Old 04-30-2011, 11:05 AM   #1
Camo81
Drives: '10 2SS Ylw RS w/ BlkRallys
Stupid Cold Air Intake Question/Advice Needed
Hey everyone, I'm sure this is sort of a dumb question to most of you, but I recently installed a volant cai on my car, there is a small rubber hose that runs from a port in the engine block into the intake of the cai, I'm not exactly sure what this is for, I assumed it is a bleed off of excess oil??? My problem is this hose comes into contact with my belt, there's a hole in it now, the stock airbox has a metal tube that runs from the port to the intake tube, is there any harm in driving it like this for the time being, has anyone else come across this?
Camo81 is offline   Reply With Quote
Old 04-30-2011, 11:44 AM   #2
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Fresh air hose hose and is part of the PCV system. Your fuel trims will be way off and dirt will get sucked into the engine. I'm not familiar with the Volant, but most aftermarket intake can make use of a 3/8" transmission cooler hose which can be purchased at most autoparts stores.
Do NOT cap off these lines though. $6 in hose and you should be good to go.
IndeedSS1 is offline   Reply With Quote
Old 04-30-2011, 12:07 PM   #3
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
The auto store also sells 90 degree elbows as a general use multipurpose type of thing. Maybe you could use those to redirect your hose out of harms way.
Pollock is offline   Reply With Quote
Old 04-30-2011, 12:17 PM   #4
Nomad
Nomad's Avatar
Drives: '11 2SS/RS RJT M6
Post up a pic of the set up and where the hole was made and we can help you come up with a solution.
Vararam CAI, Elite Engineering Catch Can, Separate Clutch Fluid Reservoir, Ghost Armor Full Protection Package, Chromed Turn Signal Bulbs, RPI Stealth Splash Guards, Skip Shift Eliminator, Defenderworx Chrome Bowtie Inserts, Pfadt Trailing Arms, Camaro Decal Store CGM Hood Spears with "376ci" custom text, Billet Depot/Drake Underhood Polished Caps, CGM Lug Nut Decals, Pedders Front Radius Rod Inserts, JacFab Front License Plate Bracket
Nomad is offline   Reply With Quote
Old 04-30-2011, 03:05 PM   #5
Camo81
Thanks guys, I'll head right to the parts store, if I can't figure it out I'll post pics later
PVC Tube Removal for cold air intake replacement (Lesson learned - others to learn) Kunihiro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 03-13-2022 03:40 PM
LSR Performance Cold Air Intake Kit BowlingSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 10-12-2010 09:11 AM
VOLANT POWER CORE COLD AIR INTAKE (CAMARO SS) NOW IN STOCK! Nick@moranoracing V8 Bolt-Ons & Tunes 0 06-30-2010 02:45 PM
K&N 2010 Camaro AirCharger (K&N cold air intake) GmPartsDirect.com V8 Bolt-Ons & Tunes 0 05-24-2010 09:18 AM
Air Intake Information for GM's 3.6L V6 Airaid Filters Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 91 10-27-2009 08:26 AM
