Old 06-22-2011, 07:26 PM   #1
Yervais
Drives: 2010 Camaro SS
Rear Shelf Speaker Rattle... BA system...
I know it has been discussed before... but did someone find a fix for it... rear speakers will rattle over with heavy bass notes at higher volumes...
Let me know!
Y
Yervais is offline   Reply With Quote
Old 06-23-2011, 01:30 AM   #2
Whiskey2Go
"Hook'em"
Whiskey2Go's Avatar
Drives: 2010 Camaro 2SS/RS L99
Glad it's not just me. I hate this. Hear it randomly.. Hope someone post a fix....besides replace the speakers.
Whiskey2Go is offline   Reply With Quote
Old 06-23-2011, 06:53 AM   #3
suhailrehman
Drives: Chevy Camaro 2010 1LT Imperial Blue
The best solution i saw around the forums is to dynamat the rear deck lid and also at the speaker mount points to reduce rattle. Does anyone have a DIY or pictures on how this can be done?
suhailrehman is offline   Reply With Quote
Old 06-23-2011, 11:28 AM   #4
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
Heres the install of it.
I had a fun day. I installed some new 6x9 speakers. I used the new 6x9 adapters from www.********.com[/URL]
http://********.com/Search-Results?k...a832ef0d7d4d86
Remove the rocker panel.
Remove the back seat. Start with the bottom part. You will need to pull up on the front part of the seat and then pull forward.
To remove the seatback you will fold the seat down and then look at the hinge you will see what I saw in the second photo. You will need two people to do this because it has to be done at the same time on both sides. Just push the silver piece back and lift the seatback up and out.
Now it is time to remove the lower interior trim piece. I started at the bottom front and worked my way to the back.
Next remove the back window trim. When you pull this off be careful their is a black clip that needs to be removed after you get this off. I think it is part of the airbag system.
Now remove side window trim. You will need a 7mm socket and T50 torx bit. There are two screws. One is hidden under the "Airbag" piece above the seatbelt for the front seat and the other is by the back window. You will need the T50 torx to remove the front seatbelt. After you have all of the screws removed just pull on the piece and it will pop out.
Now the real fun beggins. The rear speaker deck. There are four push tabs on the front part that need to be removed. Once you have them removed get under the speaker deck in the trunk and you will see four push pins that need to pushed up.
Here is the underside, You can see the four blue push pins. This is what is holding this piece in place. I worked my hand between the deck trim and the sheetmetal and pushed up on the deck trim and they came out.
At this point the rear deck trim still did not want to come out. If you look at the photo (below). You can see three of the four tabs that hold this in place. I just had to pull hard to get this to come out.
Here is what it looked like after everything is out
You can see the factory speaker now. If you notice there is a big foam piece right next to each speaker. I'm not sure what this is for, but I think it helps to put pressure on the speaker deck. I would say do not remove this.
Installed Dynamat.
I installed the new speaker to the ******** adapter. New and old.
Here is the speaker installed.
Just put everything back in the reverse order and your done. It took a few hours to do this, but it was worth it. The sound system sounded so much better. Next step will be amps and sub.
Total time was 2 1/2 hours from start to finish.
The hardest part for me was removing the two screw on the molding next to the glass.
I replaced my system with Rockford Fosgate 6x9 ways. The bass response is incredible. I have also replace my fronts with Rockfords 6.5 components, that was much easier to do.
=Stephens= is offline   Reply With Quote
Old 06-24-2011, 10:23 AM   #5
Yervais
Thanks for that!!!!
Old 06-24-2011, 11:43 AM   #6
caper
Drives: 2010 IOM 2ss/RS
do you need to remove all that to get rid of the shelf rattle??
caper is offline   Reply With Quote
Old 06-24-2011, 05:17 PM   #7
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
Unfortunately you do. Unless someone else has another way to do it.
Old 06-24-2011, 06:06 PM   #8
Dmundz
Dmundz's Avatar
Drives: 2010 Cyber Gray 2SS/RS
Wicked pics I will be following this page when my 6x9 show up
Dmundz is offline   Reply With Quote
Old 06-24-2011, 06:16 PM   #9
caper
i am takin mine to the dealer for this shortly...let them worry about all that, i will show them this post if needed...thats kinda nuts...
Old 06-24-2011, 09:13 PM   #10
meschwenk
meschwenk's Avatar
Drives: 2012 Camaro 2SS
Hey =Stephens=
Thanks for showing my work on how to do the rear speaker install. I'm glad my posting has helped you and others out.
Here is the original posting of my install http://www.camaro5.com/forums/showthread.php?t=123352&highlight=speaker+install
meschwenk is offline   Reply With Quote
Old 06-24-2011, 09:29 PM   #11
bojangles37
bojangles37's Avatar
Drives: 2010 blk ss
Honestly this doesn't sound like it will work at all but mine rattled terribly when ever I played it loud but after I added a new amp with the ******** harness... I have yet to hear Another rattle since. So I have no idea why it stopped the rattle but it did and it made the BA system sound really good and loud
bojangles37 is offline   Reply With Quote
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-18-2012 12:24 AM
rear speaker install (pictures) Shadowjack Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 11-03-2010 06:44 PM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 02:56 PM
