05-08-2011, 09:30 AM | #1 |
Burnin out!
Fogs and front markers out.
Last year I installed the P13w with DRL harness. This enabled my fogs to stay on with my drl's by connecting to my front orange markers.This year I noticed my fogs and front markers do not work at all. Rear markers are working. Does anyone else have this problem? Checked all fuses. I believe the fuse is #50 but I checked them all. Contacted ACC and they said it had to be in drive. Didn't work and I remember last year in park with engine running in daylight the fogs were on. Since both sides are out, I thought this might be a fuse or relay problem. Anybody?
05-08-2011, 09:33 AM | #2 |
Burnin out!
I should mention it's an SS with no middle button to turn the lower lights off and on.
05-08-2011, 09:35 AM | #3 |
knows 2 facts about ducks
Do you have the RS package? Because you don't have fogs with that, just the DRLs. If you put the P13W bulbs into the housing for 5202 bulbs (or some number like that) then that could be your problemish.
05-08-2011, 09:45 AM | #4 |
Burnin out!
It is a 2ss so I don't think I have the RS package.
05-08-2011, 09:51 AM | #5 |
Ok. Question: do you have halos or halogen headlights?
05-08-2011, 09:57 AM | #6 |
Burnin out!
They r Halos. This is a pic after install last year.
05-08-2011, 10:01 AM | #7 |
OK. You may have shorted out the wiring. Maybe check the DRL harness wires and see if they look fried?
05-08-2011, 10:05 AM | #8 |
Burnin out!
I pulled the well cover back and all looks clean and good. I will try and pull the acc clips off the marker wires and see if they severed the wire. Halos don,t work in daylight on auto either.
05-08-2011, 11:12 AM | #9 |
Burnin out!
Thanks for your help. After checking everything on driver side, I moved over to the pass side. By fluke i bumped the harness that connects the 2 sides and noticed it was unplugged. I have no idea how because it clicked in and now all works.Wonder how much the dealer would have charged for that. Anyway all is good in Camaro land for me.
05-08-2011, 12:33 PM | #10 |
Glad to see you worked it all out. Yea a dealer probably would have charged you an hour's labor.
Similar Threads | ||||
Washing/Detailing for Newbies | MRK III Z28 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 125 | 02-05-2024 09:55 PM |
Transformer Front Fascia | camaroitalia | Cosmetics and Lighting Modification Discussions | 2 | 09-23-2010 02:31 AM |
Looking for Hot Wire up front for lights | d69chris | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 3 | 12-31-2009 07:54 PM |
camaro front end | camarofanatic | Camaro Photoshops / Renderings Forum | 5 | 10-30-2008 08:30 PM |
