Old 06-08-2011, 01:55 PM   #1
JohnnyComeLately
JohnnyComeLately's Avatar
Drives: 2010 SS/RS
Post DIY: Front Door Component speaker (Hertz 165 HSK) install
Quick video I made of pitting in Hertz HSK 165 6.5" component speakers and Dynamatting the doors. You'll see how I put the crossover inside the car, behind the sound deadening mat of the door panel.
Both my rides will smoke ya 2010 L99 2SS/RS - Hertz HE HSK 165 components/PPI A404 & A600/JL Audio 10W6/Audio Control EQX, FAST Intake Manifold
JohnnyComeLately is offline   Reply With Quote
Old 07-07-2011, 11:15 AM   #2
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
why did you go with the hertz speakers, how much were they, and did you install a new amp to power them?
I've been contemplating changing out all the speakers and adding a new amp. I like your install...very clean. Good job. Just thinking of what speakers to go with and what amp.
Old 07-07-2011, 02:08 PM   #3
JohnnyComeLately
Drives: 2010 SS/RS
I went with Hertz after listening to JL Audio, Alpine, Focal, Dynaudio, MB Quarts, Eclipse, and a few other speakers I'm forgetting. I also listened to Hertz at 3 different Hertz dealers just to try and eliminate any bias from one or another dealer's set up. The Hertz had the cleanest, neutral mid-bass and the clearest highs without any listening fatigue from high volume for long durations. I threw in U2, Rush, Lady GaGa, and a few other CDs to hear the speakers under different conditions, and I literally stood there for close to an hour listening to these. I also closed my eyes and then signaled to them to switch speakers without telling me which... I always came back to the Hertz Hi Energy HSK 165s, even next to the $800 and $1100 Hertz speakers. It wasn't like Focals where I loved the $500, until I heard the $700, and then I loved the $700 until I heard the $1100. The HSK 165s sounded great.
Now, just to caveat this: The Milles did sound better with some source, but only On-Axis... Meaning, you had to be directly between the speakers, which doesn't happen in a car. No one listens with their head down by their center console. The other is that the XL sounds better with more power than I'm running. If you're running a clean 150 RMS per channel, than go with the Hertz Hi Energy HSK 165 XL... I'm not. I'm running 50-100 and the non-XL sounds great. The XLs handle more power, with the same sound quality... Which brings me to an important point: I built my system to be SQ (Sound Quality). It's not a system meant to just get loud.
The retail on HSK 165 is $499. You won't find it on E-bay for much lower except from Malaysia. I figured, I took up many hours of my local dealers time (not kidding, I did spend hours), and I appreciated the ability to hear these speakers side by side in a good atmosphere: I'll spend the coin. I did have one dealer offer me these for about $200 less, but again, I felt it wasn't right to not support my local dealer who was very patient and helpful. They knew I was only buying the speakers from them, and installing myself.
I initially ran these off the BA amp. It sounded a ton better than stock speakers, didn't really clip (I also had the center channel disconnected which helps a lot stock or upgraded speakers), and is worth your while. However, to really hear these speakers hit their stride, you'll need a good quality SP type amp.
These speakers are now powered by an "old school" Precision Power Industries (PPI) A (Art Series) 4200, which is 4 channels at 50 watts each. These amps are well known to be under rated. I did initially have it bridged to two channels, so they were getting 100 RMS each, until I realized it was mono. There really wasn't much sound difference, HOWEVER, I also have these crossed over really way too high. My "ear" says these are crossed over up above 500Hz (I bought a used Audio Control EQX and haven't popped the cover to see what it's dividing), and these are suggested by Hertz to go down to 250.
Here's the thread where I'm journaling my experiences... I need to update it.. I'll do it after lunch
http://www.camaro5.com/forums/showthread.php?t=152383
Old 07-09-2011, 06:39 PM   #4
SlyJester7
SoCal HT5 *COTW 8/26/13*
SlyJester7's Avatar
Drives: 2013 SS/RS LS3
SlyJester7 is offline   Reply With Quote
Old 07-16-2011, 03:03 AM   #5
TAG UR IT
TAG UR IT's Avatar
WOW!
Excellent info and that is really helpful.
I've been looking for some good speakers. I know it might differ from person to person. But, that's what I do....close my eyes and switch it around from speaker to speaker. So, I appreciate the input.
I really want to get the stock amp and speakers replaced and think that'll be my next deal to get done.
