Old 05-19-2011, 08:44 AM   #1
fishbrownie
fishbrownie's Avatar
Drives: 2010 2LT/RS White w/ Black Stripes
In dash compass "CAL"
About 99% of the time I'm on the Dallas North Tollway, my compass reads "CAL" instead of the direction I'm traveling. Does this happen to anyone else? I looked in the owner's manual and couldn't find anything on what that means. I'm thinking it means the compass is trying to calculate the direction of travel. Just a little oddity that bugs me.
"Roads? Where we're going we don't need roads."
fishbrownie is offline   Reply With Quote
Old 05-19-2011, 08:50 AM   #2
JETG
Drives: 2011 Camaro SS/RS
Yep it is the compass, and it is not recieving a signal. I get it when the car is in my garage, but once I get moving it finally picks up the signal. Might be some type or interference.
J
JETG is offline   Reply With Quote
Old 05-19-2011, 09:26 AM   #3
Johnnyma45
Former Camaro Owner
Johnnyma45's Avatar
Drives: 2011 Dodge Charger R/T
It means it's trying to calibrate the compass. Drive in a 360 deg circle away from metal structures when that happens to calibrate it. If you see it all the time though, it may be a trip to the dealer.
6/9/10-3/30/11. RIP ROXY... :(
Johnnyma45 is offline   Reply With Quote
Old 05-19-2011, 11:50 AM   #4
Shuffler
God Bless Dawson
Shuffler's Avatar
Drives: Synergy for my Daughter
I'd try the circle calibration as posted above. The same can be done for those installed in rear view mirrors.
Shuffler is offline   Reply With Quote
Old 05-19-2011, 12:14 PM   #5
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
Driving through the Bermuda Triangle?
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 05-19-2011, 12:29 PM   #6
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
Heh... The Bermuda Triangle of the Dallas North Tollway...
Scary stuff...
My VIN = 2G1FK1EJ9A9105017
Old 05-23-2011, 09:13 AM   #7
jungsoo726
jungsoo726's Avatar
Drives: 2010 Camaro SS 6MT CGM
Agree with driving in circle.... except, since you have an excuse to do so... Might as well do it with your t/c off. Make sure to post a video of how "most likely not to" calibrate a compass
U.S. Army 2003-PRESENT {OIF 06-07, OEF 09-10}
/ Airaid / Straight pipes / Morel / Zapco / Kenwood / Lamin-X /
Installer at Denton Autosound (940)484-7484
jungsoo726 is offline   Reply With Quote
Old 05-23-2011, 09:14 AM   #8
CamaroSkooter
Do some donuts. Even if it doesn't calibrate the compass, it'll still be fun
Old 05-23-2011, 10:26 AM   #9
Johnnyma45
Former Camaro Owner
Johnnyma45's Avatar
This is excellent advice...why not multitask?
Old 05-24-2011, 09:57 AM   #10
fishbrownie
While the donut method to recalibrate my compass sounds like fun, I'd burn up tires too fast since this occurs daily. I guess the tag readers for the tollway scramble my compass. Once I hit the side streets and make a turn, all is good eventually.
Old 01-30-2013, 03:59 PM   #11
whiteknight012
whiteknight012's Avatar
Drives: 2011 CAMARO RS (1LT) CGM/BLK
I love how all I have to do is START typing something like this in google and Camaro5 is always the first thing that comes up.
"Celeste" - 2011 1LT/RS CGM/BLK -A member of CVC- Central Valley Camaros [Build]http://www.camaro5.com/forums/showthread.php?t=237634
whiteknight012 is offline   Reply With Quote
Old 01-30-2013, 04:06 PM   #12
CamaroSkooter
20 month + 6 day necro thread. Awesome.
Old 03-29-2013, 02:45 AM   #13
Michael Huang
Michael Huang's Avatar
Drives: Chevrolet Camaro
I found some information on google..
#PIC5159D: Compass Calibration - (Aug 2, 2011)
Subject:
Compass Calibration
Models:
2010 - 2012 Buick LaCrosse
2011 - 2012 Buick Regal 2012 Buick Verano
2010 - 2012 Cadillac SRX
2011 - 2012 Chevrolet Cruze
2012 Chevrolet Orlando
2012 Chevrolet Sonic
2010 - 2012 Chevrolet Camaro, Equinox
2010 - 2012 GMC Terrain
This PI was superseded to update model year and add additional models . Please discard PIC5159D.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Customers may comment that the compass in the DIC displays CAL or dashes (- - -).
Recommendation/Instructions:
The compass receives its heading and other information from all the following modules:
1.OnStar Module (VCIM) - Global Positioning System (GPS) data
2.EBCM - Stabilitrak and Yaw Sensor data.
3.ECM - Vehicle speed data.
If any one of these modules lose communication or if the inputs used to calculate compass data is lost, CAL or -- will display on the DIC. If the vehicle is driven without a GPS Signal (i.e. in a parking deck, tunnel, or something covering the GPS antenna that blocks the signal) for more than 5 miles or for more than 2700 total Degrees of Turn (approx. 8 circles), only CAL will display. CAL means the compass system is CALIBRATING and this is normal operation.
When CAL or -- is displayed, drive the vehicle in an area that has clear line of sight to the sky, making several 90 degree turns. Once a signal is received, it will recalculate a heading based on its new sensor values. If the compass heading does not update after several turns in an open area, turn the Ignition off, open and close the driver's door and wait 3-5 minutes for vehicle system to power down and go to sleep then restart the vehicle. The display should now be updated. Refer to the Owner's Manual as necessary.
Michael Huang is offline   Reply With Quote
Anyone Mod Their Dash? Exo5168 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 8 04-12-2011 10:37 AM
DIY Dash and Door trim for under $30 Darth Martel Camaro DIY & HOW-TO instructions & discussions 29 09-15-2010 06:49 AM
Dash kits for secondary devices? LoneCynic Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 0 08-30-2010 02:29 PM
Factory dash ABL? bkwagonss 5th Gen Camaro SS LS LT General Discussions 3 09-17-2009 10:41 AM
'69 Door & Dash Emblems Mod tjd24 Cosmetics and Lighting Modification Discussions 15 08-24-2009 09:46 PM
