![]() ![]() ![]() ![]() Drives: 2013 Camaro ZL1 M6 Join Date: Sep 2010
Why such small 3.27 gear on L99? Heavy car
I really think GM should have put in a bigger gear in these cars. Is the small gear really intended for better gas mileage or what? I mean who wants to drive 150mph anyways? I'd rather have a better 0-60. As heavy as this car is, it can really use a 3.73 by default. What am I missing here?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Most would agree with you ...
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS CGM 6M, 2007 Harley Deluxe Join Date: May 2010
I agree, is it the same rear gearing for the manual?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
3.45 for manual
GM should definitely have had different gear options to pick from when we ordered our SS's.
#6 | |
![]() Drives: 1SS/RS/M6-White/Beige Join Date: Jul 2009
The 3.27 is a good gear for the auto - you really need to take into consideration the transmission gearing. The first gear in the transmission is very low and the combined effect is great for launching. It is true that you could improve quarter mile time slightly by going to a 3.73 but you are not going to gain much...
#7 |
Drives: '11 Mustang GT Premium Join Date: Oct 2010
Good question and I will do my best to explain this.
The L99 Camaro is at a disadvantage, a big disadvantage. With with the gas guzzler tax looming at just 22.5mpg, GM had to take certain steps to ensure that the automatic Camaro didn't fall into the government b@llsh!t. First, active fuel management.. everybody hates it and from what I heard, it can be defeated via aftermarket programing.. not 100% sure though. Second, the extra weight of the 6L80 equipped L99 Camaro is about 53lbs heavier than the LS3 Camaro. I know it isn't much to the regular consumer but I am a weight nazi and 53lbs added to my sports coupe is like adding 53lbs to my wife... I am not a happy camper... The main reason the final gear ratio is limited in the L99 Camaro is because of the Hydra-matic 6L80 gear ratios. Compared to the TR6060 that the LS3 uses, the gear ratios from 1st gear to 4th are very, very steep. I will lay out the transmission's gear ratios in both the 6L80 and the TR6060 M6. Hydra-Matic 6l80 six-speed automatic (A6 SS) w/ TAPshift Gear ratios (:1): First: 4.03 Second: 2.36 Third: 1.53 Fourth: 1.15 Fifth: 0.85 Sixth: 0.67 Reverse: 3.06 Final drive ratio: 3.27 TR6060 six-speed manual (M6 SS) Gear ratios (:1): First: 3.01 Second: 2.07 Third: 1.43 Fourth: 1.00 Fifth: 0.84 Sixth: 0.57 Reverse: 3.28 Final drive ratio: 3.45 As you can see above, the first gear ratio in the 6L80 is a STEEP 4.03. The automatic remains steeper than the TR6060 even up to 4th gear. This would be seen in the drg racing community as a very good transmission.. and it is... If you put a 3.73+ final gear ratio in the 6L80 automatic and make engine adjustments to level the horsepower rating even with the LS3 you would have the potential for some serious 60 foot times. First gear is very aggressive and it is so aggressive that using a 3.45 gear ratio that the LS3 uses would have a very negative effect on fuel economy. With the 6L80 transmission's gearing, the Camaro can achieve similar performance as the LS3 with 26 less horsepower, 10 less foot pounds of torque, 53lbs extra curb weight and 0.18 higher final gear ratio. If GM were to level the L99 and LS3, it is very possible that the fuel efficiency in the L99 would be much lower than the 23 highway rating that it gets now, lowering it into the gas guzzlers 22.5... and costing the consumer $1300 more for the automatic and in turn... making the automatic a very unattractive option and ultimately affecting overall sales. Last edited by thePill; 05-07-2011 at 04:00 PM. |
#8 |
Thepill- great explanation, thank you. I was aware of the gear ration between the manual and auto. I guess it all comes down to better mpg and avoiding the gas guzzler tax. I would love to have a bigger gear in mine. I can use some better 0-60 times. Of course I would need some good tires too to avoid too much spin.
#9 | |
I have seen the Hydra-Matic 6L80 open and have read a lot about it. It is a fantastic transmission (built by GM). |
#10 |
Banned
Drives: 2011 Avenger Heat Join Date: Nov 2009
Could be worse, I was dealing with a 3.06 in the Challenger
I would have loved 3.15's or 3.27's |
#11 |
#12 |
![]() Drives: 2016 2SS, Yellowjacket, A8 Join Date: Oct 2009
The 3.27 gear for the automatics is all about the CAFE standards and advertised fuel economy. The largest numbers on the window sticker on any care are the city/highway MPG estimates, so to produce the higher numbers they have to sacrifice the rear gear.
Keep in mind GM could have reduced the hp to say 375 and offered a numerically higher rear gear, but the hp rating is what sells. Most Camaro owners (except the nominally few who are performance enthusiasts and frequent this site), don't know squat about rear gears. GeorgeM |
#13 |
![]() Drives: 2011 CAMARO 1LT, auto, white Join Date: May 2011
Does any know if the 1LT has the 3.27 gear for the automatics. Chevy website for 1LT indicates 3.27 for the manual.
#14 |
![]() ![]() ![]() ![]() Drives: '06 Pontiac GTO M6, '19 F150 2.7TT Join Date: Nov 2008
Keep in mind that the 5th gen Camaro has a wheel/tire package that is almost 3" taller than a 3rd gen, 4th gen or newer GTO.
Also the Corvette with the same engine and transmission comes with a 2.56 or optional 2.93 rear gear ratio. As others have said the 1st gear in the transmission is super low so you aren't really losing that much when you compare rear gears to other vehicles rear gears. W When you factor in the tire height the 5th gen is at a bit of a disadvantage on torque mulitplication but at an advantage on hwy crusing rpms. |
| Stock L99 A6 Supercharger options, opinions, & experiences | 2010 Bumblebee | Forced Induction - V8 | 110 | 01-25-2019 04:23 PM |
| Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 250 | 04-01-2014 10:40 AM |
| L99 guys that switched from the 3.27 to 3.45 gear | 94guy | Forced Induction - V8 | 18 | 04-02-2011 08:55 PM |
| Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
| "The car of the future may turn out to be no car at all." | Scotsman | General Automotive + Other Cars Discussion | 2 | 11-03-2007 12:22 AM |
