Old 05-11-2011, 03:59 PM   #1
pdesanctis
i like to go fast
Drives: 2011 SS
Magnaflow axleback(16582) too close to differential? no room for wrench; fluid change
I have a Magnaflow Competition series axle back (muffler delete) with the 2.5" tubing and 5" tips. part # 16582
My issue is that there is no room for me to fit a wrench so that I can change my differential fluid. Does anybody else with the Magnaflow Axle back system's have this problem?
It was dealer installed and came with the Camaro. The dealer says I have to remove the driver side pipe to change the fluid. Which I find to be ridiculous. I do take my car to the track, at least once a month. So I plan on changing my fluid every so often.
pdesanctis is offline   Reply With Quote
Old 05-11-2011, 04:20 PM   #2
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2020 2SS/M6) (2025 GMC Yukon)
I have that same part number (installed it myself), and I don't have a problem servicing my differential.
Give me a few minutes to put it up on the ramps, and I'll take a picture for you to compare to your setup.
kmcd is offline   Reply With Quote
Old 05-11-2011, 04:24 PM   #3
pdesanctis
i like to go fast
Drives: 2011 SS
That would be great. I need some "proof" that the exhaust was installed wrong or that the tubing is bent ect.. The dealer said if I can prove it is isn't suppose to be that way then they will change it.
Old 05-11-2011, 05:02 PM   #4
kmcd
kmcd's Avatar
Here are the pics. I'm using the ubiquitous 3/8-inch drive ratchet with a 3-inch extension to go over the driver-side pipe. It's a little hard to see in the third photo, so I've circled it for you. The problem may be with where they cut the OEM pipe during the install, so I've included the first photo to show how far the tips should protrude from the rear fascia.
Hope this helps.
Old 05-11-2011, 05:18 PM   #5
pdesanctis
i like to go fast
Drives: 2011 SS
Perfect! Thank you very much. This is exactly what I needed. I think your right about where they cut the stock piping..
Old 05-11-2011, 05:51 PM   #6
kmcd
kmcd's Avatar
You're welcome. Hope you get it resolved.
DIY - V8 L99 Automatic Transmission Fluid Change Goliath Camaro DIY & HOW-TO instructions & discussions 76 01-13-2023 01:24 AM
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 58 12-01-2019 10:54 PM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
My Custom V6 Magnaflow Catback exhaust (for half the price) VT2CA Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 2 06-28-2010 02:34 PM
first differential fluid change Dentyneice Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 14 05-08-2010 09:28 PM
