Old 05-11-2011, 08:50 PM   #1
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
CHANGING FLUIDS
hello, Does the L99 have a gas filiter??? I belive it does not, but every car I ever had, had one... so use to changing it out, also when should the transmission fluild be changed out??? I just changed the oil and Diff out, and ordered the cabin filiter, so will be changing that out soon.
Thanks.
MARINE1991 is offline   Reply With Quote
Old 05-12-2011, 12:27 AM   #2
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2020 2SS/M6) (2025 GMC Yukon)
Originally Posted by MARINE1991 View Post
hello, Does the L99 have a gas filiter???...
The filter is part of the fuel pump-sending unit inside the tank. It's not designed to be replaced like the old in-line fuel filters you're familiar with. This is common in newer vehicles.
kmcd is offline   Reply With Quote
Old 05-12-2011, 12:34 AM   #3
kmcd
kmcd's Avatar
..., also when should the transmission fluild be changed out???
Thanks.
The schedule for the tranny fluid is in the Manual (pg 10-5). It depends on how you're driving the car.
By the way, did you ever replace that PDIM?
Old 05-12-2011, 01:35 AM   #4
MARINE1991
MARINE1991's Avatar
Nope.... thanks for the info thow...
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 58 12-01-2019 10:54 PM
Recommended Fluids, Lubricants, and Parts Recommended Fluids and Lubricants BowlingSS Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 12-21-2010 12:32 PM
changing tranny and rear end fluid on a m6 ls3 what all is needed? and what fluids? Jferrell88 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 2 05-18-2010 07:13 PM
will changing fluids void warranty? help! 5th_GEN_SS Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 11 04-18-2010 10:10 PM
Changing rear end oil and trans oil? caverman Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 10 03-01-2010 11:09 PM
