![]() Drives: 79 transam with 582cid dart motor Join Date: Jun 2010
fuse pull for ls3 is it required?
how do i know if i need to do the fuse pull or not. have 2SS m6 ls3. with nanny controls off it will get a little rubber in 2nd gear (a chirp) when we got the car it had 300 miles on it and came with a full tank of gas.
thanks
2010 Camaro (inferno orange, 2SS, RS and such) cat backs, catch can, CAI on the way 79 Transam, 582 cid dart motor 779hp 315's out back 40spline gdaxles tko tranny |
Not required but it can't hurt to do it.
Read this if you haven't already. http://camaro5.com/forums/showthread.php?t=38964 |
#3 | |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
![]() ![]() Drives: 2011 2SS/RS Join Date: May 2011
I finally did it after 1000 miles....I did notice a loss of the "lag" I felt, and a little more pep. Whether it was in my head or not..... it was free, pulled them before I went to bed, put them back in when I woke up.
Built By Blu808
LG G6X3 Cam, UD Pully, Rotofab Intake. Dynatech LT's. Borla ATAK Catback. Full BMR bushings and suspension. |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Yep, wouldn't hurt if you've driven out that 1st dealer tank and you've been putting premium ever since. I did because I was unsure what octane the dealership put in mine upon delivery. I did notice a little more umph, but nothing spectacular like the L99 guys mention.
#6 |
"Catharine"
Drives: '11 2SS/RS LS-3 IOM/IO vert Join Date: Mar 2011
Trying this just in case.
#7 |
i guess i will give it a whirl.
thanks
#8 |
Why do the fuses have to be left out for hours and preferably overnight?
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416 ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly ![]() |
#9 |
"Catharine"
I think it has to do with capacitors retaining a charge. Have to let ALL the juice out.
#10 | |
Would have thought it would only take 5-10 sec. Dang flux capacitors can drive you nuts.
#11 |
Nightmare
Drives: Your mom crazy in bed Join Date: Mar 2011
I did mine and left it out for an hour....and then put them back in. I didn't drive the car for almost 24 hours after it though. I noticed a difference.
#12 |
"Catharine"
OK, so this morning I put 5 & 20 back in. The car seems more responsive, but I wouldn't say it has lots more power. But I haven't got on it yet either, so don't really know.
Smoother idle, maybe a bit. I did notice a difference in manual shifting, have to give it a tad more gas to get rolling. Acts as if the timing is a bit more advanced, but not by much. Could be the placebo effect.
#13 |
I bleed green
I bet the computer has to relearn its trims or whatever...you just erased it's memory. 50 or 100 miles should have it back to normal.
![]() 2011 2SS/RS LS3. Delivered 4/18/11. Solo Axle-back with J-pipes and quads, 35% tint, Yellow trim kit, Showstopper sidemarkers, babied garage queen. 2006 Silverado 3500 6.0, 1993 Pontiac Bonneville SSE |
| Fuse Pull: Low Octane Fuel Fix For L99 and LS3. Reset Fuel Map for High Octane Fuel. | radz28 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2838 | 05-11-2024 11:42 PM |
| ***Updated Fuse Pull info, confirmed*** | PQ | 5th Gen Camaro SS LS LT General Discussions | 228 | 05-07-2016 01:19 AM |
| Fuse Pull Still Needed? | raider8654 | 5th Gen Camaro SS LS LT General Discussions | 15 | 12-20-2010 01:34 PM |
| fuse pull | goose2011 | 5th Gen Camaro SS LS LT General Discussions | 5 | 10-12-2010 07:57 PM |
| 8327 after fuse pull | redjewel | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 30 | 08-25-2009 03:24 PM |
