Old 06-22-2011, 11:58 AM   #1
Without Remorse
Drives: 2011 2SS/RS RJT Convertible
Losing MPG with CAI?
OK, so I am no mechanic. I have never had a true muscle car and therefore have never moded. I am functional with a wrench in my hand but let me repeat......I am no mechanic.
So I installed a Cold Air Incuctions CAI in my LS3 Vert. I am very proud of myself and really didn't have too much trouble with it. It took me about an hour. It looks great, sounds better at idel, and has a wonderful new sound under WOT.
My question is this.....As I watch my Avg MPG meter, it seems that I now may be getting worse MPG's. Is that possible? Especially when I get on it. When I give it a lot of gas, it seems to suck much more gas now then it did before. Is this possible?
I haven't done any scientific test to try to prove this, only watching the meter and comparing it to what it did prior. Is there any way that I F'd something up or something isn't sealed properly? Or is it all in my head and I need to just chill out for a second?
Without Remorse is offline   Reply With Quote
Old 06-22-2011, 12:04 PM   #2
BowlingSS
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT
I did not not see any change in mileage after installing my CAI. INC CAI. How long have you had it installed? The PCM might need a little time to settle down to the added air. How much of a drop are you seeing?
Bill
BowlingSS is offline   Reply With Quote
Old 06-22-2011, 12:07 PM   #3
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
You MPG will go down if you floor it all the time.
Pollock is offline   Reply With Quote
Old 06-22-2011, 12:23 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
So you're watching your gas mileage while you're flooring it? You're joking right? The ONLY way to tell if you're getting different gas mileage is to datalog over a few tank fulls. The DIS will give you a idea of your average but watching your mileage while you floor it is worthess.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-22-2011, 01:17 PM   #5
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
I didn't see any change in mpg with any of the three cai I've ran. Not likely you messed anything up as you would probably set a CEL. You are playing with the throttle too much to gauge any average mgp differences...and yes just chill it will be fine.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 06-22-2011, 01:42 PM   #6
bottjeremy
bottjeremy's Avatar
Drives: 2020 Camaro SS 1LE - Born July 2020
By adding a CAI, you are most likely creating more horsepower. By adding more horsepower, you are most likely consuming more gasoline. You will see a reduction in MPG when driving fast since you now consume more gas under WOT. And since you like the new sound of your CAI, you probably are nailing it a bit more than you had been previously, so your loss in MPG might be noticable.
2020 Camaro SS 1LE
bottjeremy is offline   Reply With Quote
Old 06-22-2011, 01:44 PM   #7
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
This winter I thought I was getting worse mileage with my CAI, which I had installed late fall. So I switched back to the stock airbox and noticed NO improvement. The loss in mileage was due to the engine running cold/winter gas blend, not the CAI. I lost about 2-3 MPG.
There should be no noticeable difference in MPG. You may just be driving more aggressively due to the improved WOT sound. I know it's hard to resist
cab2g is offline   Reply With Quote
Old 06-22-2011, 01:57 PM   #8
talon6900
GRRREEN
talon6900's Avatar
Drives: '14 Denali HD & '11 Camaro
I lost a bit too, but it was 100% my doing... Enjoying the sound makes you want to press the skinny pedal farther to the floor more often. Once I regained self control, I found that my mileage came back to normal.
2011 SGM 2SS/RS M6; VIN 2G1FT1EW7B9134817 620rwhp/550rwtq
SLP TVS 2300 @ 6.5psi/CAI Intake/TSP Cam/Kooks LT/Borla ATAK
ZR1 Max Clutch/BMR Stage 3/DSS 1000HP Axles/1LE 3.91's
Carbon Flash Metallic GFX & Stripes, Black TSW Donington 20's
DashTronix Radar Projector for Valentine1
talon6900 is offline   Reply With Quote
Old 06-22-2011, 02:20 PM   #9
blkngldbabe
Barossa's handler
blkngldbabe's Avatar
Drives: 2LT/RS RJT
My fuel economy had improved with my Intake.
SLP's GTA Master Specialty Vehicle and Master Parts Dealer
blkngldbabe is offline   Reply With Quote
Old 06-22-2011, 03:01 PM   #10
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
What I've seen from reading C5 is if you drive in exactly the same way (not probable with your new CAI!) your intake should actually increase your mpg by 1 or 2 because your car can breathe better.
My boyfriend don't mind it.
CamaroFemme is offline   Reply With Quote
Old 06-22-2011, 03:01 PM   #11
Without Remorse
I think you are being sarcastic, but in case your not......I was comparing "getting on it" without CAI to "getting on it" with CAI. I realize that my MPG's will go down when my foot is on the gas.
I keep my DIC on MPG's.....I dont know where else to keep it. I really don't need another speedometer, as i already have 2. I have been resetting it every 500 miles or so to see if I notice any change as the engine breaks in. As such, I feel that I have a pretty good feel of how my MPG's are effected by city/highway, coasting, gunning it, etc. I can be a bit OCD. Like I said, nothing scientific.
This makes sence to me and what I was thinking. More/colder air --> More gas --> More HP --> More fun. I'm going with this....
Old 05-05-2021, 06:43 AM   #12
4.0=SS
4.0=SS's Avatar
Drives: 2010 Camaro 2SS RS IOM/Blk, Borla
I have a Borla cat-back is a cai going to change the exhaust note? I paid good money for the sound ;-)
4.0=SS is offline   Reply With Quote
Old 05-05-2021, 07:22 AM   #13
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Did you install your maf sensor in the right direction?
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 05-05-2021, 08:25 AM   #14
Avenging Orange
Avenging Orange's Avatar
No
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
CAI Inc. Ceramic Coated Intakes Are IN STOCK And Ready To Ship At APEX Motorsports!!! Apex Motorsports V8 Bolt-Ons & Tunes 270 08-07-2011 08:57 AM
Roto-Fab | Cold Air Intakes | Engine Covers | Washer Reservoir Relocation Kit | Fuse+ AutoAgenda V8 Bolt-Ons & Tunes 7 07-11-2011 07:50 PM
63 mpg cafe in 13 years cuspid General Automotive + Other Cars Discussion 13 05-15-2011 12:28 PM
SS A6 or M6 faster?????? MY2010SS 5th Gen Camaro SS LS LT General Discussions 275 05-20-2010 05:15 PM
Help Me Pick An Economy Car Marosolid Off-topic Discussions 75 07-11-2009 07:41 AM
