![]() Drives: 2010 Camaro 2SS Join Date: May 2011
******** - Stealth Kit Missing Resistor - Need Info
Hi All,
Need some help from the community. I just received this past week my ******** Stealth Kit, which comes with the X2 and X3 wiring harness, Eclipse 12" Sub, enclosure, and Eclipse 5 channel amp. See: http://********.com/Chevrolet-GMC-Su...New-clone.html In the kit, there's a bag with a resistor, length of ground wire, and a crimp on ring. I've read the instructions they provided, and know what I need to do, but my kit did NOT come with the resistor. Pretty simple mistake to make, I'm sure. I'm already 2/3rds through the install, and just found the baggie didn't have the resistor in it. Can someone please let me know what the Ohm value of the resistor is so I can go to RadioShack and get one? ******** is close on weekends. Sent them an email earlier, but no response yet (Again, not mad or anything, they've been great!). Please feel free to PM me the Ohm value, and post in this thread that you sent it. Thanks, Ron |
#2 | |
EYE CANDY
From what I understand, the resistor is only needed if you are totally removing the BA amplifier from the equation. There should be a link in the bag you received that explains the use of the resistor, but the link I used was taken down as someone had posted the link publicly, so I don't know how much info ******** wants us to share in relation to this resistor. I'll PM you what I know. If you could PM me the colors of the stripes on the resistor you have, that would really help me out.
Ron |
Small Update: Still looking for what the Ohm measurement on the resistor in the kit is.
I've finished the install without the resistor in place, with complete removal of the old BA amp, and the system is working just fine. Had some engine whine until I moved the audio and power cables around some, and need to finalize the positioning of the wires, but other than that, the upgraded sound is AWESOME! Finally got the lows this car has been missing since day 1. I guess I'll have to wait until Monday for a response from ******** about the Ohm value of the resistor and then go back and add it. Ron |
![]() Drives: 2015 ZL1 Join Date: Oct 2010
Did you ever figure out which resistor was needed? Mine is missing too and I'm ready to install everything!
#6 | |
![]() Drives: 2010 Camaro SS Join Date: Oct 2010
I did not notice a difference when I had it grounded vs not grounded though for what it is worth. I'm sure it does something I just couldn't tell in my limited testing.
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete Roto-Fab Intake Stainless Works 1 7/8" Long Tube Headers Corsa Exhaust |
#7 |
![]() Drives: 2011 Camaro Join Date: Jul 2011
What exactly does the resistor do? I completely removed my amp and everything works fine..
#8 |
Drives: 2011 2SS IOM Vert Join Date: Aug 2009
typically it is not needed at all. Mostly if you run an aftermarket radio. During our tests, I had a pioneer deck and needed the resistor. But on the stock deck it may or may not be required.
#9 |
Steve, what exactly does it do?
#10 |
![]() Drives: 2010 Synergy Edition 2002 SOM SS Join Date: Mar 2011
Also removed my BA amp totally and all still seems to be working properly. I was going nuts trying to find info on resistor and tried it without. And whatta you know, you dont even need it.
#11 |
Yeah I just ran the ground wire without the resistor and its working flawlessly. I love the new sound in my car!
#12 |
![]() Drives: 2012 LT2 V6 Camaro Join Date: Dec 2011
Can someone pm what resistor I need because my kit doesn't seem to have one as well.
#13 |
You don't need the resistor.
#14 |
| V8 Camaro Performance Upgrades List | Milk 1027 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 93 | 08-30-2021 05:56 PM |
| Nitrous info | CamaroSpike23 | Forced Induction - V8 | 65 | 03-19-2020 08:22 AM |
| Double Din Kit Stock Appearance Taking Orders | Hess RS | Audio / Visual / Electronics/ Gauges / Nav | 30 | 03-14-2010 10:41 PM |
| ATTN turbo kit guys: MORE VIDEOS AND INFO PLEASE | general23cmp | Forced Induction - V8 | 14 | 09-21-2009 08:04 PM |
| Nitrous Info | Milk 1027 | Wiki | 0 | 08-12-2009 06:26 PM |
