LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
Stock clutch is not going to like much over 500 RWHP for long. The transmission is pretty durable. The weaker link is the drive-shaft and axles. Remember:
High HP + Traction = Broken Parts. |
#3 | |
Boosted Moderator
Drives: Bone Stock LS3 Join Date: Sep 2009
my tranny is being touched up right now, not bad after the power I've thrown at it, changing the synchros and putting brass bushings on the forks. Other than that it seems to be holding up ok... Synchros going in are carbon fiber.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
#4 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 c7 Join Date: Nov 2009
#5 | |
Boosted Moderator
I'm almost there, still need a nine inch diff and 3.07 gears so I can launch her the way she wants to be launched and still go over two hundred in the standing mile without having to shift into 6th. OP, sorry for the thread jack... back to your regularly scheduled programming...
#6 |
LT4 M6
#7 |
Boosted Moderator
I finally did, I put a hair dryer on each side of the motor and ran a really long extension cord....
I Love the power and the torque is unbelievable... 110 mph tire smoking romps are crazy... Doing that at 75-85 mph keeps a lot of idiots from wanting to race... Several times I've down shifted without acknowledging the person in the other car, rev match it to let the clutch out, and just hammer it into full boost... Tires go up in smoke and the other car usually just goes away, or gives me a thumbs up and goes away...
#8 | |
![]() ![]() ![]() ![]() ![]() Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
#9 | |
LT4 M6
#10 |
![]() Drives: 2010 camaro ss Join Date: May 2011
Can an auto camaro smoke em at 75 80
#11 | |
#12 |
Drives: 99 Camaro SS, 79 z28, 70 GTX Join Date: Oct 2009
I usually just rev the engine and they know...
#13 |
Boosted Moderator
Well, as mentioned above, they are currently going through the tranny... Checked everything, and are going in with the bronze/brass bushings...which ever one... They are also going in with Carbon Fiber Synchros... I have an ACT 1400 Ft/lbs rated clutch....Twin Disc, and Drive Shaft Shop 1400 HP rated axles...
Heavy duty sways, trailing arms, toe rods, delrin diff bushins, and solid aluminum sub frame bushings... The backside is solid, a tiny bit noisy but solid... I'm for the moment still on the stock diff and praying I don't grenade it since two people have offered to buy it when I put my nine inch with 3.07 gears in it.. along with a one piece aluminum drivehshaft... Psssshhhhhhm I was running old school cars before you were even thought of... I had kids and a job though so I put it on the back burner for a long time... Priorities... My youngest is 23, so it's mom and dads turn.... I hear you and I would love to see and hear your beast... but, Brandi is pretty dang quiet... before the build, I had a CAI and an axle back, and she was much noisier then... Now she pretty much sounds stock until I really get her into boost... Then there is the final determining noise to those that recognize it... the blow off valve popping... Pppssssshhhhhhh..... With the turbo's dicing the sounds waves a million ways from sunday, and the magna flow mufflers, she just doesn't advertise much... I really have been thinking about a set of cut-outs... Do you offer those...???
#14 |
Boosted Moderator
You need to hook up with the Htown gen 5 Camaro guys. There are some bad Camaros in that group, and yes, properly prepped they can, the trick is getting this much power to hook... I didn't build it to spin em... Drag radials don't spin too bad, but the stock tires go up bad..
Owen at ARD can hook you up with pretty much anything you want performance wise... he built many of the fast cars in and around Houston, and a better group of folks is hard to find..
| What do all the abbreviations mean? | CrzyGamr2 | 5th Gen Camaro SS LS LT General Discussions | 77 | 12-07-2012 04:34 AM |
| Modifying for " Dummies" | Dr Jkel | Tuning / Diagnostics -- engine and transmission | 209 | 06-17-2012 11:24 PM |
| Clutch fluid contamination problems on Vette fixed for Camaro??? | LDGn63 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 05-28-2012 09:17 PM |
| Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
| Manual Tranny Clutch Specs? | ZZcamaro | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 0 | 04-14-2009 09:10 AM |
