Old 05-29-2011, 10:38 PM   #1
bigsquirrel
My car runs on acorns....
bigsquirrel's Avatar
Drives: 2010 SS RS Inferno Orange
Spohn Front Control Arms
Anyone have these? A curb uhmm moved right in front of my car so now I need a new lower control arm. They're the only company making after market ones I can find. Not sure if it's worth it though. An OEM replacement is less than 100. Spohn sells them as a package so I'd have to get all four. What do you guys think?
My car runs on acorns, the tears of ricers and these other slightly less important things...
2.9 Polished Whipple, Kooks LT 1 7/8 headers, HiFlow Cats, Kooks Sleeper catback, Cooling Mist Methanol Injection, PFADT Sport Sways, PFADT Springs, PFADT rear trailing arms, ADM intake, JDP stainless brake lines, Jegs Catch can, Stock SS wheels widened to 10 3/4, Hawks HPS Pads, Pedders Rear Subframe Bushing Inserts, BMR Center Brace, MSD BAP, AAC side markers, Emblem Pro's Custom Lighted Door Sills, Dash-Floor-Cupholder ABL lighting and other stuff....
bigsquirrel is offline   Reply With Quote
Old 05-30-2011, 03:38 AM   #2
PoleCat2SSRS2010
R6P Marketing Lab Rat
PoleCat2SSRS2010's Avatar
Drives: sometimes
Big Squirrel,
You might want to check the below thread.
http://www.camaro5.com/forums/showthread.php?t=146927
Yeah, I tried them and like the problems that the other guys are having with the drag race rear lower control arms NOT fitting as advertised the front arms have their risks too.
So far I am the only one to discuss install results. No one else has responded. The results were not good. -0.3 caster after install. If you were to use the Pedders eccentic bolt kit you will get about around +1.0* to add to the result. To correct it you will need atleast 8*. They were that far off. Spohn isn't backing his products. Says that other customers have installed them. There is no supporting data of customer front end alignments to support his claim of "being made to OEM dimensions."
I recommend saving that hard earned cash and going with a sure thing and get the OEMs arms. $600 is a high price for an absolute no refund situation of R and D.
My alignment tech has at least 30 years experience and done many of these cars. None before me with the Spohn front arms. He allowed me to look at the car and discuss with him the problem not getting the cast in spec but he was pretty certain that there was no getting to spec. I myself have spent about 30 years studying and making suspension mods and agree with him.
If you get them AND put your car on the rack AND get at least the factory recommended caster spec of +6.0 - +6.6 please let me know and I will gladly retract my posts on this issue.
PoleCat2SSRS2010 is offline   Reply With Quote
Old 05-30-2011, 11:23 AM   #3
bigsquirrel
Thanks, I appreciate the feedback. I was on the fence about getting them eother way now certainly won't.
Old 05-30-2011, 11:44 AM   #4
L99CAMA2011
L99CAMA2011's Avatar
Moving curbs huh, LOL, I took a left turn and understeered into one 2 months ago mine is still ok though.
Old 02-26-2012, 02:06 PM   #5
PoleCat2SSRS2010
Drives: sometimes
OEM v Spohn
update:
The front bushings are centered at their bolt holes for comparison.
I have more but these are pretty much self explanatory.
Old 03-25-2012, 04:41 PM   #6
PoleCat2SSRS2010
Drives: sometimes
About a few weeks ago I contacted Spohn and was confirmed an RMA number and shipped the arms back to Spohn. I am happy to confirm that I was provided a complete refund. Keep in mind that as a customer I could have been just as easily denied any refund due to terms and conditions and the original purchase being so long ago.
Props go to Spohn for standing behind his product and working with me to resolve this in a professional and courteous manner.
Old 03-25-2012, 04:48 PM   #7
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
thanks for the report,i was looking at these to shed some weight,thanks for the heads up
Hendrix-Engineering is offline   Reply With Quote
Old 04-21-2012, 11:12 AM   #8
VENOM XLI
Drives: 2010 Satin Pearl White 2SS
totally had the same moving curb problem a month ago and bent my front left control arm a 16th of an inch. glad I'm not alone on this lmao
VENOM XLI is offline   Reply With Quote
Old 07-04-2012, 12:24 AM   #9
Blown396
Blown396's Avatar
Drives: 2008 G8 GT
Spohn Control Arm Snaps On G8
Take a look here:
http://forum.grrrr8.net/showthread.php?t=32394
Just a heads up!
EB
Blown396 is offline   Reply With Quote
Old 07-04-2012, 01:49 PM   #10
Moreno1
Drives: G5.R
Same here, I guess I wont be going on this diet! Too bad though because the weight saving would have been cool :(
Moreno1 is offline   Reply With Quote
Old 07-15-2012, 11:20 PM   #11
dancc
Drives: 2010 camaro ss bumblebee
dancc is offline   Reply With Quote
Old 07-16-2012, 02:11 AM   #12
L99CAMA2011
Pfadt was right about these bushings needing to allow articulation. I honestly thought this exact same thing would happen. I said to myself , what if I am going into a turn on the track at 100+ and one of these arms break, hello wall, goodbye life, I'll pass. Stock arms were engineered by GM to handle the stress of this behemoth and not to take lives in the process, GM can't and won't allow that liability to occur.
Old 02-03-2013, 01:22 PM   #13
lcyv
Drives: Camaro 2SS 2011
Additional issues
Additional to the reliability and fitting issues, my 2011 SS have been facing a "wobbling" issues in high/strong acceleration since I have the spohn kit installed.
The camber is corrected and the tires and wheels are correctly aligned/balanced. However in high acceleration (corner exit for example), the fornt wobble almost uncontrolled. I just see something similar in superbikes (tankslaper).
Before the installation of the spohn kit it never happened. Did anybody faced something like this or I am missing something?
Thanks
lcyv is offline   Reply With Quote
The definitive bushing solution for your Camaro control arms! PfadtRacing Suspension / Chassis / Brakes 18 09-22-2011 03:24 PM
Rear Lower Control Arms and Rear Toe Links for your 2010-2011 Camaro PFYC Suspension / Chassis / Brakes 0 11-15-2010 04:31 PM
Aftermarket control arms? tples69 Suspension / Brakes / Chassis 12 02-18-2010 11:22 PM
LMPerformance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Delrin Bushings LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 03:05 PM
