Old 05-17-2011, 05:34 PM   #1
JBuzzy11
JBuzzy11's Avatar
Drives: 2010 Synergy Green
If I drop 1 inch will this be a problem?
I want to drop my car about 1 inch, I have Razzi GFX on the front with streetscene sideskirts and my rims are 19.8 stock. My question is will my tires/rims be large enough with the GFX so I dont have a problem with the GFX hitting speed bumps and stuff like that or would I have to go with larger tires/rims to bring the car up a little before I drop it? Im getting new rims anyway but I want to keep them the same size if I can. Hope you understand what im asking.
Injen CAI, JBA headers, MRT V1.0 exhaust, Trifecta tune.
JBuzzy11 is offline   Reply With Quote
Old 05-19-2011, 03:34 PM   #2
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
I think a lot of this is going to depend on the actual speed bumps etc. in your area since there isn't a well known height that everyone encounters. Maybe someone on here has a similar set up that can help out?
I would pose this question in the styling forum, or search others that have the Razzi GFX and see what they think!
-Blair
Old 05-23-2011, 07:10 AM   #3
STEALTH_MODE
I have a V6, so what?
STEALTH_MODE's Avatar
Drives: Top Secret
You'll be fine.. I have h&r springs (1.4 drop) and have 20s.. But I only have a stillen front lip..if your going to drop it 1 inch you'll be fine.. Don't know if your gfx decreases ground clearance itself but if it did, it wouldn't be much, I've seen them on some of the members and doesnt look like it decreases clearance.. Only thing with me is that some steep exits or driveways , I'll scrape the bottom of my front lip a little.. And of I take speed bumps a little aggressive, it'll give my chasis.. But no biggie, it's nothing that will destroy anything and it only happens once in a blue moon.. Hope this helps
STEALTH_MODE is offline   Reply With Quote
BMR "Split Drop": 1.4 inch front/1 inch rear Now Available At APEX Motorsports!!! Apex Motorsports Suspension / Chassis / Brakes 316 05-12-2016 06:00 PM
Trying to find offset to install 305's and drop 1 inch Scourage Wheels and Tires Talk Sponsored by The Tire Rack 13 05-27-2010 11:02 AM
Pfadt-ening things up Phase 2: Drop Springs robertway Suspension / Brakes / Chassis 34 05-02-2010 08:56 AM
Consolidated Toyota Recall/Safety thread Rallysport General Automotive + Other Cars Discussion 382 03-01-2010 05:42 PM
