Factory size rear wheels
If anyone locally has a set of factory size rear wheels available PM me.
I just need a set for my drag radials. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
Discount Tire has a replica wheel. I think they are around the $180 range.
Also, look on eBay. When I was looking for a set I found some on there for a decent price. I ended up getting mine from ADM....he happened to have a set of rear polished for the right price and I was able to drive 15 min to go get them. If you don't have your drag radials already you might consider buying the 18" corvette wheels and Nitto radials. I was quoted around $850 from Discount Tire for the C6 replica wheels and a set of Nitto NT05 mounted and balanced out the door. The larger side wall will help you hook better.
Build Journal ![]() |
![]() Drives: 2011 Synergy Green 2SS/RS Join Date: Jan 2011
check out craigslist, that's all i've seen on there lately.
| Poll -- Camaro vs Mustang Supercar Shootout | JusticePete | Suspension / Brakes / Chassis | 105 | 10-09-2013 03:18 PM |
| Rear 20" wheels | rforbes | Wheels / Tires | 4 | 05-11-2011 02:16 PM |
| aftermarket wheels using factory tires and TPIs | GB EB | Wheels and Tires Talk Sponsored by The Tire Rack | 1 | 09-08-2010 02:16 AM |
| Factory Rear ground effects | Sully | Cosmetics and Lighting Modification Discussions | 10 | 05-15-2010 12:52 AM |
| Drag Racing Suspension Kits | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 02-21-2010 09:48 PM |
