![]() Drives: 2011 Camaro SS Join Date: Apr 2011
Weak Dyno results - 2011 SS Auto with Edelbrock Supercharger
We are disappointed in the dyno results. The car has the following specs:
I've attached the 2 dyno runs. The car ran lean at peak torque. Any input on this? Are these normal figures for this setup? I was hoping for around 450-500rwhp... Last edited by lahatte; 05-20-2011 at 07:14 AM. |
10.11 @ 136.32
Drives: Black & Yellow 2SS/RS LPE LS7 427 Join Date: Mar 2010
Thats about 50-60 rwhp over stock. Seems a little light to me. My A6 dyno'd 357 rwhp when it had only headers, exhaust, CAI and a tune.
Are you running an aftermarket air intake? How much boost?
Stock air intake and i have no clue on the boost. We don't have a boost gage. We used the programer that came with the Edelbrock supercharger and the pulley it came with (auto tranny), so whatever it's programed to do boost wise is what it will be.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Silver 2010 SS Camaro Join Date: Jul 2009
You need to do the Jannetty fuel rail upgrade and your numbers will go up and fix your lean condition.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Z06 Join Date: Oct 2010
What type of dyno? If it is a loading bearing dyno like a mustang/dynapack then 380rwhp could be fine. That would be 410-420rwhp on a dynojet which is what I would expect out of a edelbrock L99/auto.
Nick
Corvette Z06 -1200ish rwhp |
#6 | |
![]() ![]() Drives: 2010 Camaro 2SS/RS RJT, 6speed Join Date: May 2011
Have you adjusted all other aspects of timing and tune? |
#7 | |
You should see about 6 psi with that system in its "stock" form, with the other modifications you have I would expect about 100 rwhp increase. Granted you are dynoing on a dyno dynamics, which read low, lets say 5% low, correcting for this would put you at 400 rwhp...Still unusably low in my opinion. Edlebrock advertises (on a manual trans car http://www.edelbrock.com/automotive_...o/street.shtml) 599 engine horsepower, so lets say being overly aggressive a 22% drivetrain loss of 467 rwhp, then another 5 lost for the auto, 440 rwhp, less the dyno dynamics lower readings around 420 rwhp would be at least in the ball park. One of the issues we have seen with these blowers is they run fairly high intake air temperatures, so verify those, second verify how much air is moving into the engine (your MAF hz or Map Kpa) so we can calculate boost pressure, maybe you have a slight leak...You can also monitor with a boost gauge or sensor on the dyno. Finally are you using their "canned" tune, and what octane? There is a nice little laundry list of checks you can make to solidify the full function of this system! |
#8 | ||||
We are using the tune that came with the Edelbrock supercharger. We updated the programer with the latest version off of Edelbrock's website and followed the instructions. We had no errors and it completed the update. 93 octane pump fuel was used. Where can I find the check list to solidify the full function of this system? Thanks |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
You definitely need a dyno tune. You better get the lean F/A ratio fixed or you will hurt the engine. Shorty headers don't do anything for you either. 1 7/8" long tube headers will work a lot better. Before I installed the S/C I had LT headers, ported intake and dyno tune. It made 414/rwhp. After installing the S/C it was dyno tuned. The F/A ratio was also very lean. It took a few runs to get it where it should be. I know mine is a manual, but you should have more HP than what you are getting.
#10 |
![]() ![]() ![]() ![]() Drives: Nothing Fun. Join Date: Aug 2009
Can you hook this car up to a Wideband on the Dyno? Even datalog the fuel trims with Edelbrock Programmer so you can see how they are.
#11 |
![]() ![]() ![]() ![]() Drives: LS3S/C Join Date: Aug 2008
should have gotten a whipple
MODS whipple 2.9L s/c, ADM race scoop, 600 rwhp 550 wrtq, .
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Whenever someone posts crazy dyno numbers it seems to always be from a Dyno Dynamics dyno.
If you get your car re-dynoed, try to find a dyno jet. Dyno jets seem to be fairly consistant (SAE - corrected numbers). |
#13 |
Right Cam
Drives: 2010 LS3 / 79 Z28 Join Date: Jun 2009
Do you have baseline dynamometer data before the supercharger install?
2010 2SS/RS M6 CGM E-Force + 2015 1LT V6/A6
#14 |
![]() ![]() Drives: Silver SS/RS, Man 6 Join Date: Apr 2009
Just one other thing could be a tank of bad fuel. I have seen several cars dyno low plus much knock retard due to bad fuel. Drain and refill with known fuel from a quality station, not Sams or Kroger. Eliminates one varable.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers, GM 3.91 Rear Gears |
| g5cr cai system anybody install or looking at one "pics" | camarossrs2150 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 41 | 07-14-2011 08:26 PM |
| Edelbrock E Force Supercharger with Free Shipping | Jason@Phastek | Forced Induction | 7 | 12-25-2010 09:29 PM |
| Think about this and the Z28 5th gen | 13F20 | Camaro ZL1 Forum - ZL1 Specific Topics | 41 | 09-04-2010 12:59 AM |
| Camaro does the Nurburgring test track in 8:20 | 2sharp | 5th Gen Camaro SS LS LT General Discussions | 45 | 07-23-2008 03:17 PM |
