![]() Drives: Camaro GT Join Date: Dec 2009
Did a search and am more concerned now than before I did the search!
I'm installing a stage III kit from Pfadt but the end links are on back order, so I'm running the stock end links until the Pfadt end link's arrive. My fear is that the weaker stock links will break due to the more solid Pfadt swaybar. ![]() Also, will I need the new bracket (below) to minimize any possiblility of breaking the end link bolts? |
I'm not totally useless..
I did 6500 miles on the stock end links with Pfadt bars with no probs before going to their endlinks (only cuz a member was selling them cheap!). Still no issues so far with my LCA attachment points... You just need to be sure to torque the endlinks fully (33ft lbs IIRC) and check them after a few break-in runs and you should be fine...
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Your lower control arms will be fine on the stock endlinks. The first thing to bend in that system is typically the OEM endlinks before that tab. Just keep an eye on the endlink for bending, we are working as fast as we can and they will return soon!
thanks
Supercharged LSX
Drives: 2011 2SS/RS Black/Carbon Fiber Join Date: Dec 2010
I didn't wait and just ordered end links from Spohn.
#6 |
Pfadt, is there an ETA on the end links release?
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
I'm doing the opposite on end links. I'm staying with the OEM ones for now....mostly because of budget reasons. If they bend or break I'll replace them then.
My car is a daily driver with only an occassional AutoX event and trip to the drag races. I've heard from others, like Hypurone says, that the OEM end links will work fine. Now, if I were racing my car alot or doing hard road racing that might be a different story. I also thought about buying the end link mounting plates but after reading more it's been said that the failure of the mounting point has been much fewer than the amount of Camaros with sway bars. Again...something I'm just going to keep an eye on and if even remotely see it cracking I'll be buying the mounting plates. Since I'll be running the OEM end links I have a feeling those will bend/break first before my LCA starts to get affected. If I had the extra coin then it wouldn't be bad to have for insurance. Unfortunately these $60 here, $200 there all for insurance purposes just doesn't fit for me. The wife is already about to remove me from the credit card access.
Build Journal ![]() |
#8 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Check with Apex Chase for the Pfadt endlinks. Pfadt has been out for a little while and chase had a few sets left. That was about 5-6wks ago though.
As for the LCA braces, I figured they were cheap insurance. They add nothing in weight and take zero extra time installing, when you're already changing endlinks. By far the easiest and lightest of all the solutions.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
#9 | ||
Thanks for the mention though. We had them when no one else did so everyone was referred to us until we ran out. Now it is just a waiting game. We have a couple of pallets on the way to us from Pfadt but I'm not sure if there are any end links on them or if they are coming separately.
| 5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 06:52 PM |
| Pfadt Sways | In Stock | Best Prices | Free Shipping! | JDP Motorsports | Suspension / Chassis / Brakes | 121 | 08-30-2012 06:07 PM |
| Better Handling | Tbanks | Suspension / Brakes / Chassis | 30 | 12-15-2010 12:50 PM |
| Pfadt Sway Bar Comparisons | PfadtRacing | Suspension / Brakes / Chassis | 21 | 07-23-2010 03:51 PM |
| Pfadt Springs and Sway Bars In Stock! *Package Deal*! | PfadtRacing | Suspension / Chassis / Brakes | 0 | 10-14-2009 06:41 PM |
