![]() Drives: 2011 Camaro 2SS/RS Join Date: Jan 2011
A/C and Heater Controls NOT Working!
Not sure if this is the correct section for this topic.
Tonight, I got into my car and decided to put on the heat since it was a little cold out at 11p tonight. Well NO heat was coming out.. Just super cold air... I tried to change the vent selection, but that wouldn't change either... it just stayed on the main front vents. I tried the defroster, feet vents, etc, but nothing worked.. Anyone have this happen to them?? I even pulled over, turned off the car and took the key out and sat for about 2 mins. Turned the car back on and still no luck :( Thanks, Allen
Allen
2011 Camaro 2SS/RS |
Plays with Hot Wheels
Drives: '17 Jet Black ZL1 Join Date: Apr 2010
I'd check for blown fuses. Maybe you'll get lucky and just had a weak fuse blow.
If you can't find a blown fuse, or replace one and it blows again....best bet would probably be the dealer/service dept.
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring) |
![]() Drives: 2010 Charcoal Gray, 2SS/RS Join Date: Nov 2010
Allen,
I had a similar occurrence a few months back. I just let the car sit overnight and the next day everything worked. You may wanna consider a fuse pull or disconnecting the battery for a few minutes.......
![]() 2SS/RS, CGM, Magnaflow Exhaust, Pfadt Suspension, Airaid intake 71 RS Camaro (Sold) Z Car (Sorry, Nissan 350Z) |
![]() Drives: 2010 CGM 2SS/RS Join Date: Feb 2011
Allen,
I had a similar occurrence a few months back. I just let the car sit overnight and the next day everything worked. You may wanna consider a fuse pull or disconnecting the battery for a few minutes....... Sorry, I posted using my old login name! Allen (oh,,,that's me!)
'69 SS Camaro 2SS/RS, CGM, Magnaflow Exhaust, Pfadt Suspension, Airaid intake (Sold) 71 RS Camaro (Sold) Z Car (Sorry, Nissan 350Z) |
Thanks for the replies
![]() After letting it sit over night, it started back up normally.. Everything works great Not sure what the issue was...thanks again, Allen
Allen
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
Glad to see it wasn't anything major. If you have any other problems you can contact me as well. Thank you for your time.
Jeff Morris, Chevrolet Customer Service |
#7 |
![]() ![]() ![]() Drives: 2010 Camaro LS Join Date: Mar 2010
I had the same problem tonight at the drive in...hope it's ok after sitting overnight tonight too
#8 |
![]() Drives: 2012 Camaro RS 45th Anniversary Ed. Join Date: Jun 2012
I'm having the same problem. My heater does not seem to work at all so I only get cool/cold air. I will check my fuses and edit my post...
edit: fuses all looked perfect. Can anyone help me? I have a 2012 RS Last edited by dwas; 12-21-2012 at 06:54 PM. |
#9 |
![]() Drives: Camaro 2SS RS Victory Red Join Date: Mar 2012
Sounds like a design problem seeing as more than one person has it. You may want to contact GM about it.
#10 |
I just sent GM an email. I wish this wasn't the only problem I was having :(
#11 | |
I look forward to your reply. Brandon Chevrolet Customer Service
#12 |
#13 |
Currently, I am not showing any open programs available on your VIN, however, it looks likes you may be under the bumper to bumper warranty depending on how many miles you currently have on your vehicle. I would definitely get this addressed by a dealership. Brandon Chevrolet Customer Service
#14 |
I went to my dealership and my heater was fixed. The wires were not seated properly.
| DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 313 | 12-16-2023 07:53 PM |
| Heater Controls?? | 67 Convertible | 5th Gen Camaro SS LS LT General Discussions | 23 | 02-22-2012 09:15 PM |
| Seat Heater not working after 6chnnl amp + 2 10's | SoTHavok | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 4 | 02-18-2011 01:45 AM |
| MY CAR SHUT OFF WHEN I TURN ON THE HEATER OR A/C? | LAYN2LOW | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 14 | 12-06-2010 07:48 PM |
| Question regarding heater - A/C controls ... | Bowtie Junkman | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 2 | 02-14-2010 05:03 PM |
