Old 04-23-2011, 01:16 PM   #1
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
razzi diffuser bolt brace
bolt is epoxy on inside of diffuser, do not drill thru diffuser, it will weaken it...there is threaded bolt protruding from trunk bottom...someone wanted some pics..
mikepage0007 is offline   Reply With Quote
Old 04-23-2011, 01:19 PM   #2
mikepage0007
Drives: 2010 camaro
last pic
Old 04-23-2011, 01:33 PM   #3
mikepage0007
Drives: 2010 camaro
use flat style bolt for epoxy to diffuser
Old 04-23-2011, 06:26 PM   #4
Michaels2011
Michaels2011's Avatar
Drives: 2014 2lt/RS
Thanks. Was wondering how I was going to strenghten this area. What type of support bracket did you use?
Michaels2011 is offline   Reply With Quote
Old 04-23-2011, 08:45 PM   #5
mikepage0007
Drives: 2010 camaro
bought 2 18 inch roof truss braces from home depot for 3.00..used one to mock up and get proper bend and angles, the drilled hole..then took 2nd one , and bent same as my mock one , drilled holes and painted black...you could get more refined, but its just a simple brace that was cheap -does the job and can,t be seen
Old 04-23-2011, 10:06 PM   #6
Cabrera
Freightrain Coming Ur Way
Cabrera's Avatar
Drives: V8-1968 & V6-2000 & V6 2010 Camaros
what are thiese pics a mod of? and what epoxy did u use?
Do you serve a purpose, or purposely serve?
Cabrera is offline   Reply With Quote
Old 04-24-2011, 02:46 AM   #7
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Thanks Mike, I was hoping you would post the DIY!
CAMARO
Old 04-24-2011, 09:11 AM   #8
mikepage0007
Drives: 2010 camaro
it is a razzi gfx kit rear diffusser...shows where to epoxy bolt to inside rear diffusser to stregthen it in the center..used a 2 part epoxy from hd for all purpose...the razzi kit comes with a tube of epoxy that would also prob be good to use..
Old 04-24-2011, 02:02 PM   #9
tmac1granger33
NM HT5
Drives: COTW 3/5/12
cool my rear has held up on the freeway pretty good without a brace.. the dealership used some other adhesive though.... if it starts to bend ill do this
tmac1granger33 is offline   Reply With Quote
Old 04-24-2011, 03:39 PM   #10
mikepage0007
Drives: 2010 camaro
well i saw some diffusers and the wind really has them moving around in the center..i run @ track and figured 120mph can,t be good for no center support...so for a 3.00 mod , seemed to be worth it..the razzi is def center heavy with no center support..also mentioned in earlier dyi , do not use the screws, use aluminum rivets, will not rust nor work themselves out over time
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 07:53 PM
PWA "The Lounge" PART 2 MarkLS2 Off-topic Discussions 111159 01-14-2012 04:25 PM
WTT Razzi V8 rear diffuser for GFX rear diffuser painted SA CHEVY Local Marketplace 12 03-06-2011 02:09 PM
Razzi Rear Diffuser for sale joeblow Local Marketplace 7 01-25-2011 02:33 PM
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 12:00 PM
