Old 04-27-2011, 11:16 AM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
Opinions on a Shift light
Ok....wanted to get some opinions on a shift light. I'm just starting my research on them and alot of the posts are a good 6 months old or more. Looks like there were issues with the Raptor initially but maybe they've fixed them by now.
As of now I'm looking at the Raptor or MSD light. I really like the idea of a launch mode on the Raptor...that's a big selling point for me to help me launch the car more successfully and consistently. So far I can't tell if the MSD has that mode or not. All I saw was that it had 4 shift points.
I would also like to make it to where I could remove the light when I'm not at the track. Do either of these lights have a plug that makes that happen or is it easy enough to add my own plug?
Who is using either of these lights?
How hard was the install (seems like MSD might be easier than Raptor)?
Where are you mounting the light? Any pics you can post?
Where have you found the best price on the light?
I'm not set on any light right now so any other suggestions would be apprciated as well.
Build Journal
Old 04-27-2011, 11:18 AM   #2
Toyaholic
It's a sickness!
Toyaholic's Avatar
Drives: '69 442 Vert
Toyaholic is offline   Reply With Quote
Old 04-27-2011, 11:21 AM   #3
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
I was to understand you can install Heads up Display in the 2010. I have it in my 2011 and your Speed and a tach is displayed right up on the window in front of your eyes. Easy to see. Love it.
Sorry I cant help with your other questions.
Pollock is offline   Reply With Quote
Old 04-27-2011, 11:23 AM   #4
caverman
caverman's Avatar
Yeah but that's at least $600 (if not more) and a good bit of work. On top of that there is no shift light. If I already had HUD it might work well enough but I'm not looking at adding that.
Shift light is more reasonable for my situation.
Build Journal
Old 04-27-2011, 11:28 AM   #5
steeleshark2
steeleshark2's Avatar
Look at the aeroforce gauge. It can monitor a lot and has a feature for it to be like a shiftlight. You can get the guage and gauge pod pretty cheap. It just connects into your OBII port.
Old 04-27-2011, 12:11 PM   #6
Pollock
LT4 M6
Pollock's Avatar
I did not realize it cost that much to add.
2011 LS3 with v1.4 Raptor Shift Light - Anyone have one working? RonBennett 5th Gen Camaro SS LS LT General Discussions 17 01-11-2014 03:40 PM
SHIFT LIGHT THROUGH OBDII CONNECTOR? dcoates Tuning / Diagnostics -- engine and transmission 10 05-29-2010 02:13 PM
raptor shift light info treedoc2000 5th Gen Camaro SS LS LT General Discussions 4 03-21-2010 11:34 PM
How does one install a shift light? Ivas Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 5 12-28-2009 10:11 PM
Anybody get a shift light yet. what brand? mstrfdsstr Dragstrip and Launch Techniques Discussion 2 09-20-2009 07:38 PM
