Old 05-02-2011, 03:34 PM   #1
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Pfadt Racing releases new Fabricated Rear Tie Rod
The Pfadt Race Engineering 2010 Camaro Rear Tie Rods were developed using the latest analysis software which enabled us to increase strength 136% while simultaneously keeping mass at a drastic minimum (lighter than OEM w/ bushings). Keeping the mass low allows the suspension to react more quickly to the changing road surface keeping the tire in contact with the road to increase traction. Through further analysis and testing we were able to achieve a 99.8% reduction in deflection which helps decrease wheel hop and increase traction even further.
Included with this kit is our leading edge Rear Tie Rod Bushing Kit. Utilizing lightweight 6061-T6 aluminum sleeves that are hard anodized to create incredible surface hardness and microscopic pores to hold our special grease. These sleeves are then Teflon coated to further reduce friction. This is then coupled with our graphite impregnated polyurethane bushing which uses deep grease grooves to hold and continuously re-lubricate the surfaces for long and quiet operation. The result is an ultra lightweight, ultra-low friction joint that is 42% lighter than the OE bushing and more durable then ever before. This kit includes the bushings for both the inner and outer suspension points.
The final arm is the result of four stages of precision manufacturing; CNC machining of the bushing housing, Laser cutting of the intricate panels, CNC bending and TIG welding to finish the assembly. All of this is accomplished right here in the USA.
Old 05-02-2011, 04:03 PM   #2
Synner
Drives: cars
Those look awesome and will go good with the trailing arms. 1 question, are these painted, dipped, or powder coated? I'm curious how you coated it for longterm corrosion protection inside the boxed in truss areas.
Old 05-02-2011, 04:33 PM   #3
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
What is the actual weight savings?
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 05-02-2011, 04:42 PM   #4
kunk1963
Inferno SS
kunk1963's Avatar
Drives: 2011 Inferno 2SS/RS
What's the Price for the Kit??? I Really Like my Pfadt Springs...
2012 Centennial Edition Corvette
2011 Summit White 2LT/RS
2011 Merlot Street Glide
2013 IOM ZL1 A6 w/Black Wheels, Order Pending
USAF Retired & Lovin Life one day at a time!!!!
kunk1963 is offline   Reply With Quote
Old 05-02-2011, 05:11 PM   #5
PfadtRacing
Both our Trailing Arm kit and this Fabricated Rear Tie Rod are powder coated. We specifically chose a powder coating that would be extremely corrosion resistant. We live and work out of Salt Lake City, Utah, and we certainly engineer our products to last in environments that aren't exactly friendly to suspension components. Between salt, snow, rain, and dirt our conditions run the gamut, and we design solutions to withstand what the elements can throw at you.
The arm it's self is exactly the same weight as stock, but there is a 42% weight reduction in each Polyurethaine bushing compared to the stock rubber bushing. Dropping a little bit in the bushing nets an overall reduction in weight.
Old 05-02-2011, 05:20 PM   #6
n2oSS
n2oSS's Avatar
Drives: 2010 SS2 Camaro
ide be real interested in a video showing the wheel hop before and after with the kit
Mods:
Dynatech Headers, High flow cats, MSD 8.5 wires, magnaflow bullits, Halltech intake, SCT tuner,
maggie tvs 2300, Jannetty Tune, BMR driveshaft safety loop, Pfadt drop springs, Pfadt rear trailing arms, Pfadt rear tie rod, ACT Twin Disc Clutch, DSS Aluminum Driveshaft.
Appearance Mods:
AAC Concept Sidemarkers, P13W Plasma LED Bulbs, Iforged Classics 20".
Next Mods:
Cam and Fuel System.
n2oSS is offline   Reply With Quote
Old 05-02-2011, 05:52 PM   #7
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
New toys!
And they are already available at APEX.
Old 05-02-2011, 06:31 PM   #8
Synner
Drives: cars
Well as soon as my account recovers from Friday's down payment on the car we'll be in touch.
Old 05-02-2011, 07:47 PM   #9
fastkevman
fastkevman's Avatar
Drives: 2011 Victory Red 1SS/RS M6
Oh hell, there goes some more of my money!
fastkevman is offline   Reply With Quote
Old 05-03-2011, 04:57 PM   #10
PfadtRacing
Well we don't have a video that shows the difference between stock and Tie Rod/Trailing Arm, but we do have a video of before and after Subframe Mounts and Trailing Arms. This gives a decent idea of what's happening in your rear suspension after some of the compliance has been removed.
Old 05-03-2011, 07:26 PM   #11
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Dang. I just had the Pfadt tie rod stiffeners welded into my car.
Old 05-03-2011, 08:50 PM   #12
Stealth 2010 2SS/RS
Stealth 2010 2SS/RS's Avatar
Drives: Black 2SS/RS M6
Originally Posted by Apex Chase View Post
New toys!
Just ordered the toe & trailing arm package, stockpiling for winter.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust
JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather
Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels
Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon
Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME
MGW Short Throw Shifter
Complete ZL1 Rearend Swap
Stealth 2010 2SS/RS is offline   Reply With Quote
Old 05-03-2011, 09:00 PM   #13
Ivan @ Southwest Speed
Most Excellent!
More Pfadt parts to showoff to the masses is a great thing.
Thanks to the gang at Pfadt for keepin it fresh!
Ivan & Christa
Old 05-04-2011, 05:35 AM   #14
Apex Motorsports
Thank you for your order. Upgrading durring the winter keeps your soul from dying.
Pfadt Race Engineering's newest distributor is... Apex Motorsports Suspension / Chassis / Brakes 6 06-12-2011 10:53 AM
Amazing result for Torq and Pfadt at the 2010 LS Fest! Full report inside with pics! Erik@Torq USA - Southeast 2 09-14-2010 05:50 PM
Amazing result for Torq and Pfadt at the 2010 LS Fest! Full report inside with pics! Erik@Torq Dragstrip and Launch Techniques Discussion 0 09-14-2010 03:46 PM
Tom Henry Racing Announces a Special Edition 2010 Camaro! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 72 04-30-2009 12:57 PM
