Old 04-24-2011, 09:12 PM   #1
Yellojacket
Yellojacket's Avatar
Drives: 2SS/RS Inferno Orange
Adams & Zaino = :-(
Well I am thinking about getting the adams kit with the PC to remove the swirls in the paint but I also have Zaino as well. I sent an e-mail to Zaino asking if I could use the Adams Swirl & Haze to correct the swirls then use the Zaino over it and here is the response I got from Zaino:
Hello, My question is. I have some more swirl marks than I believe the z5 can handle. I was wondering if I can use Zaino over other products. I want to use the Adams Swirl & Haze remover with a Porter Cable to remove the swirls and then can I apply the Zaino Z2 over that once the paint is corrected without swirls?
No problem..
Zaino must be applied over bare paint.
Zaino will not bond properly when applied over Adams Swirl & Haze removeror any wax or glaze...
So now my second question.....What about using the Adams and the PC to remove the swirls and correct the paint...THEN do a dawn wash and get the Swirl & Haze off the car then go with the Zaino again?????
Because Zaino Show Car Polish is optically perfect (99.9%) The
optimum results are achieved by using over wax free paint.
Just thoroughly wash the painted surface with Dawn before applying Zaino and you'll be fine..
Thank You,
Sal Zaino
Yellojacket is offline   Reply With Quote
Old 04-24-2011, 09:25 PM   #2
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
All I can say is Sal is the man! That guy knows what he is talking about.
Old 04-24-2011, 10:00 PM   #3
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Isn't Zaino not even a true polish? A polish is an abrasive...
If it's not, then it probably is just filling your swirl marks, in which case Adam's Glaze works wonders.
nUcLeArEnVoY is offline   Reply With Quote
Old 04-24-2011, 11:58 PM   #4
2LTRS
Detailing Connoisseur
2LTRS's Avatar
Drives: 2010 Rally Yellow 2LT RS
Sal is a nice guy...
Yes you can use SHR/FMP prior to using Z5 / Z2... Sal also sells a abrasive polish Z-PC i believe. However Adam's does true polishes much better than Zaino.
If you do polish with Adam's then seal with Zaino, make sure you either wipe the car down with Isopropyl Alcohol:Water 1:1, or re-wash with dawn after polishing to remove the light silicones from the paint in the polish. Americana is my grand finale - but to each is their own, and your combo should work fine.
2LTRS is offline   Reply With Quote
Old 04-25-2011, 12:31 PM   #5
lets_go_bills
lets_go_bills's Avatar
Drives: 2011 Camaro 2LT/RS CGM M6
Zaino products are designed to work together much the same way Adams products are designed to work together.
I doubt your car will spontaneously combust should you combine Zaino and Adams. If layers of Z5 doesn't correct your swirls, then you have no choice but to bust out the PC and Adams SSR and SHR.
Try it out, see what it looks like. It's your car, you have to be happy with the results.
With the Zaino, there's a reason Sal tells you to wash your car with Dawn firts. It's to strip any and everything on the car. Zaino goes on bare paint and layers beautifully to provide depth, gloss and durability.
2011 Chevrolet Camaro 2LT/RS Cyber Gray Metallic
lets_go_bills is offline   Reply With Quote
Old 04-25-2011, 06:50 PM   #6
BackinBlackSS/RS
Go Blue!!!!!
You got that right. 14 years of using Zaino and the main reason I will always use it is it's durability. People can talk all they want that their stuff is better.
No way JACK!!
Old 04-25-2011, 07:38 PM   #7
lets_go_bills
No way JACK!!
Yeah bro. Zaino is the bomb.
Old 05-03-2011, 09:10 PM   #8
CloudXTC
Drives: 1LT|RS|SIM|M6|BA Stereo
I've been using Zaino since I got my camaro - still have the products, I don't have to use them alot... thinking of this... i might have to do a detail soon... the stuff might be expired already
1LT | RS | M6 | SIM | BA Stereo
1000 - [07-23-2009] Order Made at dealer
1100 - [08-04-2009] Preliminary order accepted
2000 - [08-25-2009] Accepted by GM
3000 - [09-01-2009] Accepted by production control TPW = 10-05-2009
3300 - [09-28-2009] Scheduled for production
3400 - [10-01-2009] Broadcast - Being Built
3800 - [10-13-2009] Produced - Built- VIN 2G1xxx54917
4200 - [10-19-2009] Shipped
5000 - [10-19-2009] Delivered to the dealer
6000 - [10-20-2009] Delivered to the customer
CloudXTC is offline   Reply With Quote
Old 05-03-2011, 10:23 PM   #9
Uncle Harvey
Uncle Harvey's Avatar
Drives: 2011 2SS RS
Since Adams Swirl and Haze remover is a polish, it should leave very little residue behind. I would think that a wash with dawn would get you back to a clean car without any product on the surface. At that point you should be able to apply whatever brand of wax that you prefer.
Uncle Harvey is offline   Reply With Quote
Old 04-26-2012, 12:42 PM   #10
Zman12
Zman12's Avatar
Drives: 2010 Camaro 2SS
I am in the same boat at OP. just trying to decide best way!
Whipple,custom cam,CAI,Kooks,Pedders and PFADT 626RWHP 549TQ ..
Zman12 is offline   Reply With Quote
Old 04-26-2012, 12:50 PM   #11
XQIZT
Adam's Distributor
Drives: 1988 Base Coupe, 1991 Z28
Both are excellent products, but there is a major difference generally.
Zaino is a layered product that removes the appearance of swirl by filling them in, but they are still there.
Adam's is a truer polish system that removes the swirls from the surface altogether. Then you top with a sealant/glaze/wax.
Use the product that get you the results you are happy with.
XQIZT is offline   Reply With Quote
Old 04-26-2012, 01:03 PM   #12
Zman12
Zman12's Avatar
I think I do understand the differences, and I do for sure want to use Adams to correct the paint, just trying to determine to use Zaino after correction or just go straight to the Adams sealants and waxes. I hate to detail I hope me buying a PC will make it somewhat more enjoyable. Last time I did the whole Zaino process I think I took 10 hrs, my back was killing me!
Old 04-26-2012, 07:22 PM   #13
oachalon
Drives: 2010 Camaro 1SS
I havent had any issues using zaino z2 or z5 overtop of adams swirl and haze and fine machine polish.
oachalon is offline   Reply With Quote
Old 04-26-2012, 07:50 PM   #14
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
It's funny, some of the same guys who tell me I'm wasting my time by doing an IPA wipe between/after polishes because Adam's finishes so clean are in here telling you to be sure to wipe or wash before applying sealant.
There is absolutely no reason why you couldn't use Zaino after polishing with Adam's. As long as you clean the surface properly (which you should be doing even if you use MSS or anything else), you won't hit any problems whatsoever. Where you'd run into snags is using MSS and then trying to do Zaino. But since polishes aren't meant to be left on the paint, whatever sealant you do after that will be touching "bare paint"
[B]
Current Specials at Detailer's Domain DetailersDomain Wash/Wax/Detailing and Cosmetic Maintenance Parts 30 12-21-2011 10:23 PM
Group Buy on Adam's Polishes New Essentials Kit DetailersDomain Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 7 04-02-2011 05:40 PM
Adam's Detail: Polishing C5's rmnc3r's 2SS/RS 2LTRS Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 13 12-11-2010 08:22 PM
Adam's New Flex System: Detailed Chevy Tahoe 2LTRS Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 27 11-22-2010 04:56 PM
another adam's / zaino comparison ace2777 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 1 05-23-2010 04:09 PM
