![]() Drives: 1999 Pontiac Trans Am WS6 Join Date: May 2011
Just got my car back from shop (new slave cylinder), still having issues, please help
Ok I'll try to make this as short as possible, I just need some advice because the shop is telling me I have a bad clutch too, and they're refusing to take another look at the car unless it's to replace the clutch.
Basically I've been having clutch issues for a while now, sticky/loose pedal, whining noise (similar to a bad power steering pump). Finally the slave cylinder completely blew out and I lost the clutch completely, so I took it to the shop. I bought a new master and slave for then to replace. I told them to replace both, but they only put the slave in. They said they did that because they were trying to save me money by letting me return the master, and that the clutch system was working just fine with just the slave. Problem is, the clutch is slipping like crazy now. It's underivable. They're telling me my clutch is shot to hell. I told them the clutch was still making the whining noise, which they said could be some bearing or something that will be fixed when they replace the clutch. They said there's absolutely nothing else that could possibly be wrong with it besides a blown clutch. The two things that are making me not think that are this: 1) The clutch is fairly new, only 10,000 miles. It's a Spec stage 2. It worked perfectly fine before the slave cylinder completely blew out, no slipping at all. I don't see how the slave cylinder blowing out could completely destroy a 100% working clutch. Is that possible that the clutch would work great, then all of a sudden not work at all? 2) I had to move the car in the driveway this morning, and the pedal stuck on me about halfway down. I had to pull it up. Could the clutch (or some part of it) being bad cause the pedal to stick? That doesn't make sense to me... that would make me assume there's still something wrong with the hydraulics, even though the pedal seems firm now usually. Basically I asked the guy if it was possible the clutch just isn't engaging completely, but he said no because it's a hydraulic system and there's no adjusting it - if you have a firm pedal and it's still slipping, it's a bad clutch. But now that the pedal has stuck on me a couple times, could it still be a problem with the hydraulics? Any help would be appreciated. I just spend $650 getting the slave cylinder replaced, and if I have to get a new clutch that's gonna be another $750 or so, which I really can't afford right now. This is a '99 TA LS1 btw, not a 5th gen.
![]() Drives: 2010 2LT Bumblebee Join Date: Apr 2013
Hey man, I see that this post is 3 years old, but this just happened to me with my Spec Stage 1. Only 1000 miles old and running great, then all of a sudden the pedal is stuck for the first time and I can't shift into gear anymore. What ended up happening? I am towing it tomorrow but I can't see how a brand new clutch can get destroyed like that.
AirLift Air Suspension, Stainless Works Long Tube Headers + Hi-Flo Cats, Resonated X-Pipe, MRT V2 Mufflers, VMAX Ice-olator and Ported Throttle Body, Barton Short Throw Shifter, CAI Intake + Air Scoop
| 5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 06:52 PM |
| How to Choose the Best Car Cover for Your Camaro | Junkman2008 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 27 | 02-27-2015 04:10 PM |
| Clutch fluid contamination problems on Vette fixed for Camaro??? | LDGn63 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 05-28-2012 10:17 PM |
| Understanding Paint Correction-The Nitty-Gritty | Mr CLuTcH | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 29 | 03-02-2012 04:51 AM |
| Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 11:06 AM |
