Old 06-20-2011, 08:32 PM   #1
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
rear tires wear inside
have a pedders full xa coilover/bushings/alignment...problem is that after 2000 miles ,rear tires are starting to wear really bad on inside..315/25/22.. others with these exact tires are not having this problem..mechanic check , and said camber was -1,which looks correct, any ideas, i did print out from the page from petes post on alignment and will take that in tomorrow, but looking for more ideas...tires worn in rear are identical,..
mikepage0007 is offline   Reply With Quote
Old 06-20-2011, 08:39 PM   #2
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
Must be alignment if they are equal, get it back on a rack and checked.
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 06-20-2011, 08:45 PM   #3
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Normal if you don't drive your car hard for negative camber to wear the inside, especially in a hot climate like FL where the road surface is very hot, causes tires to wear even faster.
DietCoke is offline   Reply With Quote
Old 06-20-2011, 08:52 PM   #4
mikepage0007
Drives: 2010 camaro
but 2000 miles, i,m lucky to get another 1000 miles out of them at this pace..talk to half dozen other guys and they were between 4500 and 12000 miles, with no bad wear.. tires almost new in middle and outside..they thru back on rack today before tearing my rear out and installing a 9...-1 on camber...but def going back on rack when done , so we can look at it again afterwards..
Old 06-20-2011, 09:02 PM   #5
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Tons of other guys isn't you. Reality check much?
Only two things cause inner wear like that. Excessive camber, and excessive camber coupled with toe.
Both will eat your tires up, the more aggressive your camber, the hotter the pavement and softer the tire, the faster it will happen. Pretty basic, and since you shouldnt have any toe at all in the rear, odds are it's your camber.
PS: Did they align the car with you sitting inside of it? Not accounting for your mass inside the car can cause significant (1-2 degree) camber difference on an already lowered car due to the suspension arc at that ride height. (Amount varies of course depending on spring setup and how fat, or unfat you are)
Old 06-20-2011, 09:11 PM   #6
mikepage0007
Drives: 2010 camaro
you know, i read that also about people in car , especially with indepent susp..makes me wonder, as i usuallly travel with another person and stuff...so actual 400lbs plus would actually be in car, but don,t know with coilovers riding stiff would allow much diff in camber...so does rear alignment need weight in coilover dropped car, for accurate alignment???
Old 06-21-2011, 12:12 AM   #7
mikepage0007
Drives: 2010 camaro
just to let everyone know, have had pedders susp for close to a year, mike and pete have been there for me evrytime i had a problem..i pm pete and he is helping me work thru this and thought that it was worth noting..sure it has nothing to do with pedders parts, more of a installation hiccup that prob has my rear alignment out...no fault of theres..but willing to take the time to help a customer out
Old 06-21-2011, 12:17 AM   #8
IOM Black Diamond
HT5 COTW 1/21/13
IOM Black Diamond's Avatar
Drives: 2010 Camaro Inferno 2SS RS 6M
Check the date on the tires. Make sure they haven't been sitting on the shelf forever. Old tires will wear really odd some times.
IOM Black Diamond is offline   Reply With Quote
Old 06-21-2011, 07:02 AM   #9
mikepage0007
Drives: 2010 camaro
the 315/25/22 never sit...they are backordered alwys..pirelli is only compay to make a tire this size...pete said to get camber as positive as possible..and a few other things..
Old 06-22-2011, 03:57 PM   #10
JusticePete
Drives: Camaro Justice
Mike,
Thanks for the props. At Pedders we take care of our own. That just happens to include the Camaro5 community and all the members no matter what brand suspension they choose to use. We are ALL Camaro5 members, right?
Old 06-22-2011, 05:23 PM   #11
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
Pedders are top notch,I would recheck that alignment, it would not suprise me to see one of the rear adusters slipped.They must be tight,it happens from time to time with cars that use cams to make the adjustments.
Bruce@raymondsperformance is offline   Reply With Quote
Old 06-22-2011, 06:07 PM   #12
mikepage0007
Drives: 2010 camaro
both tires are worn exactly same way...so it is identical for both sides...they are finishing up 9inch rear today, just left and they were massaging exhaust steel to work around pumpkin...no clearance..then wheels go back on and i will post results...
Old 06-23-2011, 07:38 PM   #13
mikepage0007
Drives: 2010 camaro
latest update, put 9 back in, we were at -.12 camber, could not get any more positive without raising car ...i was dropped at approx 1 1/2 inch...or more...raised car a little and tweaked -.04 camber both sides...toe was aprox.12, we left there..for now..i will post alignment page when i pick up car
Old 06-23-2011, 08:12 PM   #14
JusticePete
Standing by.
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 11:51 AM
2000 Mile Stock 20" SS Rear Tires $300 Jason 98 TA Wheels / Tires 2 05-26-2011 04:53 PM
Tire Wear on 2SS RS stock tires rlem00 Wheels and Tires Talk Sponsored by The Tire Rack 16 05-21-2011 11:07 AM
2 rear 20x9 midnight sterling wheels with Pirelli tires flht99b Wheels / Tires 0 01-25-2011 09:04 AM
Rear tires to the FRONT bzzzz Wheels and Tires Talk Sponsored by The Tire Rack 4 09-07-2010 10:20 PM
