Old 05-13-2011, 01:11 AM   #1
NORSS426
Drives: 2010 Camaro SS2/RS
Razzi rear diffuser please help!!!!
I bought a razzi GFX kit and the rear diffuser is not fitting correctly. My car has screws in the rear bumper cause of this thing and now its not fitting. The rear hangers released off the 3M tape and it is now resting on my exhaust. I need a fix for this asap since I can't drive it till I fix it. ANY HELP IS APPRECIATED!
NORSS426 is offline   Reply With Quote
Old 05-13-2011, 11:58 AM   #2
NORSS426
Bump!! Please help.
Old 05-13-2011, 12:24 PM   #3
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
Need to get some panel glue for the rear hangers any bodyshop or auto supplie store should have this!!!! Panel glue your hangers on and use pop rivoits insted of screws and you should be on the road in no time flat!!!!!
Hope this helps!!
Andrew!!!!!!!
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now!
Gotthat02fire is offline   Reply With Quote
Old 05-13-2011, 06:10 PM   #4
NORSS426
Anybody have issues with the rear diffuser not fitting properly? It says to place the rear hangers an inch below the ridge line but when i do that it doesn't allow the ends to fit and if I force it then it bows out at the bottom.
Old 05-13-2011, 10:08 PM   #5
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
not sure about that, i can do some rear pics for you tomorrow..if you need..i also had problem with double sided tabs fallen off while i was doing...finally got annoyed and took rivet gun and rivet them in place..once i did that it set up perfectly..
mikepage0007 is offline   Reply With Quote
Old 05-13-2011, 10:10 PM   #6
mikepage0007
Drives: 2010 camaro
here foung tjis pics , if it helps
Old 05-13-2011, 10:13 PM   #7
mikepage0007
Drives: 2010 camaro
rear corner pics
Old 05-13-2011, 10:34 PM   #8
NORSS426
hmmm ok, so you riveted through your bumpers ehh
Ground FX without Rear Diffuser hvychvy970 Cosmetics and Lighting Modification Discussions 12 12-20-2010 03:06 PM
WTB Razzi Rear Diffuser SA CHEVY Exterior Parts & Accessories 0 06-06-2010 11:32 PM
New Camaro Rocker Panels and Rear Diffuser compuwiz1937 Exterior Parts & Accessories 23 04-29-2010 10:33 AM
