Old 05-09-2011, 01:54 PM   #1
walnuty
Drives: 2SS
SOLO Mach X LS3 catback $400 shipped
Solo Mach X LS3 Catback 8,000 miles needs a little cleaning but the tips have no dings or scratches – SOLD
walnuty is offline   Reply With Quote
Old 05-09-2011, 10:41 PM   #2
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
where are you located?
trudawg660 is offline   Reply With Quote
Old 05-10-2011, 08:02 AM   #3
walnuty
Drives: 2SS
Michigan
Old 05-10-2011, 01:21 PM   #4
xtreme industries
Drives: 2010 Camaro 2lt RS
what is the diameter of the pipes?
xtreme industries is offline   Reply With Quote
Old 05-10-2011, 01:31 PM   #5
walnuty
Drives: 2SS
"Solo Performance is proud to introduce our cat-back direct bolt-on Mach-X Exhaust Kit to Camaro enthusiasts. The Mach-X kit is engineered for the 6.2L V8 manual Camaro. This kit uses 2.5″ mandrel-bent T-409 stainless steel pipes with our T-304 stainless steel Mach-X muffler. The muffler was designed and engineered differently than most other mufflers. It is an X style muffler. The inner compartment (not the flow thru X but the side compartments) is split into four different chambers, each with ceramic fiber and stainless steel wool packing. It is a true “X” design and creates a low pressure system, while the four side chambers ensure that the packing won’t break apart and change the sound and efficiency over the years. It is a dual 2.5″ in and 2.5″ out design. GM needed to get around some clearance issues and had some flat spots in the exhaust. Our design has eliminated all flat spots and is a mirror-image design, unlike the GM factory system. The differential gave GM a hard time accomplishing this, but we painstakingly have. The tips are 4.5″ round, T304 stainless steel double-walled and beveled, cut on an angle to compliment the rear fascia."
-From SOLO's website
Old 05-11-2011, 07:47 AM   #6
walnuty
Drives: 2SS
SOLD, thank you!
GROUP BUY- Solo Performance Mach-XL and Quantum for the L99 (Automatic V8)- Ends 11/1 GOINGSOLO2 V8 Bolt-Ons & Tunes 285 12-28-2014 01:44 PM
trade: stock ls3 catback for custom magnaflow catback CBRTRX Local Marketplace 0 01-18-2011 10:13 PM
WTB in MI - LS3 exhaust OE catback take off, except no mufflers needed. Russell James V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 5 05-24-2010 08:13 AM
SOLO Mach X catback BELLSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 11-13-2009 10:46 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
