Old 04-26-2011, 03:33 PM   #1
Joco84
Joco84's Avatar
Drives: 2011 Camaro 2SS/RS
ARH headers and Borla ATAK Catback fitting?
Hi Everyone, I installed a set of headers from ARH (1 7/8" Primaries, 3" Merge Collectors with Cats that narrow down to 2.5") It is basically the Short System that they offer that fits to stock Catback. I replaced my stock catback with the Borla ATAK Catback. The sound is amazing but I am a bit concerned with the fitment.
After I installed everything I noticed that the Borla Catback was sitting lower than the stock one was, therefore I could not put back that black metal frame that has 4 screws that act as a safety in case the catback falls. I initially installed it but it causes a lot of vibration inside of the car.
Has anyone experienced this issue with upgrading the exhaust using this setup or any other catback ?
Thanks,
Joco84 is offline   Reply With Quote
Old 04-26-2011, 04:09 PM   #2
DHSS
DHSS's Avatar
Drives: Empty
You have to loosen the clamps to the axle-back and the connections to the mid pipes and have someone push up (very hard) while you clamp and tighten even thing down. You have to push it back up into the exhaust well to get it to sit right.
DHSS is offline   Reply With Quote
Old 04-26-2011, 06:40 PM   #3
Josh@ARH
Drives: 2013 Corvette GS
Just like DHSS said, usually if you loosen up the connection point of both systems you can push up on them and tighten it back up.
Josh@ARH is offline   Reply With Quote
Old 04-26-2011, 06:43 PM   #4
Jason7
NorCalCamaros.com
Jason7's Avatar
Drives: 2010 2SS White
But won't it rattled against the plate he's talking about or will there be enough clearance?
Jason7 is offline   Reply With Quote
Old 04-26-2011, 09:41 PM   #5
Joco84
Joco84's Avatar
I tried pushing it upward, but I installed it by myself. I will jack the car up again and have someone help me and see where that takes me.
I'll let you know how it goes.
Thanks,
Old 04-27-2011, 04:00 PM   #6
Josh@ARH
It depends on how much room he needs for clearance of the piece. To be honest if the only point of the bracket is to prevent the catback from falling, I wouldn't worry about putting it back on.
Old 04-27-2011, 04:17 PM   #7
Joco84
Joco84's Avatar
Hi Josh,
Thanks for the help, I just talked to Mike and he said I should have gotten some spacers for this bracket with the ARH header kit, I never did so he is shipping them for me. I guess I will try to push them upward as much as I can and see if that gives me enough clearance even with the spacers.
Thanks,
Appreciate the help.
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 591 07-06-2022 09:38 AM
Please help me choose.... sfgiantsfan9 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 11-22-2010 11:34 AM
Borla ATAK catback w/ARH Headers sound clips!!! TornadoSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 09-19-2010 10:10 AM
Which LT headers with the Borla Atak catback? GuidosCamaroSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 06-30-2010 09:36 AM
