Old 05-02-2011, 09:46 PM   #1
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
Cats or no Cats why do one or the other?
Hi, need help on if I should delete the cats or go with high flow cats. I can't find much information on this subject. And why some have it and some don't. I will be adding a whipple or magna charger with Long tube headers. I already have corsa cat-back exhaust with LS3 engine. thanks
lionssfan is offline   Reply With Quote
Old 05-02-2011, 10:00 PM   #2
mbrusco103
mbrusco103's Avatar
Drives: 2011 2SS/RS (M6) 427 Twin Turbo
no cats wont pass inspection but since theres no inspection on new cars for 5 years (at least when i live) no cats would be fine for a while. the high flows should be legal but i would check that out for your state. no cats are stinky too so high flows could help with that too
2011 Camaro 2SS/RS ERL 427 M6 TT
-AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler
mbrusco103 is offline   Reply With Quote
Old 05-02-2011, 10:02 PM   #3
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
if you're worried about emission inspections, go cats. If you're not, go no cats. I went with the Solo hi-flow cats where they relocate the o2 sensor further aft to help prevent a CEL code. I also picked up about 20 rwhp with them and great sound improvement too. I'm really happy with the solo's. I have a friend with LT's with no cats and he has gone to 4 mechanics (including mine) and can't pass emissions. At least in NC there are inspections annually and you must pass to renew your registration. maybe it's more leniant in MI. best of luck to you.
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
Old 05-02-2011, 10:27 PM   #4
Gbusy06
Tap Out
Drives: 2011 Camaro SS A6 SGM
Any horse power/torque gains with no cats vs. cats? I am interested as well but I already have the high flow cats.
Gbusy06 is offline   Reply With Quote
Old 05-02-2011, 10:33 PM   #5
Synyster
Synyster's Avatar
Drives: 2006 F150 Lariat
The differences aren't noticeable, but there may be 2-3rwhp gains without cats. Most people that go without cats do it to save money.
Synyster is offline   Reply With Quote
Old 05-02-2011, 10:35 PM   #6
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I've heard of people picking up as much as 20 to 25 rwhp by removing the cats from a stock exhaust.
The stock cats are more restrictive than after market high flow cats.
BTW, I have been running high flow cats. The show removed them today so they could put my new electronic exhaust cutouts there (right behind the headers).
Old 05-02-2011, 10:39 PM   #7
lionssfan
lionssfan's Avatar
thanks for the info. I don't have to worry about it here in Michigan with inspections. Solo seem to be popular. Do you know if Solo's are better then what comes with most manufactures of long tube headers and thier high flow cats. What was the sound like with your buddies car with no cats? Also do you have headers on yours with the Solo's ?
Old 05-02-2011, 10:41 PM   #8
lionssfan
lionssfan's Avatar
yes I have heard you can get that raw fuel smell...not sure how I feel about that yet
Old 05-02-2011, 10:43 PM   #9
lionssfan
lionssfan's Avatar
I would think your fuel economy would suffer without cats because your o2 sensors might be deleted with a tune, but not really sure if there deleted or not with a tune.
Old 05-02-2011, 10:53 PM   #10
steven32708
Drives: 2010 2SS/RS IOM LS3 Camaro
would you have to get a tune if you completely remove the cats. because removing the cats completely is a lot cheaper than getting high flow cats.
steven32708 is offline   Reply With Quote
Old 05-02-2011, 11:08 PM   #11
lionssfan
lionssfan's Avatar
Yes. your going to throw a code. The post O2 sensor becomes more active without cats if you look at a tec 2. I've seen when the cats burn up and break in piecies and end up in the muffler. The post O2 and pre O2 have the same activity or ......cross counts. The post O2 with cats are always slower then the Pre O2 sensor. hope this makes sense to you. I'm not sure what your loosing when removing cats and having a tune if any. gas milage? Your gaining little more horsepower but not sure what else the advantage if any.
Old 05-03-2011, 12:50 AM   #12
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
No cats. Less weight, less cost, more power. Always.
Ovenmitt is offline   Reply With Quote
Old 05-03-2011, 02:08 AM   #13
Jay23
Drives: 2012 2SS 45th, 2007 VRSCDX
so what about no cats and the muffler delete? would you lose to much back pressure?
2012 45th Anniversary SS - Borla S Catback, Halltech CAI, Ported TB, Solo High Flows - More to come.....
Jay23 is offline   Reply With Quote
Old 05-03-2011, 02:42 AM   #14
lionssfan
lionssfan's Avatar
what about fuel mangament does the ecm still look at 02 sensors with cats removed and tuned? if you know.
Solo Performance LS3 and L99 High Flow Cats GOINGSOLO2 V8 Bolt-Ons & Tunes 169 04-20-2015 07:15 PM
Dynojet results for intake, headers, exhaust with SOLO hiflow cats! topgun1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 07-02-2010 07:52 AM
Modern Muscle Exhaust and Intake Special modern-muscle V8 Bolt-Ons & Tunes 1 01-20-2010 07:46 PM
Ohhhhh C-A-T-S Cats Cats Cats!!!!! acscamarochick06 Off-topic Discussions 1 01-14-2008 03:57 PM
