Old 06-30-2011, 01:07 PM   #1
CPDSS
Drives: 2010 SS M6
Tach and Speedo: Does Anyone Else Think They Should Be Reversed?
Let me start by saying I really am enjoying my camaro. Bought a leftover 2010 SIM 2SS/RS M6 back in march and as of today just passed 1000 miles.
My only issue with the car thus far is the positioning of the speedometer and the tach. When i lower the steering wheel it's hard to see the right side of the tach which makes me worried that eventually i am going to over rev the car/hit the rev limiter. It seems to me that GM should have postioned the speedo on the right side and the tach on the left since you can still see your speed in the DIC. Does anyone else have the same problem?
I searched before i posted and could not find any threads on this and i apologize if this is a repost to an already discussed concern.
To any GM techs, would it be possible to have my local dealership move my tach to the left side and the speedo to the right?
CPDSS is offline   Reply With Quote
Old 06-30-2011, 01:10 PM   #2
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Nope. I like it like it is. While I do watch the tach, I use the DIC mph for better accuracy.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 06-30-2011, 01:15 PM   #3
Flashpoint135
Flashpoint135's Avatar
Drives: 2016 SS
My seating position must be different. I can see the Tach clearly, use the digital speedometer, and never even look at the analog speedometer.
Flashpoint135 is offline   Reply With Quote
Old 06-30-2011, 01:20 PM   #4
Moorepheus
Drives: 2013 Dodge Charge R/T Plus AWD
If you hit the limiter, you should be safe, the car will not let you rev above it. Someone correct me if I am wrong
Moorepheus is offline   Reply With Quote
Old 06-30-2011, 01:25 PM   #5
woodj
woodj's Avatar
Drives: 2SS/RS RJT Vert
In an automatic they are both fairly worthless. I use the HUD to see how fast I'm going and I use the digital readout to see my MPG. A speedo that shows 0 to 180 is pretty worthless anyway, you can't differentiate how fast you're travelling within any decent tolerance. I would rather the speedo was programmable and gave you different options such as a low range (0-60) and a high range (60-180). That would be more useable than what we have now.
K&N Typhoon CAI, Flowmaster Outlaw axle backs, Vertini 20" Wheels, Sparks Restorations SS Emblems, GM Wind Restrictor, Splash Guards
woodj is offline   Reply With Quote
Old 06-30-2011, 01:26 PM   #6
CPDSS
Drives: 2010 SS M6
maybe i just need to drive my car more................
Old 06-30-2011, 03:57 PM   #7
1BADLS3
1BADLS3's Avatar
Drives: Sold: 2011 2SS/RS
I think the position of the seat and the steering wheel will play a part for you. Mess around with both variables (seat and steering tilt/telescope) and see if you can't reach a happy medium that still keeps you in correct ergonomical and airbag-effectiveness position.
You should be able to comfortably be able to see the gages through the wheel and also have the airbag at least (12") away from your torso and it should be aimed at the center of your torso as well.
1BADLS3 is offline   Reply With Quote
Old 06-30-2011, 04:17 PM   #8
Bodih
I Got My Orange Crush
Bodih's Avatar
Drives: it like I stoles it...
I'm curious what difference the improved gauges in the 2012 will make. Will the new style gauges fit into the older dash?With the HUD, I never look at the dash gauges anymore. Before I got my car, I thought the HUD was just a gimmick; now I'm hooked.
My love is in league with the freeway. Its passion will ride, as the cities fly by, and the tail-lights dissolve in the coming of night. And the questions in thousands take flight ~Robert Plant - Big Log~
Bodih is offline   Reply With Quote
Old 06-30-2011, 04:35 PM   #9
jtzako
Drives: 2010 IBM Camaro SS
I dont use either the TAC or Speedo, but even if I wanted to I couldnt. With my seat and wheel adjusted the way I need them I cannot see the top edges of those 2 gauges. Plus, the speedo needle is too thick and I would need to fix that if I wanted to use it.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 06-30-2011, 04:39 PM   #10
L99SS
L99SS's Avatar
Drives: '10 Camaro IOM
I would have preferred them reversed. Years of driving Chevy trucks makes for a well ingrained habit. Even if the positions were reversed, the needle is too fat and I would continue to use the digital speedometer.
L99SS is offline   Reply With Quote
Old 06-30-2011, 04:43 PM   #11
Lazerbrainz2k3
Drives: 2017 Camaro 2SS - M6, NPP, MRC
They're positioned the same way as in most of the cars I've ever driven or rode in, so that's not a concern. And at 5' 11" I have the wheel positioned at the top, where I can see everything very clearly - gauges, road, all of it.
Lazerbrainz2k3 is offline   Reply With Quote
New! 2010 Camaro Pre-Painted Gauge Cluster Surround Bezel (speedo, tach, etc) RPI Designs Interior Parts & Accessories 67 07-17-2020 07:46 AM
How do you remove the Speedo/ Tach trim?? Dragon Tats Camaro DIY & HOW-TO instructions & discussions 4 04-22-2011 12:24 AM
speedo and tach scratched like the radio zero Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 2 06-14-2010 02:19 PM
Your thoughts on the Speedo and Tach in the 2010 Camaro dash? SlasherMcGee 5th Gen Camaro SS LS LT General Discussions 51 03-06-2010 11:13 AM
SS Speedo and Tach issues mbavenger Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 9 07-23-2009 10:20 AM
