Old 05-03-2011, 01:10 PM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Sea Foam / Supercharger .... ???
I have a TVS2300 Magnacharger and I called Magnuson to ask if I could run seafoam through the system.
I got a resounding NO.
He said DO NOT DO THAT.
So I asked him if he thought it would be ok to run it through the gas tank and oil at least. He said the oil may be fine but he wouldn't run it through the gas either. He told me if I did then just don't run any real boost through it.
But running it through the blower it's self he said was a big no no. The coating and efficiency and lube and yada yada yada.
So what do you guys think? Make sense at all? Is it safe to run fuel injector cleaner through? Seafoam in the oil?
Two vids. One is from cold start. It idles good for a bit then starts to miss. The other is after it's been warmed up. It misses right away.
Old 05-03-2011, 01:18 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
DONT DO THE MANIFOLD PORTION OF THE SEAFOAM WITH THE BLOWER!!!!
I piss excellence
and fart awesomeness
Old 05-03-2011, 01:18 PM   #3
CamaroSpike23
Truth Enforcer
thru the gas tank and the oil is fine the fuel doesnt come in contact with the rotors, so that wont be an issue
I piss excellence
Old 05-03-2011, 01:22 PM   #4
PQ
Booooosted.
PQ's Avatar
Ok.
This was a developement after we got off the phone yesterday. lol
Old 05-03-2011, 01:23 PM   #5
CamaroSpike23
Truth Enforcer
Ok.
shouldnt have gotten off the phone then....
I piss excellence
Old 05-03-2011, 01:23 PM   #6
Tallboy
Say "when"...
Tallboy's Avatar
Drives: 11 2LT
Correct answer.
Tallboy is offline   Reply With Quote
Old 05-03-2011, 01:24 PM   #7
PQ
Booooosted.
PQ's Avatar
Originally Posted by Tallboy View Post
Correct answer.
Well, he just said he worried about the octane level with seafoam and boost. He said I'd probably be fine, which i figured, but he didn't want to be on record telling me it was ok. lol
Old 05-03-2011, 01:28 PM   #8
Tallboy
Say "when"...
Tallboy's Avatar
Drives: 11 2LT
When I had my Marauder [Eaton blower] my tuner told me basically the same thing. I used the sea-foam in the gas tank [I was given a couple bottles from a buddy who sold his Mustang]. I really can't say if it helped, I didn't notice any difference...
Old 05-03-2011, 01:35 PM   #9
PQ
Booooosted.
PQ's Avatar
I have a surge, or miss, or hesitation I'm trying to chase down. I've changed the plugs, tested the wires and just don't think a coil would cause an intermitent problem like this. So just for another check, I wanted to Sea Foam it. Mainly the injectors. So I can still do that I suppose. But I still don't have a catch can so I was wanting to do that as well. I will be ordering a catch can soon.
Old 05-03-2011, 01:36 PM   #10
CamaroSpike23
Truth Enforcer
no worries with the octane level. if anything, it will bump it up by about 1/2 a point.
I piss excellence
Old 05-03-2011, 01:37 PM   #11
CamaroSpike23
Truth Enforcer
you still had the miss after replacing that spark plug?
did you swap the wires as well?
I piss excellence
Old 05-03-2011, 01:42 PM   #12
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
and move the coil to another cylinder. if the problem follows the coil - there's your culprit
Old 05-03-2011, 01:43 PM   #13
PQ
Booooosted.
PQ's Avatar
No didn't swap the wires. But I just don't think a wire is the problem. In my experience, the wire is either good or it isn't. My hesitation is just not that big.
The one plug that was bad had me freaking out yesterday. It was just not firing so my scanner told me that cylinder 6 is misfiring. So I swapped the plug with cylinder 1 and cleared the code and then it said cylinder 1 is misfiring. So I went and got another TR6 and it's back to normal.
Normal meaning I had a mis that doesn't show on the scanner.
I'll take a vid so you can see the miss.
Problam is it isn't registering. So there's no way to know which cylinder.
The bad plug I put in was easy to find that way. But the miss I'm trying to fix is too small.
Old 05-03-2011, 01:47 PM   #14
CamaroSpike23
Truth Enforcer
so you are hearing a miss that isnt showing. does the scanner let you see any knock retard or spark advance?
go warm the car up and video tape it idling for me. send it to my phone or youtube it. just dont get too close to the exhaust and ruin the sound quality.
then you are going to move across the street from me.
I piss excellence
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 273 08-15-2023 04:44 PM
Stock L99 A6 Supercharger options, opinions, & experiences 2010 Bumblebee Forced Induction - V8 110 01-25-2019 04:23 PM
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 08:26 PM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 02:11 AM
Supercharging options available from BMC Performance! Curt@BMCPerformance Forced Induction 17 02-18-2010 07:17 PM
