhaust if worried about warranty?
Old 04-19-2011, 11:10 PM   #10
Josh@ARH
Drives: 2013 Corvette GS
I know members on here have ran 02 sims or spacers to keep the car from throwing a CEL, so that could be a viable option for you. Also you will see quite a bit more power with LT's than shortys.
Josh@ARH is offline   Reply With Quote
Old 04-19-2011, 11:17 PM   #11
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
I had JDP Motorsports throw on KOOKS LT headers and a tune before the fest. Greatest thing I've ever done to this car!!!
JUST DO IT!!!
Old 04-20-2011, 08:09 AM   #12
JANNETTYRACING
Agreed.
Old 04-20-2011, 08:38 AM   #13
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
I live in california too. You dont have to smog your car for the first 5 years. Im not worried that i voided my powertrain warranty when I had Ted tune my car. My car isnt a drag race car. I drive it "spirited" at most to say the least and have taken it to the track only twice. So with that said, my car just barely hit 20,000 miles yesterday and the only powertrain issue i had was a bolt coming off the driveshaft which the dealer was quick to identify and gave me my car back in 2 days.(the repair only took about an hour but they didnt have the bolt which came as a complete set which they had to order from back east. They even repaired it even after i told my service advisor not to flash the computer whatsoever noting that it had custom calibration) I guess what im trying to say is that i took a chance based on confidence that chevy built me a good car that as long as i didnt abuse it, i couldnt break it. I figured if i paid $45K for the car (i bought the car in 2009 when every dealer was marking them up) and the 2005 Tahoe that I traded in for her never gave me ANY problem whatsoever, there was no reason to believe the camaro would be any different.
I understand how you feel about your warranty. My advice is to enjoy your car. If you want LTs, get them and do it right by tuning the car. As long as you dont abuse the car, it is VERY unlikely that you will break something that you couldnt afford to replace on your own. Chevy took their time on this car. Its built well and LS engines havent been under hoods since 1997 because they arent built well. As far as the smog goes, keep the factory cats and manifolds stored somewhere and swap them back in when you have to smog it. It is very easy to swap back and forth between headers and manifolds. Talk to Ted or any of the other vendors here. Ive only dealt with Ted but I have seen all other vendors in the forums and they have all been very helpful with everyone (customers AND non-customers alike) Ted or anyone of them can set you up and recommend a good set of affordable headers. You'll love them once you install them. Im sure i speak for everyone here that already has them
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 04-20-2011, 09:52 AM   #14
c-dub
It's that guy
c-dub's Avatar
Drives: 2011 SIM SS/RS
Thumbs up
that right there was a very sound and well put together arguement. I want LT's really bad, but I am afraid of voiding the warranty. THis makes a ton of sense though. If I can find a way to lower my payments I'd be all about it, but as it stands right now I pay more per month due to the warranty and I doubt me voiding it would lower my payments...so as long as I am paying I might as well keep it right? Anybody know of a way to kill the warranty on paper?
We mortals are but shadows and dust.
c-dub is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Another L99 Dyno tune (with headers and CAI) pcmforless Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 31 02-26-2011 07:36 AM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
