Old 06-14-2011, 11:30 AM   #1
ron8879
ron8879's Avatar
Drives: 2018 Camaro RS
questions questions questions
ok, so that title might be a bit much....I have decided to lower hotrod and its down to BMR (assuming they are back to selling early v6 springs) or Hotchkis....I plan on going with a 1" drop and would like some feedback from people on the ride quality and any problems anyone has had with either brand......and one last bit....I live near st louis and could use a recommondation for a great shop that knows how to do the install and time the bushings...thanks
Fifty years from now, when you're looking back at your life, don't you want to be able to say you had the guts to get in the car?" :
HOTROD2010 VR RPO 14568...flowmaster exhaust, color matched antenna and drip rails, barton shifter, 4 pack gauges, leather armrest, color matched spoiler, and emblem delete, 20x9 chrome wheels
HOTROD2018...RS camaro LT1 Npp Exhaust, SS front brakes package and cooling packaage, black bowties, more updates to come!
ron8879 is offline   Reply With Quote
Old 06-15-2011, 11:54 PM   #2
ron8879
ron8879's Avatar
bump
Old 06-16-2011, 11:01 AM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There are lots of threads on lowering springs. I"d suggest you search them and see what others have to say about them. There are also several threads with LOTS of pics. Since ride quality is very subjective, the only real way to compare them is to take a ride in a car with them installed. I have done that for a few people around me and all have bought the ones I have. Just a suggestion, i'd get a set of springs that drops a little lower than 1in. The V6 typically sits higher than the V8 so you won't have the same lowered look. It may just be that the wheels are smaller but either way, it doesn't look lowered unless you drop it more. As far as shops, I don't live near you so I can't help. I will say that most GOOD tire shops should be able to do it. It's not that hard and many on here do it themselves. Just be sure that they're not going to rape you on labor as that's all they'll be providing. You're looking at ~2-3hrs labor plus a alignment. That shouldn't be more than $300-350.
You could post your shop question in your regional forum. Surely someone near you is on here and has some recommendations.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-17-2011, 01:04 PM   #4
ron8879
ron8879's Avatar
thanks axis for letting me know about about the regional section...otherwise I know there a bunch of trends on here but i was looking for more recent since bmr stopped sellign for v6 for a bit due to a shock difference. I was hoping for a followup from some members as well to see if this problem was solved or was a problem at all....as well, i more than likely will go with more than a 1" drop since you make a good point about the v6 sitting a bit higher than the 8.
Old 06-17-2011, 04:01 PM   #5
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
There definitely is an issue with the V8 and V6 shocks being different. The V6 shocks seem to be the same part number as the V8, and even show up as the same replacement part number according to the dealers we've called, but there definitely is a difference between cars as they come from the factory. A solution is being worked on for V6 equipped cars as we speak, but for right now we've stopped selling V6 springs because of the change.
We've done some work with CBI Street Cars in Florissant in the past and they do good work. You might want to give those guys a call. Their number is 314-479-7799.
Old 06-18-2011, 09:31 AM   #6
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
We have been installing the Pedders coil springs on the v6 cars with no problems,but the Pedders springs are a hot wound spring unlike many of the drop springs sold by others.Here is a link of Pedders factory making there own springs.http://www.peddersusa.com/products/10
Bruce@raymondsperformance is offline   Reply With Quote
Old 06-18-2011, 01:31 PM   #7
ron8879
ron8879's Avatar
so my car is a very early v6...what would be the difference between it and the current v6's currently being sold?
Old 06-18-2011, 01:49 PM   #8
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
I had eibachs installed last week and love them. just got a bad creek on the passenger front yesterday. Trying to figure out what that is but love them so far. If your on a budget, go for eibachs, if not go with Pfadt. Altough they stopped selling v6 springs now, I have never heard a complaint or problem with any pfadts users
CAMARO
Old 06-18-2011, 02:43 PM   #9
Rob@WretchedMS
Drives: His Wife Crazy
yours is a 2010, the new ones are 2011
lol, sorry, it was just to easy.
I don't believe there is a difference in regard to the struts.
Some of the 2011's are coming with different sub frame bushings, but most of the changes will not happen until the 2012 model year.
Rob@WretchedMS is offline   Reply With Quote
Old 06-19-2011, 10:57 AM   #10
ron8879
ron8879's Avatar
[QUOTE=Rob@WretchedMS;3355460]yours is a 2010, the new ones are 2011[QUOTE]
ok so hopefully if/when i get my drop springs I wont have any problems with the install as long as I let them know when ordering that ive got a v6...
Old 06-29-2011, 05:45 PM   #11
JusticePete
Drives: Camaro Justice
Having checked with our GM sources we can conform that Pedders lowering coils will fit both the V8 and V6.
Old 07-02-2011, 11:28 AM   #12
ron8879
ron8879's Avatar
coil overs or lowering springs---or is this some crazy hybrid (im thinking its not)
Old 07-02-2011, 11:30 AM   #13
JusticePete
Pedders lowering coils are a direct bolt up for both the 6 and 8. Our coilovers are as well. These are the 220032 front and 220033 rears on a 6.
Detailing questions answered here! Moose Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 636 06-04-2011 01:27 PM
Couple of questions codo Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 2 09-29-2009 09:51 PM
ordering questions...how long, when should i order... etc haleyd Camaro Price | Ordering | Tracking | Dealers Discussions 10 07-25-2009 02:47 PM
so many questions about the new camaro... haleyd Camaro Price | Ordering | Tracking | Dealers Discussions 14 07-22-2009 03:23 PM
New member with a few questions rachelcb80 5th Gen Camaro SS LS LT General Discussions 21 06-29-2009 12:02 PM
