![]() Drives: 2010 Camaro Join Date: Jun 2011
Need help getting to 700rwhp......advice?
Figured it out
Camaro SS Lover
Drives: 2010 Camaro 2SS/RS Black IOM Join Date: Jun 2010
For sure. Your tuner may have been very conservative? Do you have a meth. kit? Is your setup on an A6 or M6?
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
knows 2 facts about ducks
Yea 12 psi is kind of ridiculous. I wouldn't call that a conservative tune by any means.
![]() ![]() ![]() ![]() Drives: Maggie blown LS3 vette Join Date: Aug 2009
700 through an A6 is a pretty tall order for a TVS2300. That may be a little unrealistic without backing up a Brinks truck and dumping a bunch more money into your car.
With your mods and boost level, I would have thought you'd have seen more than 575rwhp. Could be a soft tune or it could be as simple as a stingy dyno. Also, if they diked around and heated things up nice and warm before the dyno pull, you won't see good numbers. |
![]() Drives: 2010 2ss LSR CAI, Borla S axle back Join Date: Apr 2011
Twin turbos...
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
Numbers are too low for 12 psi. I make that plus sum on 6 psi, with a cam and meth.
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
#7 | |
I would look at some kind of install problem: maybe vacuum leak. Try another dyno. The one your using might just be way off in calibration.
#8 |
Treasure Coast Camaro 5
what kind of dyno did u run on?
#9 | |
![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 Join Date: Aug 2009
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir Glassskinz rear window valance . 2012 ZL1 A6 (SOLD) Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC. Alky Control, FIICHILLER. |
#10 |
Mustang Dyno i was at 575 and on a Dynojet i was at 588. Both warmed up, but not hot.
Both SAE #'s |
#11 |
I understand the boost because of the small pulley. This thing shoots up the RPM's very fast when im on the throttle. Gotta have the smaller pulley to get the boost up because of the Long tubes and the deleted cats. From what ive been reading i must run a smaller pulley, due to lost back-pressure to get the boost back up.
Am i reading that correctly? |
#12 |
Drives: black camaro Join Date: May 2011
your car is a prime candidate for jannetty racing. if your far from them, they can do tunes remotely.
Jannetty Racing Enterprises 2984 East Main Street Waterbury CT 06705 Phone:203-753-RACE (7223)
#13 |
Something is wrong.
Here is a TVS pulley/boost chart: 3.60" pulley: expect 2.0 psi. more boost over stock pulley -Total boost 8.0 psi - 3.40" pulley: expect 4.0 psi. more boost over stock pulley -Total boost 10.0 psi - 3.20" pulley: expect 6.0 psi. more boost over stock pulley -Total boost 12.0 psi - 3.10" pulley: expect 7.0 psi. more boost over stock pulley -Total boost 13.0 psi - 3.00" pulley: expect 8.0 psi. more boost over stock pulley -Total boost 14.0 psi - 2.90" pulley: expect 9.0 psi. more boost over stock pulley -Total boost 15.0 psi - 2.80" pulley: expect 10.0 psi. more boost over stock pulley -Total boost 16.0 psi - 2.70" pulley: expect 11.0 psi. more boost over stock pulley -Total boost 17.0 psi
#14 |
There might be a 1-2 psi drop from the long-tubes. You need to get that thing checked out by another tuner.
| I need advice on upgrades | 73duster | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 17 | 12-26-2010 06:42 PM |
| Need advice on a cold air intake system | central99 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 17 | 07-22-2010 04:33 PM |
| 2010 ABM/BGE 2SS/RS M6 w/Roof FOR SALE SOON ... New Member Looking For Advice | ABM2SSRSM6 | 5th Gen Camaro SS LS LT General Discussions | 18 | 06-27-2010 02:02 PM |
| Need some advice, please. | X-Z01 | 5th Gen Camaro SS LS LT General Discussions | 0 | 04-28-2010 10:58 AM |
| I need some advice on the color selection here. | 13F20 | 5th Gen Camaro SS LS LT General Discussions | 33 | 02-14-2010 04:31 AM |
