Old 04-21-2011, 02:51 PM   #1
Dosin
Dosin's Avatar
Drives: 2010 2SS RS black ground effects
High flow Converter question?
I have a 2010 L99 with catback MBRP 3 inch exhaust. I tried doing some research about high flow catalytic converters. I don't know much about them and need "schooling" on them. The whole point of me wanting them is to make my car a bit louder. I don't want headers because I don't want to void the warranty. Any suggested threads for me to read? Will high flow converters make much difference on sound or is it a waste of money? Thanks for the help.
Dosin is offline   Reply With Quote
Old 04-21-2011, 03:01 PM   #2
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
High flow cats won't make that much of a difference in the sound. You already modified the exhaust system..so if the dealer wanted to be a di** about, if there was a problem exhaust related they could still void you on that anyway.
They have to prove the aftermarket part contributed to the problem in question.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 04-21-2011, 03:44 PM   #3
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
I guess you have a point but my dealer told me a cat back system was fine just don't touch the cats or exhaust manifolds to keep my warranty.
Pollock is offline   Reply With Quote
Old 04-21-2011, 05:56 PM   #4
HulkSS
Drives: 2011 RS/SS SGM
My dealer told me I was fine as long as I didn't touch the computer, i.e. tune, thats why I went with cats instead of long tubes. My car was quite a bit louder with the cats, I have the SOLO ones. Still on stock cat back until tommorow when my flowmaster gets here.
HulkSS is offline   Reply With Quote
Old 04-21-2011, 10:54 PM   #5
Dosin
Dosin's Avatar
This is my problem. One person tells me it won't make much of a difference and the next person tells me it is quite a bit louder. I would not be interested unless it did make a noticeable difference in sound. Maybe I should have done a muffler delete. Oh well. 1k exhaust already installed.
Old 04-22-2011, 02:36 AM   #6
blk96gt
Drives: 11 SS(sold),96 Mustang,12 Silverado
I don't know why lexlueger said it won't make a difference in sound. Mine was a good bit louder after I added my Solo hi-flo cats.
blk96gt is offline   Reply With Quote
Old 04-22-2011, 03:06 AM   #7
Mud
In Mud We Trust
Mud's Avatar
Drives: 2010 Camaro 2SS/RS LS3
Just being louder does not always make for a good tone. It is the quality and tone of the exhaust that one needs to look for. For the street anyway.
I can see your frustration. I listened to a lot of different combinations at Camarofest. So I'm starting with some SLP II's and after that, I'm thinking about some long tube headers.
Good luck with your cats.
2010 2SS/RS, LS3
-Hurst Shifter
-American Racing Torq Thrust/Anthracite
-CAI Intake
Mud is offline   Reply With Quote
Old 04-22-2011, 08:05 PM   #8
blk96gt
I should have said that other than making it louder it greatly improved the tone. Even my wife thought it sounded much better without making it obnoxiously loud.
Old 04-22-2011, 08:38 PM   #9
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
high flow cats =louder exhaust plus about 15hp.....solo did a dyno test when theres came out
bmbbl be is offline   Reply With Quote
Old 04-22-2011, 08:51 PM   #10
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Mine is noticebly different sound, hard to say louder or not. I gained 2mph in the 1/4-mile, which equates to about 20hp.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 04-22-2011, 09:00 PM   #11
AzTeK
AzTeK's Avatar
Drives: 2011 Camaro SS
High flow cats do make the car a bit louder on idle and when you rev it i would say about 5x louder then stock plus good performance wise as well. JBA or SOLO are both great.
AzTeK is offline   Reply With Quote
Old 04-22-2011, 09:46 PM   #12
1FAST SS
1FAST SS's Avatar
I have a set of DT headers and a borla s-type catback ordered, but haven't made up my mind on which hi flow cats to order. Either Solo or JBA, but really don't know if Solo is $200 better than JBA. Anyone have any bad experinces with the JBA hi flow cats?
2011 Camaro SS Synergy Green
CAI Cold Air Induction, ADM Race Scoop, Apex Washer Bottle Kit, Vengeance Racing Kaotic Cam, DOD/VVT delete and LS3 conversion, American Racing LT Headers, American Racing Headers Off Road pipes, Borla S-Type Catback, FTI Billet Triple Disk 3600 rpm Torque Converter, DSS Aluminium Drive Shaft, AAC Plasma DRL's, Showstopper LED Sidemarkers,Carbon FIber Bow Ties, 35% Window Tint, Llyod's Floor Mats, JBL MS-8 Sound Processor, 2 Alpine PDX-1.600, Alpine PDX-4.100, JL Audio C5-650, JL Audio C5-650x, Alpine T10 Type R Shallow Mount, Stinger Dry Cell Battery
1FAST SS is offline   Reply With Quote
Old 04-22-2011, 10:05 PM   #13
Padre
Padre's Avatar
Mine are JBA. 2mph in the 1/4 and about 0.15 ET gain. Worth it, in my book. I'll be adding the JBA shorties next to see if that makes a difference.
Padre
Old 04-23-2011, 07:28 AM   #14
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
Me and a friend have the exact same car's, L99's. We both put MBRP catback 3" only at first but he ended up puting high flow cats and his car is quite a bit louder than mine and has a deeper tone !
KARBON is offline   Reply With Quote
FTI/RX Billet Torque Converter special!! SC2150 Transmission / Driveline 122 07-23-2013 06:19 PM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 04:34 AM
High Flow Cats Question? erk5000 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 03-07-2011 10:57 PM
Brand New Solo High Flow Cats for LS3 ddavis V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 14 08-10-2010 10:23 PM
ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL ADKINS PERFORMANCE Suspension / Chassis / Brakes 0 08-03-2010 12:08 PM
