Old 04-27-2011, 03:58 PM   #1
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
No2 racer guys, I want some info
I have never ran nitrous before, I plan on a full bolt-on h/c setup over the next few years. As far as nitrous... how many of you guys are running it, what setups are you running, what does the full cost for the No2 setup go for and what times are your running? Basicly any No2 guys I want to know your setups!
Also if I did all bolt-ons with a 150 shot and tires what kinda times could I expect.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 04-27-2011, 04:20 PM   #2
Graham@N
Drives: Pontiac Firebird
We have a TON on 5th gens and LSX owners running our system.
I usually recommend our Plate systems. They are application specific with custom made stainless hardlines, specific solenoid mounts, wire extensions harness included. The works.
http://www.nitrousoutlet.com/install...stall.asp?id=9
Here is an install we did.
The cost of putting a package together will really vary on what all you would like out of your system. I am happy to go over some of the additional features to add to the 2010 specific system.
We will work with you to make sure you have a good idea of what your looking at and how to use it. Down to the correct spark plugs.
Graham@N is offline   Reply With Quote
ABL connector info Toasty Camaro DIY & HOW-TO instructions & discussions 11 12-22-2013 11:34 AM
Chemical Guys Rant 2LTRS Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 15 04-30-2010 09:41 AM
Headlight mounting info wylde1 Cosmetics and Lighting Modification Discussions 0 04-06-2010 02:40 PM
Road Trip and a Question For You Guys Seawolf 5th Gen Camaro SS LS LT General Discussions 52 01-05-2010 11:56 PM
What Do You Guys Think? Different look for different models? CoolestCamaro873 5th Gen Camaro SS LS LT General Discussions 8 03-30-2008 02:46 PM
