Old 06-16-2011, 10:23 AM   #1
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
Apex Motorsports Skip Shift Eliminator 8001
Does anyone have this installed and what do you think ?
tpower is offline   Reply With Quote
Old 06-16-2011, 10:50 AM   #2
HDRDTD
I don't know if it's a Eliminator 8001, but I do have a skip shift eliminator installed I bought from Apex. Had the dealer put it on for me since the car was in the shop for several mods.
Works like a champ.
Old 06-16-2011, 11:16 AM   #3
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
Best mod to date!! Love it.
Pollock is offline   Reply With Quote
Old 06-16-2011, 11:17 AM   #4
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
Cool my car feels like it is in the wrong gear at low speeds , drives me crazy
Old 06-16-2011, 11:35 AM   #5
HDRDTD
Keep in mind that the 'skip shift' only comes into play if you are accelerating very gently from a stop light.
Even if you have the eliminator installed, you will still see the indicator appear in the DIC under those same conditions.
I think in the last 3,000 miles or so I've only had the skip shift display maybe 4 times.
Just accelerate just a wee bit more, or hold it in 1st just a little bit longer, and you'd never run into the skip shift issue again.
Old 06-16-2011, 11:48 AM   #6
Eldnearb
Chevy for life...
Eldnearb's Avatar
Drives: 2011 RS/2SS Black
Send a message via MSN to Eldnearb Send a message via Yahoo to Eldnearb
i hear about these but have no idea what it is...can someone explain?
2011 2SS Black w/Cyber Grey Stripe
Chevy for life...
1987 Chevy Celebrity, 1992 Chevy Cavalier, 1995 Chevy Camaro, 2001 Chevy Blazer, 2002 Chevy Silverado, 2011 Chevy Camaro
Eldnearb is offline   Reply With Quote
Old 06-16-2011, 11:59 AM   #7
SSFury
My Road Rage is Legendary
SSFury's Avatar
Drives: 2011 IOM 2SS/RS "Fury"
It's to save on fuel. If you are at low RPM's in first gear, and attempt to upshift to second, the car figures your not in a hurry, and in an effort to use less gas, it locks out second, so as your pulling down on the shifter, it slips instead into fourth. Which, at low RPM's, the car barely has the power to turn the gears. It shutters a little, and generally gives you no power whatsoever. On the rare occasions this has ever happened to me, it is automatically followed up with a downshift to third. Not exactly what it was designed for, I'm sure.
Like HDRDTD Said, if you drive it right (knowing what NOT to do..) You really dont ever get this to kick in.
Every Time You Buckle Up In That Car, Tonight Might Be The Night That You Die.
SSFury is offline   Reply With Quote
Old 06-16-2011, 12:00 PM   #8
HDRDTD
The skip shift eliminator is a simple length of wire (with secret stuff inside) and a connector at either end.
The skip shift cable unhooks from the top of the transmission, the skip shift eliminator cable is then connected between that cable and the trans.
That's it.
Old 06-16-2011, 12:53 PM   #9
Swifty49
Drives: IOM Camaro 2SS/RS
Does it ruin your warranty?
Swifty49 is offline   Reply With Quote
Old 06-16-2011, 01:28 PM   #10
HDRDTD
Nope. Not according to my dealer.
BORLA Exhaust Systems From Camaro5's #1 Borla Distributor: APEX Motorsports!!! Apex Motorsports V8 Bolt-Ons & Tunes 56 08-13-2012 06:44 AM
Who's looking for a deal on a Skip Shift Eliminator? Apex Paul Transmission / Driveline 51 07-07-2010 06:32 PM
$26.95 Skip Shift FREE w/ purchase of Hurst Billet/Plus 2 Shifter Apex Paul Transmission / Driveline 9 04-23-2010 08:08 PM
St. Louis, MO Tune Special - Turn off Skip Shift or AFM! DSteck V8 Bolt-Ons & Tunes 3 04-19-2010 04:20 PM
