Old 06-22-2011, 10:51 PM   #1
linda052
Drives: 2000, camaro, black
DIY VVME HID kits for Camaro
Step 1: After disconnecting power to the two headlamps and after removing the bulb access covers of the low beam, high beam or both bulb access covers, drill a small hole in the removed cover. The HID-Xenon bulb wire is passed through this hole for your headlamp upgrade. On the wire is a supplied adjustable tight rubber waterproof grommet to be fitted into the hole. Next, the HID-Xenon bulb is fitted into the headlamp's base and locked into position via the factory locking device. No cutting of wiring is required on the installation. from VVME.COM
Step 2:Reinstall the access panel and close it.Secure the small ballast to a convenient location in the motorbay.
Step 3: Finally attach power to the headlamp in the normal manner and the upgrade is completed. Headlamp realignment is recommended but only required if you have removed the headlamp during the upgrade which sometimes can be avoided (model and side dependant). It takes about 1-2hours to complete the installation. No special tools are required. Normal handtools only.
Before and after HIDs
linda052 is offline   Reply With Quote
DIY - Install BFxenon HID Fog Light kit - RS and non-RS package BFxenon.com Camaro DIY & HOW-TO instructions & discussions 46 04-25-2011 12:04 PM
5 things you NEED to know about HID lights BFXauto.com Cosmetics and Lighting Modification Discussions 2 02-15-2011 02:13 PM
*New Vendor* Flashtech Lifetime warranty HID kits! Free shipping in july! steve@flashtech Exterior Parts & Accessories 48 10-08-2010 05:56 PM
5202 (H16 ; 9009) Slim HID Kits !!! 09-Up Camaro Fog Light HID kits !!! HID_Guy Exterior Parts & Accessories 19 09-08-2009 02:07 AM
2010 Camaro Fog/DRL Light 5202 HID kits .... HID_Guy Exterior Parts & Accessories 1 09-07-2009 01:19 PM
