Old 04-23-2011, 02:45 PM   #1
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
Lightbulb 19" Wheel Experts, Advice
Hi guys,
For a while now, exactly one year, I have been researching the best possible wheel and tire combination. I have a 1LT, with stock 18" wheels. I would like to upgrade to 19". I've thought of 20's for the longest time, but I do not want to sacrifice too much performance. Also, due to the single piston disc brakes, I also dont want too much space between the wheels and the calipers.
To this, I believe 19" might be perfect for my tastes. However, I would like to ask you all to give me some advice. Believe me, I'm taking all the advice dished out to me right now. What kind of tire combination should I get?
So far, I've been thinking of the TSW Nurburgrings, 19x9 F, 19x10.5 R. The bad thing is... there isn't too much selection for tires at the size I want.
So brands, and tires that I may have overlooked, please help out =D. IF there really is no hope.. then I might go to 20s.
jagan323 is offline   Reply With Quote
Old 04-23-2011, 07:30 PM   #2
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
19s and 21s are the bastard sizes for the tire industry. A good quality lightweight 20 could even weigh less than a cheap cast 19. Don't just base weight on diameter. We still use the same diameter tire either way, and tires make up the most difference in weight vs radius from center. I'd call 19s/20s a wash performance-wise, unless you also run shorter (lighter) tires on the 19s.
Fquick.com/NineBall
Old 04-23-2011, 07:35 PM   #3
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
I would agree with Nine Ball. The higher odd number increments don't seem as popular and hence less selection and maybe no break in price.
Old 04-24-2011, 01:01 AM   #4
Speed Depot
Speed Depot's Avatar
Drives: 2010 Camaro
Send a message via AIM to Speed Depot
Originally Posted by jagan323 View Post
Hi guys,
18" or 22" are your best options for tires. Besides, the TSW Nurburgrings in the 19x10.5 are only available with a +25 offset and they will stick out past your fenders. I recommend that you with 20" (20x9.0 and 20x10.0) Nurburgring or Interlagos wheels. The rears are only 25 lbs and lighter than most 19" cast wheels.
Speed Depot is offline   Reply With Quote
Old 04-24-2011, 01:17 AM   #5
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Hey man I have a 1LT also with the 18's (had bought the RS package separate but sold the wheels at first) and had this same issue. I researched all kinds of combos. But at the end settled for the good old RS 20's again! They just look good overall and perform great. Plus bought them from a member for $700! Just saying something simple is better. I agree with the trouble you will have with the 19's in the long run.
Can't_C_Me is offline   Reply With Quote
Old 04-24-2011, 04:11 PM   #6
jagan323
I have no life
jagan323's Avatar
Thank you wheel experts! I think I will go with the 20's then. After pm'ing one of the members on this board, running same wheels I want, 20x10, 20x9, 275/30 and 255/35. He got me to reconsider going to 20s. He says they are 1" shorter in overall diameter as the SS wheels. 50 lbs lighter than stock wheels in total. Which is good enough for me.
However, I might be going for something more agressive, 295-305 rears and 275 front. What should my profile be? Still 35 front 30 back? Then I'd imagine I'd be bigger in diameter again right?
Old 04-24-2011, 08:20 PM   #7
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
Try this to play around with the various sizes:
http://www.rimsntires.com/specs.jsp
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Recommended Tire Sizes for 2010 Camaro Nine Ball Wheels and Tires Talk Sponsored by The Tire Rack 367 04-23-2024 11:22 AM
Set of 19" OEM 2LT Painted Aluminum Wheel with stock tires Rtoups Wheels / Tires 9 03-07-2011 04:32 PM
Help please...can't find many 19" wheel tire combos S-eatin-grin Wheels and Tires Talk Sponsored by The Tire Rack 5 12-22-2010 04:42 PM
Cleaning Rims!? Gothedoublee Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 2 11-09-2010 07:24 AM
Looking for one Factory Alum 19" wheel Pizzapatty Wheels / Tires 1 01-29-2010 12:44 AM
