Old 06-18-2011, 04:54 PM   #1
Icefsh
Icefsh's Avatar
Drives: CGM 2LT/RS M6
Help with new speaker install
I have the Boston premium system. Changing out the front speakers. Just installed one side. Does not sound as good as the Bostons on the other side. Sounds like a bad connection or about half the power. The speakers are Focal Access 165 a1. Supposed to be a quality speaker. Anyway I used the harness and adaptors from ********. Connected it to the wires that went to the woofer, (that is the only place the harness would plug into.) Then took those wire from the harness to the input of the crossover. Double and triple checked all connections and polarity. They all seem good. Do I need to install both doors before I get a good connection or am I not getting full power because I am just coming off the woofer only? HELP!
Icefsh is offline   Reply With Quote
Old 06-18-2011, 10:55 PM   #2
Veritasz
Drives: 2010 Camaro
The change in speaker intensity may be due to the mismatch in the new speakers impedence. Most car speakers are 4 ohm. Ones used by factory systems can be all over the map. This may be the problem.
Veritasz is offline   Reply With Quote
Old 06-18-2011, 11:27 PM   #3
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
^^^ That may be it.
Also, I doubt that the BA amp is "powerful" enough for those Focals
I'd change out the stock amp for something a bit better
Old 06-19-2011, 03:56 AM   #4
zachi3
Drives: IOM 2SS Convertible
Try without the crossover from FOCAL. Connect the speakers to original wires in doors. Just to be sure, that the OEM amplifier does not cut frequencies internally.....
zachi3 is offline   Reply With Quote
Old 06-19-2011, 08:23 AM   #5
epstein
Drives: SS/RS
Send a message via AIM to epstein
get thee an amp ....stock is not your friend....
epstein is offline   Reply With Quote
Old 06-19-2011, 10:03 AM   #6
Icefsh
Icefsh's Avatar
Was thinking of doing what zachi3 said. Try to hook it up to the factory wires and eliminate the crossover. Makes sence that this might work. Also Veritasz mentioned that the inpedence is not right. I think Steve at ******** agress with you.
I did email Steve at ******** yesterday. He returned my email quickly. He says that the speakers I installed are 4 ohm and the boston speakers are 2 ohm. Bummer, hopefully he can come up with some type of amp setup that I can affordably get into. Looks like I will not be listening to my stereo until I find a solution. Thanks for the feedback everyone!
Old 06-19-2011, 10:18 AM   #7
oldfriend
Drives: Fiat 500 E
SS
On the other hand ******** knew all along that the new speakers DID NOT match the OEM equipment and said nothing when you bought them ?????In my book it says that you were setup to buy other parts from them !
Old 06-19-2011, 10:25 AM   #8
Veritasz
Drives: 2010 Camaro
I'd also think before I ran the speakers without the crossover unit. Playing frequencies that a speaker is not designed to play will fry a voice coil, especially the tweeter. I have no idea if the factory amp has internal crossovers in it or if the frequency band is cut by using passive components closer to the speaker. Best advice I can give you is to save up and build the system you truely want.
Old 06-19-2011, 10:42 AM   #9
Icefsh
Icefsh's Avatar
Guys, Steve did not sell me the speakers. I bought them at Ultimate Electronics when they were going out of bussiness. Got a great deal on them. Although it does not seem that way now. Sorry, I should have said this from the beginning. I just bought the speaker adaptors and the harness from Steve. I should have researched this before I installed them.
I suppose I will have to save up and get the right equipment. Hopefully others won't make the same mistake I did when they go to build thier system. I only have one door intalled now and am not to motivated to install the other side. Although now I know how to get this done alot faster. Sure am glad I bought the plastic pry bars. Quite the learning experience.
Old 06-19-2011, 10:45 AM   #10
Iwantone2
Iwantone2's Avatar
Drives: CGM 1SS RS
Umm...I bought the harness and adaptors from ******** and my speakers work just fine Unless he bought the speakers from ******** as well, I'm not sure how the OP was setup to buy other parts from them...
EDIT: thanks for the clarification OP
Old 06-19-2011, 10:49 AM   #11
Foreverman
Drives: 1SS-RS
i cant believe this!
I would be hard pressed to find 2 ohm speakers - even the low end of low are 4 ohm. Are we sure this is true?
Foreverman is offline   Reply With Quote
Old 06-19-2011, 11:02 AM   #12
Icefsh
Icefsh's Avatar
Thats what the email I got from Steve said. Now maybe the base system without the amp is different. Don't know. Sounds like some people have added speakers without a problem. Its like the premium boston accustics system standard with the 2LT and 2SS package is not ment to be upgraded. I mean without having to buy seperate amps. Hopefully its something GM can look at in future models.
Old 06-19-2011, 12:41 PM   #13
Iwantone2
Iwantone2's Avatar
Drives: CGM 1SS RS
Specs:
Name:  BA Speakers specs.jpeg
Old 06-19-2011, 04:54 PM   #14
Foreverman
Drives: 1SS-RS
I am almost embarrassed for the choices made in creating the premium package ...
Install of new Pioneer AVH-P3300BT with painted black Metra kit Darth Martel Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 50 09-13-2011 09:50 AM
Amp install and compartment non BA Black on Black Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 8 01-30-2011 02:11 PM
4.10 or 3.73 Gear & Install Kit Combo Apex Paul Transmission / Driveline 21 08-21-2010 02:55 PM
Edelbrock E- Force Super Charger Install On 2010 Camaro rt66 Forced Induction - V8 17 06-02-2010 04:15 PM
Please help with speaker install!! camaro10rs Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 0 03-13-2010 01:32 AM
