Old 06-24-2011, 08:37 AM   #1
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Tampa Tuning dyno results of street tuning package
www.TampaTuning.com
If you recall, back in January, This stock car with an after market air intake dyno'd at 371 RWHP and a SCT tune. within 5 minutes of the dyno, a SC2150 ported throttle body was installed, and it pulled 380 RWHP.
Recently, the owner installed long tube header, and Tampa Tuning designed a street package tune on it. The temperture on the orginal dyno was 70 degrees. The below are the results are from last week's dyno on a 99.6 degrees day.
The Tampa Tuning street package tune produced 405 RWHP and 400 RWTQ on a nearly 100* day.
On the original dyno day in January, Five Gen 5 camaros were done ...
Josh - 397 ( tune by another shop)
Paul - 380 ( SCT tune)
Jim - 375 (unk)
John - 318 ( tuned by another shop)
Pete - 240 (V6 untuned )
Tampa Tuning is offline   Reply With Quote
Old 06-24-2011, 08:51 AM   #2
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Why not SAE (corrected) numbers?
That should help the numbers seeing it was so hot.
Old 06-24-2011, 10:08 PM   #3
Tampa Tuning
Here are the modifications:
K&N cai, Borla S type cat back exhaust, Kooks 1 7/8 headers w/hi flo cats, Vmaxx throttle body
SGO. You ask about corrected numbers in all dyno threads. What are you looking for? Flywheel numbers?
Shops dont give if the weather is XX temperture you'd get XX more HP.
Old 06-24-2011, 11:39 PM   #4
DSX
Drives: 2006 Z06
SAE Correction compensates for weather conditions and attempts to normalize the horsepower output to take weather out of the equation.
DSX is offline   Reply With Quote
Old 06-24-2011, 11:44 PM   #5
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
What day was this as it would be an all time record. Highest temp ever recorded in Sarasota was 99 back in 1998. Looking back at last week the highest temp recorded was 95 on June 16th and that's the only day it got over 91.
Feels like about 150 outside around here lately though. Car is running like crap in this heat and humidity.
Nice gains though.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 06-25-2011, 07:04 AM   #6
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
I am reasonably sure he knows what SAE corrected numbers are.....the problem is why give them...because nobody else gives them. Dyno sheets are all over the place.
The real gem of this thread is the huge increase in spite of 30 degree hotter temps.
HufferSS is offline   Reply With Quote
Old 06-25-2011, 08:05 AM   #7
Tampa Tuning
It was 99.6 degrees air temp in the shop while dynoing. My bad
The owner of the vehicle was told there was HP left on the table because of the heat. I dont like reporting numbers like that and would rather state the actual numbers coming off the dyno for better or worse.
Old 06-25-2011, 09:43 AM   #8
SGOS252382
SGOS252382's Avatar
The problem with STD numbers is that cars make significantly more HP in cold air.
STD numbers will be inflated in cold air and underrepresented in hot air.
You could dyno a car in 90 degree weather (STD numbers) and then dyno it again in 50 degree weather (STD numbers) and the number will be way off. The car will make significantly more HP in colder air.
You really need to use SAE numbers if the car was baselined on a different day with different weather conditoins.
My guess is his corrected SAE numbers would have been up around 415 - 420 rwhp because it was so hot. And his baseline numbers would have stayed pretty similar because it was 70 degrees.
Old 06-25-2011, 03:06 PM   #9
mrvenicess
mrvenicess's Avatar
Drives: 2013 CRT ZL1 auto
I will run it on Matt's dyno again when its not so brutaly hot out. Am planning on a cam in a couple of months so will do a couple of runs before we install the cam. The shop temp did read 99.6 on a day when outside temp was around 94.
mrvenicess is offline   Reply With Quote
Old 06-25-2011, 05:25 PM   #10
SLO RYDE
SLO RYDE
SLO RYDE's Avatar
Drives: 2011 IOM 2SS/RS 400hp+ / K&N CAI./
I like it Awesome results.
Need to get mine Dyno'ed; I should real close to this since I had the best Tuner in the area and the same MODS. What do you think Phil?
Bad thing is the shop around the corner does not open til 10am. I think its too hot and sticky for the best results. Will try to post soon. Maybe this week.
2011 2SS/RS IOM. / K&N CAI./ V Max Throtle Body / Pypes Headers & Pype Bomb exhaust. / Texas Speed 231/236 112 Ls3 cam/ RX Catch Can/ SLP Under Drive Pulley/ American Racing Torque M Wheels painted. / CBD Rear Wing, SunCoast Creations Bumbble Bee Hood, Heritage Grill/ SLP "SS" Badges and tuned by "TampaTuning.com" & Next Level Performance
SLO RYDE is offline   Reply With Quote
Old 06-25-2011, 09:15 PM   #11
DSX
Drives: 2006 Z06
Just because everybody else jumps off a bridge doesn't mean you should too. I encourage people to use SAE numbers everywhere. I use a Powerdyne Mustang dyno now though, so numbers always look low.
Old 06-26-2011, 06:27 AM   #12
Tampa Tuning
That would be great
Old 06-26-2011, 04:58 PM   #13
Snake Slayer
Snake Slayer's Avatar
Drives: Awaiting 2014 C7
Phil,
Great Work... We need to get mine back on the Dyno with the new Tune.
Awaiting 2014 C7
Snake Slayer is offline   Reply With Quote
Old 06-27-2011, 07:16 AM   #14
Tampa Tuning
That would be cool to see how the automatics numbers come out.
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 06:56 PM
Texas Speed Long Tubes & Rumbler 5 Cat-Back Dyno Results! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 48 12-08-2018 03:37 AM
West Chester, PA - Dyno Tuning $300 - Intake and TB Porting $225 AndrewZPSU V8 Bolt-Ons & Tunes 4 08-25-2010 01:38 PM
* * * Synergy Green Pricing Announced - Option B2E * * * CamaroScotty Camaro Price | Ordering | Tracking | Dealers Discussions 20 01-24-2010 04:06 PM