So...who offered them to you for $200 less???
Old 07-16-2011, 12:06 PM   #6
TAG UR IT
TAG UR IT's Avatar
Looked on ebay. I found them from Singapore and Maylasia for anywhere between $80 to $180. Is there something I'm missing? You said you paid $300? Was that for all of them or just two?
Old 07-27-2011, 12:32 PM   #7
chopper
chopper's Avatar
Drives: 2011 camaro 2ss convertible
What would I need to use to seal the ******** adapters and how and why would they need too seal them might be a dumb question but im a newbie to audio install
chopper is offline   Reply With Quote
Old 07-27-2011, 12:52 PM   #8
tbone587
Drives: 2011 Camaro
Chopper,
You should either spray paint them black with a few coats, or seal them with resin.
tbone587 is offline   Reply With Quote
Old 07-27-2011, 12:59 PM   #9
JohnnyComeLately
Drives: 2010 SS/RS
Sorry, been sorta out of the loop due to a car pulling in front of my bike and other issues. I paid $450 for a single pair. I was offered by a dealer I'd rather not name $300 for a pair, but when I mention that price to Hertz dealers in San Diego, they get extremely angry. I don't want to burn my source here
I assume you mean sealing the ******** speaker adapters, and not the adapters for the amp electrical connections. The ST speaker adapters are particle board which you then attach with sheet metal, or less-than ideal sheetrock (drywall) screws to a metal surface. Two non-forming, hard objects, one of which is oscillating (making sound) at multiple freq's usually need something between to buffer and make the speakers "sound" better. It's also to provide a better performance, as any sound waves that come out of the back that are able to immediately come "around" the speaker to the front will cancel out. For an obvious example, turn on a heavy bass song with your sub in a box. Now take it out, and do the same. Obvious difference, but the principle is the same with sealing a mid-range driver. Tweeters are in a sealed enclosure usually, so this is why it's an issue mostly for the mid-drivers. Make sense? I sorta gave a long answer.
Old 07-27-2011, 01:10 PM   #10
JohnnyComeLately
Drives: 2010 SS/RS
Originally Posted by tbone587 View Post
Chopper,
Are these being sealed for moisture reasons?
This is part of the reason I personally am not a fan of particle board anywhere moisture is close by. A sub box is ok, but door interiors see a ton of moisture. I think plastic adapters, although less than ideal from a rigidity-seal standpoint, are a better route and is why I stuck with the OEM adapters. In 50 years you'll pull my adapters out and they'll be the same. No matter what you do to particle board, there's decay eventually. Even pressure treated redwood breaks down eventually
Resin sounds like a good route, but at that point.... you've spent more time and effort than using the OEM or similar plastic adapter.
Old 07-27-2011, 03:10 PM   #11
tbone587
Drives: 2011 Camaro
Guys I found these scosche plastic adapters for 20 bucks.. I dont know if they look quite as deep as the factory baffle though, maybe someone knows..
http://www.scosche.com/car-audio/product/2028
Old 07-27-2011, 03:15 PM   #12
JohnnyComeLately
Drives: 2010 SS/RS
Wow, good find. At $20, I would save my 30-45 minutes of hacking the OEMs and have just gotten those.
We have tons of mounting depth in our cars. The windows aren't behind it, and the frame within the door isn't that tall. So unless you're putting subs in your doors, I think 99% of the 6.5" mid drivers would be fine with those adapters. And even if you do need more, you can easily put a generic spacer between the driver and adapter for more depth.
Old 07-27-2011, 03:21 PM   #13
JohnnyComeLately
Drives: 2010 SS/RS
For anyone needing rears, here they are:
http://www.scosche.com/car-audio/product/1177
I'm probably going to use those, however I think the Alpine R-type 17S components I'm planning on running in the back come with a 6x9 to 6.5" adapter.
Old 07-27-2011, 03:49 PM   #14
tbone587
Drives: 2011 Camaro
Johnny, just out of curiosity, why do you think the factory speaker adapters are so deep? I havenent taken my door off yet, but I assumed they were that deep due to clearance issues.
door, hertz component, install, installation, speaker
DIY : Install headers on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 70 06-25-2020 07:40 PM
DIY : Radar Detector Hardwire Install Macamaro Camaro DIY & HOW-TO instructions & discussions 179 07-29-2014 08:30 AM
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 09:25 PM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 05:36 PM
