Old 04-20-2011, 07:39 PM   #1
GNVenom
Turbos. Turbos. Turbos.
GNVenom's Avatar
Drives: 2010 SS Yellow/Black
You DON'T want to lose your key!
What a hassle!
A word to the wise: Do not leave both sets of keys where they can be lost or stolen. Don't ask me how I know...
Anyway, you can't just go and purchase a replacement key and fob. The key is cut by a special GM facility, and the remote fob is programmed at the dealer, hooked up to a computer on-line, and takes about an hour to program each fob. You can't do it with the TEC II or by the conventional means of plugging the key in the ignition and proceeding with the routine.
And, it'll cost you - hundreds. I had my Camaro flat-bedded to the dealer yesterday, and it takes several days to get the keys.
Sooooo, if you have a spare, put it in a SAFE place, which is a different safe place that the first set resides.
And, if you're inclined to get a spare key, be prepared for a long drawn-out procedure. HINT: Order a spare key from your GM dealer NOW - you'll need to show proof of ownership. Then once you have it, wait until your car goes to the dealer for warranty or service, and have them program it while it's there.
Then PUT IT AWAY.
John Spina
Caspers Electronics Inc.
Loveland CO
2010 2SS/RS Yellow/Black > http://www.bummlbe.com
GNVenom is offline   Reply With Quote
Old 04-20-2011, 07:43 PM   #2
1BADLS3
1BADLS3's Avatar
Drives: Sold: 2011 2SS/RS
I think the key here is that you need both sets to cheaply/easily get a 3rd key.
If you have none, or one, you're pretty much screwed because the VATS/security system needs to read the other fobs that have been programmed into the computer as well. It takes a trip to the dealer to program out the other codes and then set up new primary/secondary codes.
At least that's the way it works with my Jeep.
1BADLS3 is offline   Reply With Quote
Old 04-20-2011, 07:53 PM   #3
austinjames
Account Suspend...Right
austinjames's Avatar
Drives: Synergy LS & Vulcan 1600cc
thanks for that info, great idea.
austinjames is offline   Reply With Quote
Old 04-20-2011, 07:54 PM   #4
GNVenom
GNVenom's Avatar
Apparently starting with the 2010's, GM has stepped up security and made it very difficult to for a would-be thief to scam a working key. Necessary steps mean it's going to be a hassle.
I had the car locked in my garage, so I ordered a replacement key/fob Had to go to the dealer to do it, show ID, and so on. Got it three days later, opened the car door, and swiftly set off the anti-theft horn-beeping routine. That's the best I could do. Got it out of gear, rolled it into the driveway and called Roadside Assistance, who summoned a flat bed tow truck to the house, and brought it to the awaiting Chevy dealer.
By the end of the week, I'll have my car back with two new keys/fobs. Don't know the cost yet, but I think it cost $130 to program the fob. Add to that the cost of key cutting and new fob. X2. Ouch!
John Spina
Loveland CO
Old 04-20-2011, 07:56 PM   #5
GNVenom
GNVenom's Avatar
Originally Posted by Comrando View Post
Wrong! That doesn't apply to our GEN 5 Camaros. It works on the standard chip key only. That procedure worked on my 2009 Traverse.
Switchblade fobs are completely different.
John Spina
Loveland CO
Old 04-20-2011, 08:00 PM   #6
Riddikulus5Gen
Riddikulus5Gen's Avatar
Drives: 2010 ABM RS 2LT
I just went through the joys of prorgramming or 'adding' a new key to my car, and
the thing that took the longest was waiting for the new one the dealer had ordered to come in.
From day ordered, took over a week, I think about 8 business days to be delivered.
Luckily, mine was used, (that's the ONLY reason I say those words in the same sentence), but the car was turned in with 1 key already, so that one worked, and the new key was just going to be a back-up anyways.
So, anywho, since my dealer is from across country, the car made it home
before the spare key did, and that means, I had to go get the new key programmed at a dealer out here. (And to add to the process, a week or so later, the original owner found the spare key that came with the car), so now, I have a total of 3 keys, and that means, that either: all 3 need to now be reprogrammed, OR (once I was in the shop at the dealership), you could choose to "add" a key instead of reprogramming all 3.
So, from start of plugging the car into the computer, to finish, the process of adding the 3rd key took about 20 minutes? maybe 30 at most? It runs through this process that sets a timer for at least 15 minutes while the car and computer sync up and do their thing, and then you go through with all the keys and test them out, making sure they do what they are supposed to do, then voila!
All done.
granted, 72$ later, (Thank goodness my dealer in NC fronted the bill. *THANKS GUYS @ BIGGS CADILLAC!*) I was finally finished with the ordeal.
So lesson is, yes, can be a bit of a pain to obtain and program a new set of keys,
so BE CAREFUL and SMART and store one away in a safe place that YOU WON'T FORGET! haha, and keep the one you use attached to something that is easy
to keep tabs on as well.
good luck!
I GOT MY CAMARO FOR MY SIG.!!!! AT LAST!!!
Built: October 2010 / ABM Chevy Camaro RS 2LT
Grey/Ebony Leather Interior / 6-Speed Manual Trans.
Gauge Cluster / Silver Rally Stripes (May remove?)
20" Polished Aluminum Rims.
K&N Cold-Air Intake / Corsa Exhaust.
Riddikulus5Gen is offline   Reply With Quote
Old 04-20-2011, 08:20 PM   #7
Sunlover
Sunlover's Avatar
Drives: 2011 Camaro 1LT/RS
A few weeks after we got the new car, I decided we should have a 3rd key, so I went to the parts department, and they ordered me one, pre-cut based on our VIN#. It cost in the neighborhood of $55. It took about a week or so to arrive. When it came in, I took both our existing keys in, cause I knew from past experience how much of a hassle it usually has been to re-program fobs when you get a new one. The service managers hadn't done one yet, so they looked up some info, started the car with one of the existing keys, then with the new key, and that was it. He had no idea it would be that easy, and I CERTAINLY didn't. All three work just fine, and I wouldn't have even needed to take the other original key in, as it turns out. They didn't charge me anything, except for the key (given the ease of things, makes sense).
Sunlover is offline   Reply With Quote
FINAL Production 2010/2009 Camaro! (PICS) rray200 Camaro Photos | Spyshots | Video | Media Gallery 799 05-20-2011 12:48 AM
Camaro info from GM dahulk 5th Gen Camaro SS LS LT General Discussions 5 03-01-2011 11:39 AM
Re-key car? skraemer 5th Gen Camaro SS LS LT General Discussions 30 02-17-2011 10:07 AM
Problem with Key Fob anyone? ffrcobra_65 5th Gen Camaro SS LS LT General Discussions 8 12-12-2009 02:45 PM
Can YOUR key, open MY car?!?! Mr. Wyndham General Automotive + Other Cars Discussion 11 11-13-2007 08:44 AM
