Old 06-17-2011, 11:35 AM   #1
2FST2LIV2YNG2DY
...this is my addiction!
Drives: SOLD
My 2500 mile road trip and need tips to prepare
I am relocating to Nogales, AZ from Philadelphia, PA and need tips on how to prepare for this long long journey. Yes I will be driving the Camaro down.
Sent from my iPhone 4 using Tapatalk
2FST2LIV2YNG2DY is offline   Reply With Quote
Old 06-17-2011, 11:50 AM   #2
scottyvegas
X SS
scottyvegas's Avatar
Drives: 2010 Camaro 2SSRSM6 1988 Sportside
I always go to the dealership for long trips and have them "check for roadtrip". Fluids, tires, air in the spare etc......Most will do this for free.
MODS: PEDDERS XA COIL OVERS, STAGE 3 CAM, McLEOD CLUTCH, SKIP SHIFT, , HURST SHORT THROW, CAI INTAKE, SCOOP, WASHER RELO KIT, KOOKS HEADERS, KOOKS HI FLOW CATS, CUSTOM TUNE, QTP CUT OUTS, PAINTED STRIPES, PAINTED SS EMBLEMS, PAINTED FIN, PAINTED REAR TAIL LAMP BEZELS, HERITAGE GRILLE, DUCTS, AAC STUFF, BAER ROTORS, HAWK PADS, FUZZY DICE, LASER BEAMS, DISCO BALL, SYBIAN & 3 CHROME VALVE STEM CAPS................
scottyvegas is offline   Reply With Quote
Old 06-17-2011, 11:52 AM   #3
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
RADAR DETECTOR!!!
christianmotox is offline   Reply With Quote
Old 06-17-2011, 11:54 AM   #4
TOMS1SS
Drives: NA
If you DIC tells your oil change is 40% away you should be fine on the LTT. Just do the basics like checking your tires and fluid levels. You'll probably want to get a warm weather battery when you get here because the heat will kill the one in your car. Incidentally there is a Camaro club out here with 300 something people (Arizona All Gens) that is all over the state. One final thing, do a full detail when you get here. I did a similar drive from Detroit to Phoenix 10 years ago when I moved here and you'll need it.
TOMS1SS is offline   Reply With Quote
Old 06-17-2011, 12:48 PM   #5
2FST2LIV2YNG2DY
Drives: SOLD
I will do that. Thanks for the info.
Old 06-17-2011, 12:49 PM   #6
2FST2LIV2YNG2DY
Drives: SOLD
Originally Posted by christianmotox View Post
RADAR DETECTOR!!!
I was actually shopping around for some today but don't know which are the good ones.
Old 06-17-2011, 12:50 PM   #7
2FST2LIV2YNG2DY
Drives: SOLD
Thanks for all that info. I'm going to do an oil change the week before I leave will get a detail when I get there. Thanks.
Old 06-17-2011, 01:42 PM   #8
VTXrider
VTXrider's Avatar
Drives: 2010 RY 2SS/RS
What's your budget?
Alot of people are going to say Bel GX65 or Valentine 1 or Escort 9500xi. All are about $450-500. All are excellent but I disagree.
In my view, I would get the Bel 955 for about $150 or the Bel 995 for $225. Both will give you 95% of the warning distance of the expensive ones but the 955 will have significantly more false alarms and the 995 will have slightly more false alarms.
If you want an expensive one I would get the Escort Passport IQ. This is about $650. It tests the same as the Escort 9500 but also is a GPS and you can plug it into your computer and it downloads known traps and speed and red light cameras to notify you of those as well. Also since it just looks like a GPS cops don't give it a second look.
Be aware however that many areas now use LIDAR (laser) enforcement and detectors do not go off until too late, there are some jammers which help but are not foolproof protection.
VTXrider is offline   Reply With Quote
Old 06-17-2011, 01:55 PM   #9
fugimo
fugimo's Avatar
Drives: 2010 Camaro SS/RS ABM
Also along with what others are saying here, get a good wax job on the car, it will make cleaning it a lot easier when you get to AZ.
Born date 12/18/09
ARK Slant Tip Cat back Exhaust
Ported throttle body
Injen CAI
AAC lighting (Foot well, trunk, interior, RGB Halos, Plasma DRLs, V2 scanner, side markers)
fugimo is offline   Reply With Quote
Old 06-17-2011, 02:15 PM   #10
colemanvoice
team chicklet camaro
colemanvoice's Avatar
Drives: MOTL3Y
...and that's why I try to read all posts before I make my own. I agree, wax that sucker, just before you go.
colemanvoice is offline   Reply With Quote
Old 06-17-2011, 03:12 PM   #11
ponygirlnomore
ponygirlnomore's Avatar
Drives: 2011 LT (SW)
If not already turned on, OnStar, or perhaps even LoJack. I'm in Tucson and well, some places are not exactly the safest place to be. I hope you have a secure garage to park it in once you get here. Also, if not already done, get the windows tinted as dark as legally permissible. Every day for the past week my Camaro has read 106 degrees consistently. I don't think Nogales is as bad as Tucson at the moment, but nonetheless, it's HOT with no relief in sight.
Also, I'm not sure what's going on with the Arizona-New Mexico wildfires or how much damage to the infrastructure it's done, but I'd check the highways you'll be taking in the general area with like news agencies here just to make sure you will be using roads that still exist.
ponygirlnomore is offline   Reply With Quote
Old 06-17-2011, 03:22 PM   #12
HumanWiki
Drives: Car
You don't need a RADAR detector if you choose not to violate the speed limit..
I took two lengthy road trips in my SS and just did the basic systems and fluid checks one should be doing on a regular basis.
The biggest thing you need to do is to enjoy your car and the trip.
HumanWiki is offline   Reply With Quote
Old 06-17-2011, 03:23 PM   #13
Matic
Matic's Avatar
Drives: 2011 Summit White LS
Onstar is virtually useless to anyone other than a novice thief. He is so close to the border, none of that would really matter anyways, one would think.
Matic is offline   Reply With Quote
Old 06-17-2011, 04:06 PM   #14
mikeSS
mikeSS's Avatar
Drives: 2015 c7
get ready for colder weather in the winter
